Question about Canon PIXMA iP6700D InkJet Photo Printer
I have a Canon PIXMA iP6700D Photo Printer. I refill the ink cartridge but everytime i put it back into the printer it still displays low ink. is there any way i can reset it so that wont come out after i have refilled the cartridge?
  • 30 Answers
IP6700 uses chips to estimate the ink level in each cartridge. You have to either reset the cartridge chip(s) or disable the ink monitoring if you want to refill. It's easy enough to do...
hope this helps
LC
www.inkbank.com.au
Posted on Nov 12, 2010
I have a Canon iP6700D. I refill my carts. I have a resetter and use it every time. This time the printer won't recognize the magenta cart. I refilled it, reset it and replaced it as always. I...
If your printer did not good in times of reseting the cartridges do check the cartridge holder if the is some dirt inside or the terminal of your cartridge had wet by the ink when you refill the ink of your cartridges.
Aug 12, 2011 | Canon PIXMA iP6700D InkJet Photo Printer
My canon ip6700d cannot correctly detect the ink level in one of the cartridges. How can I fix that problem?
Hold down the (red) Stop/Reset button until the message disappears from the printer display.
Then clear all jobs from the print queue (select and cancel each job). Then resubmit a print job.
May 16, 2011 | Canon PIXMA iP6700D InkJet Photo Printer
Changing ink cartridges
If you have put in genuine Canon cartridges, contact Canon support for advice.
If you have refilled in any other way, your printer cannot detect ink levels. If you have used a refill kit, you might have problems if you return your printer for repair under warranty as evidence of refilling is the first thing checked for
Apr 09, 2010 | Canon Pixma iP2600 Photo InkJet Printer
After refilling cartridge, red light still blinking, shows low level ink supply - how to reset cartridge level status?
reset it all ...by keeping the on button pressed for about 20 seconds on start up....anyway ..if it has a personalized reset operation ..it is described in the manual...get a good look there ... ...most af them works like I said...but some has either reset button that have to be pressed...or double functions ones...
Dec 20, 2009 | Canon PIXMA iP6700D InkJet Photo Printer
Canon pixma mp 810
Still just an ink error, you can't refill Canon inks without either replacing the chip or resetting the chip. If you are using genuine Canon, you just have a bad cartridge and Canon will replace for 30 days.
Sep 24, 2009 | Canon PIXMA iP6700D InkJet Photo Printer
Refilled Ink cartridge but the printer says there is no Ink
you refilled or purchased a new cartridge? If you refilled ; did you do it after the printer told you it was out? The cartridge electricial would have to be reset. How to do that is a guarded secret for Canon. Buy a Canon One and replace Cartridge, would one on solution.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=257&modelid=14991
Jan 18, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Refilled ink cartridges not recognizby printer.
I fixed the problem by using original Canon ink cartridges and not getting them refilled. Apparently their chemists put a chemical in all of their inks so that only their Canon printers will recognize. It's a guarded trade secret that no one else knows about, unless it was analized. Other ink manufacturers produce ink that looks exactly as Canon ink, but that's where the similiarities end.
Nov 24, 2008 | Canon PIXMA iP6700D InkJet Photo Printer
Error U130 Cannon ink tank
it is possible that the ink chip is damage. try to buy another. or you can buy original ink to make sure the printer is ok.
Apr 16, 2008 | Canon PIXMA iP6700D InkJet Photo Printer
Problems
The Canon ink cartridges have a chip that records the amount of ink fired from the nozzle. When they are empty, cartridge is finished. I recommend buying new cartridges. Welcome to inkjet printing.
Nov 24, 2007 | Canon PIXMA iP6700D InkJet Photo Printer
Canon PIXMA  iP6700D InkJet Photo Printer Logo
348 people viewed this question
old marine
old marine
