Question about Dryers
I need a diagram of how to put the idler arm assembly on and how the tension should be for a General Electric / Hotpoint electric dryer
  • 3 Answers
Go to GE website enter model and get instructions
Posted on Oct 13, 2010
I've bought a drive belt for a Hotpoint 9342W Dryer but I can't work out how to fit it can you help
http://www.repairclinic.com/Dryer-Belt-Diagrams?red=Dryer-Repair-Help#DiagramL
here is a diagram on how the belt is fitted.
Move the idler arm forward to allow room for the belt and thread the new belt around the idler arm pulley and over the motor pulley. When you have it in place, slowly release the idler arm pulley to place the tension back on the belt.
After this, turn the drum around slowly by hand to make sure that the belt is in the right place, and is situated to the right side all of the way around (no twists in the belt). If the belt falls off during this, you'll need to try again. If not, you're good to go.
I hope this was helpful. I will be more than happy to help you if you need any further assistance. Good for you for fixing it by yourself.
Jul 20, 2011 | Dryers
Hi i've got a hotpoint condenser dryer it's
the belt may be off/broken, motor bad, or idler assemblage.
Here is a website with the routing of the belt the Hotpoint is( General Electric (GE) - Large Capacity Models 1970-1990):
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html
how to replace the belt:
http://www.ehow.com/how_6100255_replace-hotpoint-dryer-belt.html
May 08, 2011 | Hotpoint Dryers
How to fit a belt to a hotpoint v3d01 dryer
Instructions
Tools Needed:
Screwdriver
Hand vacuum
1. Unplug the electrical cord of the Hotpoint tumble dryer from the electrical outlet before attempting to replace the belt.
2. Pull the door open on the dryer and locate the screws on the underside of the top cover. Unfastening the screws with a screwdriver.
3. Flip the top cover back so that it rests on the rear hinges, and find the screws on the top of the front panel on the inside of the dryer cabinet.
4. Undo the screws on the top of the front panel with a screwdriver, and tilt the panel away from the dryer cabinet. Unplug the door switch connector from the metal prongs on the back of the front panel.
5. Lift the front panel up and remove it from the dryer cabinet. Set it out of the way. Locate the idler arm and motor on the bottom of the cabinet.
6. Move the idler arm forward to relieve the tension on the belt, and take the belt off the idler arm and motor pulley as well as from around the drum.
7. Place the new belt around the drum, looping it over the idler arm pulley and around the motor pulley. Move the idler arm back into place to add tension to the belt.
8. Verify that the belt is lined up correctly with no twists in it, and put the front panel back on the dryer cabinet. Plug the door switch connector into the metal prong on the back of the panel by hand.
9. Secure the front panel with the screws at the top, and flip the top cover down over the cabinet. Secure the top with the screws on the underside of the front lip.
Feb 23, 2011 | Dryers
As I was cleaning my crosley dryer modle cde600w I let the drive belt idler arm relax and the spring came off.Now how do you put it back in place?Can you HELP!!! Thank you.
The idler arm attaches to the base, and the spring attaches to the arm, and then the frame. You'll pull the arm past the belt, and then relax your tension, and transferring the tension to the belt.
--W/D--
Feb 06, 2011 | Crosley CDE6000 Electric Dryer
My dryer starts to squek real loud when it is running
The source of this noise is usualy the dryer drum drive belt.
  • Unplug the electrical cord before replacing the dryer belt.
  • 2
    Pull open the dryer door and locate the screws underneath the top lip that secure the top of the dryer.
  • 3
    Unfasten the screws holding the top on with a screwdriver and lift the top, flipping it back and resting it on the hinges.
  • 4
    Unfasten the holding the front panel on the cabinet, using a screwdriver. These screws are at the top on the inside of the panel.
  • 5
    Disconnect the door switch wires on the back of the front panel by hand, pulling the connector straight out off the electrical prongs and setting the front panel aside.
  • 6
    Locate the idler arm pulley next to the motor on the bottom of the cabinet near the back and push the idler arm forward to relieve the tension on the old belt.
  • 7
    Remove the old belt from around the idler and motor pulleys as well as from around the dryer drum and take the belt out of the dryer cabinet.
  • 8
    Place the new dryer belt around the drum in the center of the cabinet, fitting the belt inside the V-groove in the center of the drum, and lay the rest of the belt on the bottom of the cabinet near the idler pulley so you can access it easily.
  • 9
    Move the idler arm forward to allow room for the belt and thread the end of the new belt around the idler arm pulley and over the motor pulley, letting the idler arm move back to apply tension to the new belt. Check the new belt over to verify that it is lined up correctly in the V-groove on the drum and around the pulleys and that there are no twists in the belt.
  • 10
    Place the front panel back on the dryer cabinet, securing it with the screws on the top of the panel with a screwdriver, and plug the door switch wires back into the electrical prongs, pressing the switch wires on by hand on the back of the front panel.
  • 11
    Lower the top of the dryer back down onto the cabinet and secure it with the screws underneath the lip of the front panel.
  • 12
    Plug the electrical cord of the Hotpoint dryer into the electrical outlet.
  • Dec 28, 2010 | Hotpoint Dryers
    Trying to put belt on drier but its to loose what im doing wrong
    make sure the belt is around the motor pulley and the idler tension arm.it goes on like a serpintine belt on a car.pull the pulley to one side and then put the belt on the motor pulley and then release the idler pulley it should tighten up your belt.the outside of the belt should run along the inside of the idler pulley.it will almost look like a figure S.
    Nov 13, 2010 | Crosley CDE6000 Electric Dryer
    Whirlpool estate model teds780jqo how do i get the tension in the arm when changing the belt does the spring arm go above or below the pully on the motor
    Hi. The idler pulley assembly locks into two slots in front of the motor. The belt will loop through the idler pulley and the on the motor. Push the belt under the idler wheel and thread it between the wheel and the idler bracket.I hope this helps you. Please let me know if I can assistyou further.
    Vic
    Jun 13, 2009 | Whirlpool LER4634J Electric Dryer
    Idler pulley arm
    there is a certain way that the belt is supposed to loop around the tensioner and motor. this picture might help.b00f604.jpg
    Jul 19, 2008 | GE DBSR453EBWW Electric Dryer
    Hotpoint condenser dryer ctd00
    change the drive belt. evidently the belt has stretched to the point the belt tensioning device can no longer do its job. when you change the belt make a diagram of which way the belt is reaved through the tensioning device. if you don't you'll be back here asking how to arrange the belt.
    Jun 19, 2008 | Hotpoint TDC32 Electric Dryer
    I need to replace the drum bearing on my GE DDE5300 dryer
    The idler pulley controls the tension on the belt. Simply grasp the idler pulley located by the motor and pull in the direction of least restraint, then slip the belt off the idler pulley.
    Make sure the power is disconnected to the dryer. Below is a link that will assist you with exploded diagrams and parts information.
    http://www.repairclinic.com/0100_20.asp
    Good Luck!
    Dave E. (Illeagle)
    Jun 15, 2008 | Hotpoint NVL333EY Electric Dryer
    Dryers Logo
    47 people viewed this question
    Top Dryers Experts
    Dan Webster
    Dan Webster
