Question about Samsung Computers & Internet
My Samsung Q70 starts beeping. The sound comes from the top left side under the keyboard. A long beep (about 1 second) every 4-5 minutes. Otherwise, it is working fine. It beeps in mute mode and even when switched off..
hughv
  • 196 Answers
SOURCE: cannot swith on
Beep codes are specific to the BIOS, but this seems to indicate a bad video card, which needs to be replaced.
See here for more codes:
http://www.pchell.com/hardware/beepcodes.shtml
Posted on Oct 11, 2007
  • 34 Answers
SOURCE: beep sound on booting
If you can remember (Or lookup what version of the BIOS your computer has then go here:-
http://www.bioscentral.com/
On the right you will see "Beep Codes", this will interpret what your laptop is trying to tell you.
The most comon is loose, or poorly fitting RAM, although the problem could be more serious.
If my advice was helpful, please vote for me!
Posted on Nov 16, 2007
  • 102 Answers
SOURCE: ibm laptop problem
The beeps are telling you something is not right.
Every beep is different and I'm not 100% on what means what.
Most likely something is not inserted right into the motherboard.
Go back and check you inserted the ram correctly, if that dosn't work try checking your cables (ide, power, etc.) and your cards (video, sound, etc.) as they might have slipped out of place when inserting the ram.
You might even have a bad/faulty part in the motherboard. Check the new ram stick and see if it works without it.
These basic troubleshooting steps should help you find the problem. If not it could be the cpu is burnt out.....the way to know this is if you unplug it, the beeps will disapeir or change completely.
Maby someone else on FixYa could tell you what the exact beep could be but I'm pretty sure its just something not plugged in right or a faulty part like I had just mentioned. Either way your computer should work fine once the problem is traced and fixed.
Posted on Dec 27, 2007
  • 41 Answers
SOURCE: Dell D800 won't boot
you have an issue of no display and as you see that u are betting the knocking sounds, could u plzz let me know are you getting these sounds when you power on the computer with the Fn and the power button, if you are able to listen to the sound but there is nodispaly then its a no video issue . in order to determine whether its an issue with the LCd you can connect an external monitor to the laptop and power on the laptop then hold the Fn key down and then press the F8 key and release both the but keys, look for the display on the m#external monitor , toggle the keys a couple of times , if you are able to see the display on the external monitor and not on the LCD , then u have to open the cover above the keyboard (hinge cover) and reseat the LCD cable, if there is still no display then the LCD has to be replaced.
Let me know once you try these steps...
all the best :)
Posted on May 01, 2008
Bajanguru
  • 7752 Answers
SOURCE: beeping
type *2767*3855#
Posted on Aug 17, 2008
What is the problem when you troubleshoots your computer and you unplug all peripherals except the CPU, motherbaord and the power supply was left but still has a strange beep
Check all data and power leads connecting to motherboard.
start up beeping sounds
1 short beep : Normal POST - system is ok
2 short beeps : POST Error - error code shown on screen
No beep : Power supply or system board problem
Continuous beep: Power supply, system board, or keyboard problem
Repeating short beeps: Power supply or system board problem
1 long, 1 short beep : System board problem
1 long, 2 short beeps: Display adapter problem (MDA, CGA)
1 long, 3 short beeps: Enhanced Graphics Adapter (EGA)
3 long beeps : keyboard card
Nov 23, 2012 | Computers & Internet
I have this acer aspire one kav 60,every time i turn it on this beep sound kip coming for few seconds
looks like your number 3 on keyboard is stuck down...the beeping would imply a keyboard error at startup......you'll need to clean thoroughly under key 3
Jul 24, 2012 | Acer Aspire One PC Notebook
Samsung microwave displays press 1-4...
The SE indicates a short in the keypad membrane, but to cure this! the whole keypad control board should be changed if effort to resolve is decided, I would also suggest checking the pricing.
Apr 16, 2012 | Samsung SMH9187ST Microwave Oven
When I turn on my dell 9200, a beeping sound starts from the CPU and nothing comes up on the screen
how many beeps you have?if three short beeps its you RAM failure..try to reinsert you RAM or replaced it a new RAM..if theres a long beep..its your video card..
Jul 27, 2011 | Dell Dimension 9200 PC Desktop
Samsung Q70 doesnot start no graphics at all , just beep sound for 3 times one long 2 short beeps
It may not be your graphics card... if it does not display video then it is not making it past POST (Power On Self Test) Implying that memory is the issue... Since you did not specify what motherboared you are using I cannot interpret that beep code for you. However I would start by Pulling the RAM out, Removing the CMOS Battery, Wait 30 seconds, then put it all back together.
Dec 05, 2010 | Samsung Computers & Internet
I need the manual of breil milano shosholoza.the model is bw0480
The crown has 3 positions.
Normal screwed down.
First pull out position.
Second pull out position.
Setting the Time:
Pull out the crown to position 3.
Rotate the crown to set the exact time.
Ensure that you are in the daytime12 hour segment by allowing the hands to pass 12 o'clock and notice if the date moved on or not.
If the date changed, then you will need to advance at least 2 hours before moving on to set the date.
If you do not need to change the date, return the crown to position 1.
Setting the Date:
DO NOT DO THIS IF THE WATCH IS BETWEEN 8pm & 2am
Pull crown to position 2.
Rotate the crown clockwise to set to the correct date.
Return the crown to position 1.
Setting the Alarm [12 hour]
Pull the crown to position 2.
Rotate the crown anti clockwise to move the alarm hand to the desired time.
To activate the alarm, press the 8 o'clock button. You will hear 2 beeps.
To deactivate the alarm, press the 8 o'clock button. You will hear 1 beep.
NB If the alarm is not cancelled while it sounds the first time, it will repeat again in 2 minutes time. The alarm sound last for 15 seconds. If the alarm time coincides with 1 beep of the countdown, the alarm function will be cancelled.
Battery EOL [End Of Life]
The Swiss ISA 8270 movement uses a 395 cell and will signify a low power state by advancing the small seconds hand 4 steps every 4 seconds.
Setting the Countdown
You can specify a countdown of between 1 and 10 minutes.
Press the 4 o'clock button to enter setting mode. You will hear 1 beep.
Press the 4 o'clock button to move the central timing hand successively to the desired countdown time.
Wait 3 seconds for the watch to automatically exit the setting mode.
You can change the duration of the countdown [except in the last minute] at any time.
e.g. If the countdown is set to 10minutes, and you now want to change the countdown to 9 minutes, press the 4 o'clock button. The hours/seconds counter sub-dial will perform one complete turn and then stop at 60, before continuing.
Activating the Countdown:
Press the 2 o'clock button to start the countdown. You will hear 2 beeps.
When the countdown begins, the hour/seconds counter sub-dial indicates the seconds with 1 step every 2 seconds, and the central timing hand indicates the minutes with 1 step being 2.4 seconds.
Countdown tone:
There are 2 beeps every minute.
in the last minute:
50 seconds=1 beep.
40 seconds=1 beep.
30 seconds=2 beeps.
20 seconds=2 beeps.
10 seconds and less=1 beep every second with zero being 1 second long beep. Timer function automatically starts.
Timer:
After countdown has finished the timer starts automatically.
The central timing hand indicates the minutes with 1 step every 12 seconds. The hour/minutes counter sub-dial indicates the hours up to a maximum of 96.
Press the 4 o'clock button to see the timer seconds [display lasts up to a minute].
Press the 4 o'clock button to see the timer hours.
The timer has a maximum time of 96 hours [4 days] after which the hour/seconds sub-dial counter will stay at 0 and the central timing hand will stay at 12.
Start/Stop Timer:
Press the 2 o'clock button to stop the timer. You will hear 1 beep.
Press the 2 o'clock button to resume the timer. You will hear 2 beeps.
Setting the Countdown & Timer:
Countdown reset:
Press the 2 o'clock button to stop the countdown. You will hear 1 beep.
Press the 4 o'clock button to reset.
Setting the Timer:
Press the 2 o'clock button to stop the timer. The hour/seconds counter sub-dial will show the elapsed hours and the central timing hand the elapsed minutes.
Press the 4 o'clock button to view the seconds elapsed on the hour/seconds counter sub-dial.
Resetting the Hands:
If the hands do not zero correctly, which might occur after a battery change or a violent shock, you can make adjustments by doing the following settings as long as the countdown is not in operation.
To correct the hour/seconds counter sub-dial, pull the crown out to position 2 and wait 1 second.
Press either the 2 or 4 o'clock button; the central timing hand will turn and stop [not necessarily at 12].
Press the 2 o'clock button to increment the hours/seconds counter sub-dial hand to position it at 60.
To correct the central timing hand, press the 4 o'clock button to increment the hand to the 12 position.
If the battery had been replaced, the central timing hand defaults to the 10 minute position. If the battery had not been replaced, the central timing hand will return to the previously set position.
Oct 05, 2010 | Watches
3 medium beeps on pc; repeating
Hi John. If you already swaped the Memory, it's the video card. I'm giving you what the beep means according to the different types of BIOS, because basically Ascent is a clone PC. I hope it helps.
(you will have to open the computer to see the BIOS type.)
BIOS AWARD
1 long beep and 2 shorts -- Video error
2 short beeps -- non-fatal error.
1 beep corto -- OK.
BIOS AMI
1 short beep -- Memory error.
2 short beeps -- ECC error.
3 short beeps -- Memory error.
4 short beeps -- change atery
5 beeps cortos -- bad processor.
6 beeps cortos -- bad keyboard.
7 beeps cortos -- video memory bad.
8 beeps cortos -- video bad.
BIOS PHOENIX
1-1-2 beeps -- Problem with cpu/motherboard.
1-1-3 beeps -- Cmos issue.
3-4-1 beeps -- Video issue.
BIOS IBM
1 short beep -- Post normal, ok!.
2 short beeps -- POST error, will show on screen.
NO beep -- CPU issue or Expansion card issue
1 long and 1 short -- motherboard error.
1 long and 2 shorts -- Video issue.
1 long and 3 shorts --EGA video issue.
3 longs -- Keyboard error.
Apr 29, 2010 | Systemax Ascent Pro A20 (988185) PC...
My pc beeped twice and nothing came
Lack of video signal is usually 1 of 3 things, Power supply (PSU), Video card or Motherboard (mobo).
Situation #1: If you get a blank screen and no sounds or movement it either indicates that the power supply unit (PSU) has failed or something on the motherboard has failed, preventing normal startup.
Situation #1A: You might get some power lights coming on and some fans spinning but the video output does not happen, usually indicates that motherboard or PSU is going out or has gone out. Occasionally it will be due to a weak (damaged) PSU.
Situation #2: If you get sounds (normal Windows startup sounds) and lights but nothing on the screen then it indicates a failed or loose video card.
Always try a different power outlet that you know is working. (Eliminate the easy stuff first!)
If it is out of warranty, try opening up the case, with the power off, of course. If you have Sit #2 and have a video card that you can reseat (take out and then put back in) try that. If it is onboard video then you may have to buy a video card for it.
Also take this time to inspect the capacitors on the motherboard (they look like tiny soda cans) and check for tops that are bulging, swelling or leaking anything. Capacitors should be perfectly flat on top. If you find these then your motherboard is bad (well technically the capacitors on your motherboard are bad). The bad caps will need replacing to fix (not a job for an amateur). If it passes the visual inspection then it may just be your power supply is bad. Notice that a bad PSU does not mean you are getting no power, just not enough to start and run the computer.
A few years ago a company stole the recipe for making capacitors and started making their own capacitors at really cheap prices. The stolen "recipe" was not complete and not correct so these caps started failing after about 2-3 years of use. Emachines, DELL and Gateway were the computer companies most affected by the bad capacitor issues, although any of the big companies could have the same problem. These bad caps also affected power supply makers.
Do you hear anything else during startup, beeps, fans or drives spinning, lights on the front or back of computer flashing or lit up? Do you hear the Windows starting sound?
Let us know more then we can troubleshoot better. Do you have the 4 diagnostic (A,B,C,D) on the rear of the machine? What is the front power light on the CPU doing?
Apr 29, 2009 | Dell Dimension 2400 PC Desktop
Latitude D600 beeps twice
that may be because of a bad connection with the harddrive thats easy to fix you just take the harddrive out and blow the connecting surface clean then it should behave normaly agian:)
Jan 04, 2009 | Dell Latitude D600 Notebook
Computers & Internet Logo
81 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
