Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Our garage door is not opening with the wall unit or remotes. When I push the wall unit I hear a click from the ceiling unit. The door operates fine manually. The green light on the ceiling unit (the SRT button I believe) keeps blinking periodically. The wall unit has a green light that is lit (not blinking). I've tried holding the SRT button since it appears it needs reset somehow but that hasn't worked. Any suggestions?
  • Paul Bade Oct 13, 2010
    By "operates fine manually" do you mean you can pull the door open and closed using only muscle power? If so, can you see the opener mechanism moving normally? I assume this is a chain-drive system; I would expect a screw drive would not be movable manually unless the screw nut or its attachment to the door is broken.
    President:
  • 3,197 Answers
The green light on the motor unit is an LED and random flickering is normal. Your problem is most likely caused by an electrical storm or power surge. You will need to remove the logic board from the motor unit and check for burnt or missing traces on the printed circuit board especially around the small transformer. Your holding that button in will most likely have erased the memory of the unit and all your remotes will need to be programmed once you find your problem. I really suggest you call an technician at this point.
Posted on Oct 13, 2010
2 Suggested Answers
SOURCE: sears craftsman 1/2 hp garage door troubleshooting
I've got a similar problem. The green light is flashing on the unit. I can here a click when I try either the remote or wall mount switch, but no movement.
FWIW our wall switch has a lock and a light switch and I can't get the light to go on either.
The door moves freely when disconnected from the opener.
My gut tells me the logic board is fried. What I'd really like to find is some sort of trouble shooting guide - Is anyone aware of any trouble shooting information on these lifts?
Posted on Aug 24, 2008
My Chamberlain Liftmaster Formula 1 garage door (2002) has stopped working. The power is on -- light turns on when I push the wall mount button. But the remotes no longer work. The door does not move. ...
The light by the learn button may be sending a diagnostic code. See if it is flashing a number of times, pausing and then repeating. Count the flashes. Is your door stuck in the open posititon?
Jun 11, 2011 | Sears Craftsman LiftMaster Chamberlain...
Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+: when i push the wall unit i hear a click from the ...
Remove the cover from the motor unit and check the drive gear. It is a white nylon gear just in front of the motor. It may be going bad.
May 16, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have 2 liftmaster 3245. The hand held remotes were working fine then stopped. I replaced the batteries and turned of all electrical/RIF close by. Still not working. Both cars operate the doors with no...
You need to reprogram the remotes by briefly pushing the learn button on the garage door opener until it flashes once, then release the button on the garage door opener.
Now press the remote button once until you hear the garage door opener click, now press the remote button once again and the remote should be programmed to work for that garage door opener.
DO NOT press and hold the garage door opener learn button for more than 10 seconds or you'll erase all programs and have to relearn all the remotes, including your car ones.
Hope you found this very helpful and best regards.
Aug 06, 2009 | liftmaster Chamberlain Garage Door Opener...
Craftsman Garage Door Opener won't work after storm
Check to see if the trolley (the part that slides back and forth on the rail and is connected to the door) is jammed against the bolt just in front of the motor unit. If so, remove the bolt and run the door until it is closed. On the side of the motor unit there is an 'up limit' control. Turn this 3 turns in the opposite direction of the arrow printed on the cover. Be sure to replace the bolt.
Jun 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster 1/2 hp won't open
Turn the gears again by hand like you did and lower the door a couple feet. Now find the 'up limit' on the side of the motor unit and using a small screwdriver turn this about 3 turns in the opposite direction of the arrow printed on the cover. Now you can go ahead and operate the door.
May 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote not working
you will need to train (link) the remote to the garage door opener. to do this you will need to find the remote "train" button on the operator.
If you have the manual for the garge door opener this will show you where it is located.
push the train button on the operator, an LED light will start blinking. Then push one of the buttons on the remote. the LED light on the operator will stay on. push the button on the remote again and the light on the operator will turn off.
try the remote it should work now.
Apr 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Grage door blinking yellow, click and won't open with anything.
TRY RESETTING THE UNIT BY UNPLUGGING IT FOR ABOUT 5 MIN.
IF WHEN YOU PLUG IT IN THE REMOTES STILL DON'T WORK TRY TO REPROGRAM THEM.
IF STILL HAVING TROUBLE--
COUNT THE FLASHES - GOTO LIFTMASTER.COM DOWNLOAD A FREE PDF FOR A SIMILAR UNIT (THE MODEL NUMBERS ARE DIFFERENT BUT THE CODES ARE THE SAME).
HOPE THIS HELPS
Jan 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
Flashing green light on Sears garage door wall opener HBW0777 1/2
Same problem - The flashing wall button indicates the remotes are locked out. I fixed mine by pushing the green button on the back of the opener. I did nothing else , just left the LED time out.
Dec 03, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears craftsman 1/2 hp garage door troubleshooting
My garage door opener will start to close then stop and go back to the open position. If I put pressure on the door as it is closing sometimes it will close all the way and sometimes it will return to the open position. Can you help me. Thanks pbstation771@verizon.net
Aug 18, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
411 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
