Question about Frigidaire GLEH1642DS Front Load Stacked Washer/Dryer
Dryer gives very little heat and clothes take forever to dry
  • 3 Answers
You may need to replace the heater element
Posted on Oct 13, 2010
Takes forever for the clothes to get dry. It use to take a little more than an hour for my clothes to dry but now it takes three hours or more even with a very small amont of clothes in it!
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
May 03, 2011 | Fisher and Paykel Dryers
Dryer pauses several times and takes 6 hours or more to dry it does not heat.
so it is drying clothes but is taking forever:
http://www.applianceaid.com/dryertip.html
http://www.partselect.com/dryer+wont-dry-clothes+repair.htm
so the dryer is not heating:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
these should fix the problem Good Luck Tim
Feb 19, 2011 | Danby DCD5505W Electric Dryer
My kenmore dryer heat element goes on and off. The clothes take hours to dry.
It seems to run forever If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system. Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Dec 31, 2009 | Kenmore Dryers
The Dryer runs forever and the clothes dont dry
there are two elements on the back wall of the dryer and if one goes it will still get warm but not to dry all the way and will not trigger the heat sensor to finish
Dec 12, 2009 | GE 5.8 Cu. Ft. Extra-Large Capacity...
Dryer won't heat and the timer doesn't move. It runs forever with no heat.2 different problems?
if you have timer on time dry and it doesn't move timer is probably bad, if you have it on auto dry or some say more or less the timer will not move if there is no heat
Nov 10, 2009 | Kenmore 63942 Dryer
Location of dryer cycling thermostat
The thermostat is usually on the sside of the heating element housing that runs up the back of the dryer the thermostat looks like this
http://www.appliancepartsworldwide.com/Store_Part.aspx?Id=300982
if I had the model # I could be of a little more help
Sep 14, 2009 | Estate Dryers
Dryer is heating but clothes are not drying
Try checking to see if the dryer vent is clogged.
May 07, 2009 | Kenmore 62602 Electric Dryer
Maytag dryer barely gets warm
Is your vent stopped up? Or your lint screen? Usually an element will be all out, not just a little.
Apr 13, 2009 | Dryers
Dryer comes on, dryer turns, dryer heats but does
make sure your vent is clear from dryer to outside the house.your keeping moisture in dryer and if it cant circulate the air out correctly your clothes will take forever to dry.
Mar 10, 2009 | Dryers
Extremely low drum heat but setting is on HIGH.
Electric (Kenmore - 60931) dryer takes forever (several cycles) lately to dry clothes set on high heat (actual heat in tub feels low though). There are no obstructions in the venting and the 240 volt connection is fine. The timer rotates the dial (timer motor working). Help!!!
Sep 15, 2008 | Zanussi TC7102W Electric Dryer
Frigidaire GLEH1642DS Front Load Stacked Washer/Dryer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
