Question about Refrigerators
We have the Bosch kgn34x60 fridge freezer and the fridge wont stay cold. The dial is turned to 5. Any ideas on what might be the problem????? had it less than ayear and the freezer is fine
  • Hillbeley Aug 10, 2008
    Fridge is cold at the bottom, the knob influences a flap behind the duct at the back og#f the fridge, I believe there is no aiflow from the frezer up to the fridge, as there appears to be no cooling plate in the fridge. Is there a fan in the freezer?
    Hillbeley
We have this model and had the same problem. It turns out that the ducts which move the cold air from the freezer to the fridge become blocked with ice. The solution was to turn the fridge off for a day or so, let it defrost completely and then turn it on again.
The bad news is that it will do this every 6 months or so... Fixable every time though
Posted on Jun 12, 2010
I have this model and am having the same problem. Bosch don't want to know as it is out of warranty.
This means that a perfectly good freezer has to be thrown away because the fridge won't work properly.
Don't buy Bosch.
Posted on Apr 26, 2010
  • taffia Jun 12, 2010
    I tried that a number of times, but got fed up of the inconvenience.
    After a number of phone calls to Bosch it seems this is a known fault and there is a modification and after waiting best part of a week for an engineer it is now fixed, hopefully for good.
    They did not do a recall as they thought 'They had all been fixed'
Fridge started working again after I cleaned the grill, then freezer stoppped, unplugged and waited now freezer is good but fridge won't stay cold. The temp says 56. Ugh! Model # is PLHS67EGSB4.
My Freezer is Cold But My Fridge is Not! - YouTube
? 1:51
www.youtube.com/watch?v=OiKCqniraM8
Nov 5, 2013 - Uploaded by Appliance Princess What to do if your refrigerator is warm, but your freezer is stillcold. ... Cleaning them is a good idea, even if it isn't the cause, because it will improve the fridge's efficiency. ... How does thefreezer fan's failure cause a fridge not to stay cold? .... How To Fix Your Fridgidaire Refrigerator (if the compressor won't ..
Sep 23, 2015 | Refrigerators
Why wont my fridge stay cool?
MAKE SURE THE FAN IN THE FREEZER IS RUNNING THATS THE ONLY WAY THE REFRIGERATOR STAYS COLD DO YOU HAVE AN ICEMAKER IF YOU DO IS IT WORKING OR A DEFROST PROBLEM ANY ICE OR FROST BUILD UP IN THE FREEZER
IF YOU SEE IT ON THE WALLS ITS FULL BEHIND THE WALLS OF THE FREEZER
Jul 11, 2014 | Frigidaire Refrigerators
I have lost my instuctions for this Bosch
Problem solved went to Currys and looked at the instruction book in there!!!!!!!
Jan 09, 2010 | Bosch KGU32124 Bottom Freezer Refrigerator
Not cold enough. freezer works but fridge wont stay cold. i can shut it off for a day and it will work for two more. after that it quits again.
It you have a frost free fridge, then what is happening is that either the defrost element or the thermostat is faulty, causing ice to build up and block off cold air circulation to the fridge. Sometimes the frost builds up around the circulation fan and ceases it up.
That is why when you turn the fridge off for a day, the frost melts and drains out the back of your fridge and so the fridge works ok for a few days until the frost build up again.
Another thing to watch out for is the defrost timer. Sometimes they fail and stick on one cycle and dont advance through. pull your fridge out. The timer is located in the back near the compressor. There is normally a small dial on it. With the fridge turned off, you can twist the dial clockwise and you will hear the timer mechanism click through the different cycles. Make small ink mark on the timer dial. Say at 12 oclock. Turn fridge on. Chech the fridge every couple of hours and see if the mark advances through and does not get stuck in one position for lengthy periods of time. The defrost cycle should normally be around 8 hours and it repeats again.
Let me know if you need more help with the defrost element or thermostat. But it is best to get an experienced repairer to change those.
Good luck
Ash
Oct 31, 2009 | Estate TT21AKXKQ / TT21AKXKT Top Freezer...
My freezer is working fine but refrigerator is not as much cold as it is suppose to be. Is there is a trip button somewhere I can check.
Could be a couple things. Turn freezer dial control to suggested setting---usually 5. turn fridge dial up. if you set the freezer dial to a higher number it will divert more air to freezer, turning down will divert more to fridge.
Clean coils in back or under fridge.
Is ice building up in freezer?
Are your door gaskets sealing?
Oct 21, 2009 | Kenmore 50522 / 50524 Side by Side...
Faulty Fridge freezer
I suspect you may have a faulty compressor! Do you notice if the compressor starts?
Feb 05, 2009 | Bosch Freezers
Digital display on LG fridge just keeps cycling options. Showed "ER" error. Any ideas on how to get it to stop? The freezer is still cold but the refrigertor isn't cold at all
Hello sewing6
Welcome,
You said,
digital display on LG fridge just keeps cycling options. Showed "ER" error. Any ideas on how to get it to stop? The freezer is still cold but the refrigerator isn't cold at all
Try turning the fridge and the freezer off at the controls.
Then turning off the breaker for the fridge for 5 minutes .
then turn the breaker back on and restart the fridge and freezer!
This should reset the system and solve your problem.
let me know how it goes.
Thank You,
Huuum
Please remember to leave a rating! Hopefully a "solved "one.
Oct 12, 2008 | LG Refrigerators
Freezer staying cold but fridge is getting hot
More likely than not there is a blockage of ice bettween the freezer and the refridgerator. most fridges work to get the freezer cold as a priority.Then the cold freezer air is circulated throughout the rest of the unit to keep the fridge cold. Thats why you may hear a fan running in the fridge unit while the compressor is not on. Unplug and open the doors to warm the inside. Look at the plastic piece bettween the two units and remove. See if there is ice build up and use a hair dryer to melt, dry area out and restart the unit by plugging back in or turning temp dial. Hope this helps.
Aug 06, 2008 | Refrigerators
Refrigerators Logo
261 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
