Question about Jenn-Air JFC2087HRP Side by Side Refrigerator
Ice maker not working. appears no water coming in. water dipenser is working fine in frige.
  • Jenn-Air Master
  • 4,655 Answers
Pour tap water into the ice tray if empty of cubes. Let freeze and if cubes drop then the dual water control on back of the refrigerator is most likely the problem. Click Here=> Rear of JFC2087HRP you will see part 10 in photo, that is your dual water control valve OEM Part=> 67005154
It can be bad only on ice maker side. Let me know about the ice test so we can determine which part is the problem. If you have more questions please let me know, Thanks Sea Breeze
ice maker not working. appears no water coming in. - 1ec4065.jpgSea Breeze
Posted on Oct 13, 2010
  • Karl H
    Karl H Feb 18, 2014
    All due respect to John Tripp's solution above, dated Oct 13, 2010 - this is not the solution to my problem posted on Feb 17, 2014.
Just had a new part # 241734301 installed, because the old one broke during a move. It appears to work fine although the water continues to dribble for a while after filling a glass. Also, the water will...
It seems as though the water hoses are reversed, Ice maker line and water dispenser line are probably switched, this would explain why the water comes out the door intermittently. It's probably trying to dump water into the ice tray but its coming out the door.
May 22, 2011 | Frigidaire FSC23F7D Side by Side...
Ice maker will not produce ice, no water flowing to dipenser.
Sounds like the water filter is plugged up...
Here are some basic tips for ice maker troubleshooting2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Jul 11, 2010 | Whirlpool Refrigerators
Kenmore refrigerator 71203100 ice maker does not make ice. I get water from the water dispenser inside the refrigerator, but no water in the ice maker. The metal bar used to turn the ice maker on and off...
The water inlet switch on the back lower is always the problem. It has 2 solenoids, 1 for water and 1 for ice. They never go out at the same time. Follow the water line to the frige and there it is. Turn the water off repalace the part and plug the frige back in. check for leaks and enjoy...
Mar 29, 2010 | Kenmore Refrigerators
I have a Kenmore side-by-side refrigerator and the water dipenser quit working, the ice maker works fine. Any solutions?
Check water valves on back of fridge, one is for the ice maker and other is for water dispenser. Need to get the correct and complete model number listed on front and near floor behind the fresh food door. Problem may be the water valve in back or the dispenser switch on the front. let me know and I will try to get it going for you.
Thanks, Sea Breeze
Mar 20, 2009 | Kenmore 57029 Side by Side Refrigerator
Ice maker not making ice. Water disp inside frig disp water.
the line that gives water to the ice maker, every time the water comes down it lives a drip of water that turns to ice blocking the line, get some hot water and a towel and place the hot wet towel on top of the line intel it melts the ice in side the line. it happens to my frige at list once a year. if that is not the problem the valve that supplies water tho the ice maker needs replacing, it's behind the frige at the bottom, where the line coming from the house meets the frige.
Dec 10, 2008 | GE Profile PSW26P Stainless Steel Side by...
WATER DISPENCER DOES NOT WORK, YOU CAN HEART THE MOTOR GOING BUT
first thing to do is to remove the lower back panel behind the frige and disconet one of the water lines that goes to the top back of the frige and push the switch to get water with the line of. do that to the 2 lines one at to give you water back there. if none of the lines gives you water back there 100% that plastic valve needs replacing.
Dec 09, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
yes, there is 2 lines, one for the water and the other for the ice. you can take the back lower panel behind the frige and take a look at the water line coming from the house where it connects to the frige, you can disconet the line that goes to the freezer, and put the line inside of a container of about 1 litter, and waite for about 30 minutes it at to have some water inside just enough to fill the ice maker. if you donot get any water, replace that valve.
Dec 08, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker and frige
A COMMON FAILURE FOR THE WHIRLPOOL REFRIGERATORS THAT CAUSE NO COOLING IN THE FREEZER IS A BAD RELAY ON THE COMPRESSOR.
LISTEN CLOSELY FOR ABOUT 5 MINUTES TO THE BACK OF THE REFRIGERATOR. IF YOU HEAR A CLICK AND THE COMPRESSOR HUMS AND THEN CLICKS AGAIN AND SHUTS OFF THE COMPRESSOR, THE RELAY IS MOST LIKELY BAD. ABOUT A 40 DOLLAR COMPONENT.
ALSO, CHECK THE FREEZER BACK WALL. IF IT IS FROSTED UP, THERE IS A FAILURE OF THE DEFROST CYCLE. YOU WOULD HAVE TO CHECK THREE COMPONENTS. THE DEFROST CONTROL, HEATER, AND BI-METAL.
Apr 03, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Frigidaire signaling water dispenser instead of ice maker
Sounds like the water solinoid valves are wired wrong.One activates The water dispenser.The other the ice maker.That, why every so often the water shoots out on the floor.The ice maker is telling the valve to open.
Dec 05, 2007 | Frigidaire FRS3R5EMB Side by Side...
Jenn-Air JFC2087HRP Side by Side Refrigerator Logo
154 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
