Question about Car Audio & Video
I installed a Kenwood mp245in my 92 TC and it sounds like **** using factory amp. Proper wire harnesses were used but yet blah! So now I want to bypass amp but still use exsisting speaker wires, I noticed they all go into amp and out of amp. Can I cut power off from amp then splice speaker wires together matching color to color? I want to try to avoid direct wiring and have to but hundreds of feet speaker wires! Plus without the wire harness I wouldn't know antenna and power antenna motor wire
  • y9e3s7 Oct 13, 2010
    Am I able to pull out the input and output harness from factory amp in 1992 Lincoln, aluminum one not sub for this one didn't come with sub, and connect color code match , and also disconnect power supply to amp? I want to be able to use existing speaker wires and main power supply to radio ? Just do not want amp that came with car. If this is possible what are color wire codes from amp that I need to snip
  • y9e3s7 Oct 15, 2010
    Very helpful, I have one more question but cannot afford to ask .
  • 11,896 Answers
Yes you can bypass the amp. You can find out which wire is which by going to installer.com or the12volt.com
Those are sweet sites showing you all the factory radio wires in your car.
There should be a fuse for the amp you can pull. Otherwise just cut the powre wire. You can always use that power wire later on if you go with an aftermarket amp.
Posted on Oct 13, 2010
    President:
  • 1,768 Answers
Here is a site that has the pdf / schematic that may assist you if you direct wire
your system.
http://www.eserviceinfo.com/index.php?what=search2
I do not ever recommend rewiring any thing electronic to something it was not designed for. You may overload the battery to your vehicle and or ground out the whole system if not properly wire. Most manufacturers have engineered their unit to specific tolerances and to modify them may cause harm to other electronics.
Battery drains after stereo install
Sounds like BCM unable to power down with this unit. Call Kenwood tech. support for assistance.
Jan 09, 2014 | 1997 Chevrolet Blazer
After a after marker radio install I have no sound from my speakers. 2000 eclipse
I can definitely solve your issue. I just need to know a few things.
1.) Was the factory amp used in the install of your aftermarket deck?
*if equipped the amp would be located underneath the passenger side seat*
2.) Did you use a cable harness to connect to the factory harness when you installed the aftermarket deck?
Jan 29, 2012 | Kenwood Car Audio & Video
I just installed a new deck but no sounds or feedback from speakers what am I missing
You need to answer a few questions first. Do you have a factory or aftermarket amp? Did you use tape or crimps to attach the harnesses together? Did you use the proper harness? Is the head unit new or used? Check the fuse(s) in the back of the head unit. Then check your wire connections. Check that they are hooked up to the right colors and they are solid.
May 02, 2011 | Kenwood Car Audio & Video
Kenwood KDCBT645 deck mounted into a 2000 Miata I have replaced the Sony deck in this car with the deck above ,most of the wires matched up to the factory plug .The deck works fine BUT the power antena...
Use the Amp remote turn on wire, some units don't come with a antenna wire and as an installer we use the remote turn on instead.
Kind Regards Influential Customs
Dec 30, 2010 | Kenwood Kdc-bt645u Car CD/ MP3 Player
Whats the proper way to install the cd player into a 1992 chevy pick up truck and if u cud send a manuel
The proper way to install any aftermarket deck into a newer vehicle is to get a factory wiring harness adapter. This adapter will attach to the existing wiring harness for your factory stereo system. You can purchase these from various websites like this http://us.ebid.net/for-sale/1992-chevy-pickup-fullsize-radio-wire-harness-92-17373248.htm?from=googlebase
When you plug this in your factory speakers and power/ground will all be available to wire to your new deck without cutting or splicing any wires. The colors follow the E.I.A standard and should match your new stereo. I hope this is helpful and thanks for using FixYa.
Sep 17, 2010 | Car Audio & Video
Canabalized wiring job on OEM radio
You should buy a replacement harness to restore the OEM wiring, so that you can then properly plug it into an aftermarket harness that has been mated to your Kenwood radio's harness. The next buyer will appreciate that the factory radio has been replaced when you're done with the car, and you get the added benefit of not being forced to leave your Kenwood head unit in it, since it can be easily unplugged once you're at that point.
Jun 22, 2017 | OEM Systems Car Audio & Video
Kenwood KDC-MP438U reciever installed. No sound in any mode.
if its a newer truck it will most likely have a factory amp u either have to utilize or bypass
Apr 21, 2009 | Kenwood KDC-MP438U Car CD/ MP3 Player
Replacing factory radio
With that year vehicle it is recommended that you use a special harness because it has an factory amp and in order to get the proper wiring it requires the harness also if you don't use the harness you will loose your onstar and vehicle chimes and warning sounds.
Oct 08, 2008 | 2004 GMC Envoy
Problem no sound
If your KENWOOD unit is experiencing audio problems (NO Audio), but do have audio when TUNER is selected as the source, you may have problems with your installation.
NOTE: If using an external amplifier or the unit was installed using a separately purchased wiring harness for your specific vehicle, please check the following
If Using an External Amplifier
The P.CONT or REMOTE terminal on the external amplifier requires a “turn on” signal from the stereo. This terminal should be connected to the BLUE/WHITE P.CONT wire on the Kenwood harness and not the solid BLUE ANT.CONT wire.
If Using a Vehicle Specific Harness
The vehicle has a factory installed amplifier and requires a “turn on” signal from the stereo. Make sure that the BLUE/WHITE P.CONT wire is connected to the vehicle specific harness and NOT the sold BLUE ANT.CONT wire.
The solid BLUE ANT. CONT wire is used to trigger a power antenna ONLY when the tuner is selected as the source. Using this wire to “turn on” an external amplifier or factory installed amplifier will only allow it to work when TUNER is selected. Please refer to your instruction manual for proper installation. If you are not completely comfortable with installing the unit yourself, we recommend that you seek assistance from a professional installer.
Apr 10, 2008 | Kenwood KDC-MP438U Car CD/ MP3 Player
Car Audio & Video Logo
21 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
