Question about D-Link DI 514 Wireless Router (DI-514)
Want to securise my di-514 - D-Link DI 514 Wireless Router (DI-514)
    President:
  • 1,768 Answers
1. log into the router user 192.168.0.1
2. click the "home tab" then the "wireless" button on right will bring up the screen to enter
your security information.
3. enter key desired key ( write it down and save to a safe place)
4. click "enable" at the top of page
5.click apply after all information is entered
I hope this helps. Have a great day!
Posted on Oct 13, 2010
I want to change my username and password..i have wi-fi connection.and my router is from d-link.
To reset your wireless router to the default, hit the the reset button
46e1c92.jpg Whenever you want to configure your network or the DI-514, you can access the Configuration Utility by opening the web-browser and typing in the IP Address of the DI-514. The DI-514 default IP Address 192.168.0.1
· Open the web browser
· Type in the IP Address of the Access Point
Type admin in the User Name field (lower case)
Leave the Password blank
Click OK
The Setup Wizard page is the first page that appears when logging into the web-based management interface. The Setup Wizard is a utility used to quickly configure the DI-514. It will guide you through four quick and basic steps to help you connect to your ISP. You will be connected to your ISP (Internet Service Provider) and have Internet access within minutes.
If you need the entire user manual, follow this link and choose Product Manual. You can download a zip file with the manual in it.
http://www.dlink.com/products/?tab=3&pid=DI-514&rev=DI-514
Mar 12, 2010 | D-Link DI 514 Wireless Router (DI-514)
I lost CD for 514 router. I need for additional computers. Can you help?
driver.wareseeker.com/free-d-link-router-di-514/
drivers.dltube.net/download14090.html
you can download the software at either link
Nov 11, 2009 | D-Link DI 514 Wireless Router (DI-514)
How to setup pass word for a d link router di 514
there is a main reset button on the router
befor you bo anything go to you network connecting and then go to the connecting your using and write down all the ip adders befor you push teh reset button
May 11, 2009 | D-Link DI 514 Wireless Router (DI-514)
Want to use Dlink DI-514 with Qwest modem to hardwire 2 computers
Believe it or not, Actiontec modems from Qwest are setup as a router already (even though ports are missing from it). You should use a switch instead of another router. Otherwise you will have to configure the DI-514 to act as a switch rather than a router. This is done by assigning a new starting IP address into your DI-514. By default both routers use 192.168.0.1 as the default. You will have to plug the DI-514 seperately into a computer (to take it off the network) and assign a new starting IP address for the DI-514 such as 10.150.1.1 for example. Then you will be able to get it work. I would strongly recommend using a switch instead and turn the wireless on the modem itself (this is why the modem is the router). It will save you some headaches if the power goes out.
Feb 04, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
D-Link DI-514
http://support.dlink.com/faq/view.asp?prod_id=1227
Try that link it shoulkd get you going
Jan 03, 2009 | D-Link DI 514 Wireless Router (DI-514)
DI Liks DI-514
http://support.dlink.com/downloads/
Select: DI Select One: 514
This is all that is available for this router from D-Link.
http://support.dlink.com/faq/view.asp?prod_id=1513
This page probably can answer any question you have about configuring this router.
Oct 18, 2008 | D-Link DI 514 Wireless Router (DI-514)
How to connect wireless router to adsl router?
You're wanting to connect the directly connect the DI-514 to the ASDL modem to give you a wireless network, right? If so here's what you do:
Connect an ethernet line from the modem to the Internet/Wan port of your DI-514 and then you're set. I recommend you then follow the directions in the manual to setup wireless security.
If you're wanting to have your DI-514 wirelessly connect to the ASDL modem, then connect your PC to one of the LAN ports of the DI-514 and open the administrative web interface (usually located at http://192.168.0.1) and go to the wireless section and select "Wireless Client" and input the MAC of the ASDL modem's wireless interface (you can find this on the administration web interface of the ASDL modem) and you should be good to go.
Feb 10, 2008 | D-Link DI 514 Wireless Router (DI-514)
DI 514 and Skyway
if A is the skyway modem with the adress 192.168.1.1
if B is the DI 514 WAN port with the adress 192.168.1.2 and 192.168.1.1 set as gatway
and if C is your computer with the adress 192.168.2.2 and 192.168.2.1 set as gatway
and if D is the di 514 LAN port with the adress 192.168.2.1
than it works
"When I route it through the DI 514 I can access the internet but not the modem" u dont route it, u NAT it. so if u cant acces it with the right setings then try to xpoze yor computer host in DMZ seting
Nov 02, 2007 | D-Link DI 514 Wireless Router (DI-514)
D-Link DI 514 Wireless Router (DI-514) Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
