Question about Microsoft Streets and Trips 2008 for PC
Microsoft Streets & Trips 2005
Vista, It use to work great but now I get this.
microsoft Streets & Trips
Your registry setting for this application were not copied correctly. To
correct these setting, run Setup again for this application from the
location where you originally installed it.
  • 2 more comments
  • KelvinNghiem Aug 14, 2008
    I have the same problem
  • LeonK Aug 18, 2008
    This same problem just started on 8/18/08. I have uninstalled and subsequently reinstalled Streets & Trips 2008 with no resolution or change to the problem - the same dialogue box stating to rerun Setup from original location. Incidentally, I cannot find "Setup" in the Program files for Microsoft Streets & Trips. Use Vista Home Premium OS.
  • szanghi Sep 26, 2008
    why get the new software you have the same problems and microsoft offers absolutley NO help. They want you to pay. Even when you have new computer and software. They,re just in it for the money.
  • Anonymous May 12, 2009
    Count the forth one in with the samr problum
    Problem Solver:
  • 79 Answers
Maybe if enough people come together and post our opinions they'll listen. Lets get everyone with these problems to post their problems. United we stand and devided we fall
Posted on Sep 27, 2008
Get the following error message: Your registry
If you are installing this on Windows 7 or 8 you will have to contact Microsoft directly. You can use Microsoft Technet or knowledge base to try to find a solution but I have found a bunch of this same error on their site and it appears to be a major problem.
I do know that the registry error is often a mistake and the program may run correctly after you reboot. This is a serious issue with Window 7.
Oct 15, 2013 | Microsoft Streets and Trips 2013 B17-00563
When I started MS Streets and Trips 2010 with GPS, I got a window that said: "Your registry settings for this application were not copied correctly. To correct these settings, run Setup again for...
Look on the box to see if Windows Vista supports this software. If so, I would suspect you have a deficiency in the hardware. (i.e. Not a powerful enough video card, not enough memory or not a powerful enough processor)
Nov 22, 2010 | Microsoft Streets and Trips 2008 for PC
I am using Vista Premier. My Streets & Trips
uninstall. type regedit in run. In the left pane click HKEY Local Machine. Find Software and Click. Find Streets & Trips Delete it 'All". close the box. clean your drive. Restart & reinstall
Jul 30, 2010 | Microsoft Streets & Trips 2009 Full...
Always get "your registry setting for this application were not copied correctly (S&T 2009 w/ GPS)...." any suggestions? Joe M
Uninstall the program completely. Then reinstall according to the software instructions. Then reconfigure your GPS hardware.
Nov 12, 2009 | Microsoft Streets & Trips 2009 Full...
Registry settings for this application were not copied correctly
it was 2008-2009 thats why it said it i have a vista computer 2 mine did the same thing the version last up2 2009 2008-2009 thats why
Jun 04, 2009 | Microsoft Streets and Trips 2008 for PC
Microsoft streets and trips 2009 registry issues on vaio p588e/r
Hi, go to the "streets.exe" file in the program folder, right-click it and go to "Properties". Click the "Compatiblity" tab and uncheck "Run this program...". Try it now. It's what I had to do.
May 03, 2009 | Microsoft Streets & Trips 2009 Full...
Your registry settings for this application was not
Hi
My personal openion is , by using just only Registry cleaners will not solve your problem
We need to get rid of every supported file.
so suggest you for
1) Uninstall the application
2) Restart
3) Use Regsitry Cleaners
4) After successfull cleanup of regsitry go into registry for manual removal by clicking Start -> Run --> Regedit
5) Now locate HKEY_LOCAL_USER -> Software ->
Here locate the application matches with the name of MS Streets (actually i have not used this, so i am not sure about the exact name, but i am sure that you will locate it)
And DELETE that key
6) Same is for HKEY_Current_User--> Software
7) Now go into System Drive (usually C drive) and locate the programfiles -> MS Streets
(again i have not used this, so i am not sure about the exact name, but i am sure that you will locate it)
And DELETE It.
8) Now restart the system
9) Now we need to use some JUNK FILE CLEANERS for get rid of other supported files
so i suggest you to go with Tune-Up Utilities 2008 version (its trial ware for 30 Day - Fully Functional)
so from that use your JUNK FILE CLEANER
10) After successfull clean up i incist you to execute the Defragmentation process on system drive (usually C drive) so that we can close the backdoor for support files.
11) So after doing all above MAINTANANCE then try to install the application once again
If problem persists.
Please let me know, then I personally get involved with this topic
Thanks
Sep 17, 2008 | Microsoft Streets and Trips 2008 for PC
I have microsoft streets and trips 2007 and I have media player 11
How can you get MS-Streets & Trips 2007 into full screen. It will only open in a 6 x 6 window and far too hard to read. When I first used S/T it was full screen but have not been able to get back there since. Have tried several time re-intalling and read everything I can find and still no go. Any information will be appreciated.
Thanks Larry
Nov 17, 2007 | Microsoft Deluo Universal GPS USB...
Microsoft Streets and Trips 2008 for PC Logo
115 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
