Question about Garden
RAINBOW RETICULATION SYSTEM - HAVE LOST INSTRUCTIONS OF HOW TO SET UP AUTOMATIC WATERING - THOUGHT I DID IT CORRECTLY BUT DIDN'T COME ON WHEN I HAD SET IT TO. ANY WEBSITE WHERE I CAN PRINT OUT INSTRUCTIONS?
  • 4 Answers
Had the same problem, and finally found the manual - http://www.thewatershed.biz/Holman_EZY_ONE_-_Manual.pdf
Posted on Dec 11, 2010
I need to find a manual for setting the Rainbow RB1 reticulation unit.
http://www.thewatershed.biz/Holman_EZY_ONE_-_Manual.pdf - had the same problem and finally found the manual!
Nov 27, 2010 | Garden
MY RAINBOW VACUUM HAS LOST SUCTION POWER AND i DON'T KNOW WHY
Your Rainbow E series has lost suction power, because you need a new hepa filter, ot your water basin gasket is messed up, or the center motor gasket is messed up or out of position.
Make sure your water basin is not cracked or broken, also.
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
May 19, 2010 | Rainbow E series Canister Wet/Dry Vacuum
I have lost the instructions and cant set the time
Try Googling (pod)(548)(manual) without parens.
Aug 04, 2017 | Watches
Click on my profile (escapement), then click on Tips and Tricks. There you will find links to all watch manuals.Rate me, please .
Mar 27, 2010 | Watches
My Rainbow has no suction
Your Rainbow E series has lost suction power, because you need a new hepa filter, or your water basin gasket is messed up, or the center motor gasket is messed up or out of position.
If it is an earlier model, everything applies, except for the filter. They do not have filters, on any of the earlier models.
Thank you,
Ralph
Jan 27, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Water leaking from out of the heppa filter
Reasons for that to happen:
a) You have tilted the vac while vacuuming
b) Used the Rainbow without separator (basket like thing on the bottom of the motor)
c) Overfilled the rainbow tank with water (may have happened when shampooing with AquaMate)
Clean and install back the separator, remove HEPA, Set the Rainbow on empty water pan (with HEPA removed) turn it on for a while so everything will dry. Install new HEPA.
You will have to get a new HEPA filter (you can find them HERE)
Good Luck,
Rocky
Mar 18, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow aqua mate II instructions
You have the vacuum and the basin, you put them together just like when you vacuum but don't put water in the basin. There is a large white container that comes with the shampooer. you fill that up with water and then you place the vacuum cleaner and the basin on top of that. Now you will need the water hose (not the one that has the gas pump hadle). Hook that in the same spot that you do for vacuuming. Then you take the shampooing handle( it will have a trigger and a little white bottle and some tubes hooked to it) the one end of it hooks to the water hose and the other end hooks to the wands. There are 2 wands that come with your shampooer. At the end of those the shampooer head will be attached. There are two separate tubes there is a thick tube ( there two tubes fused together) and a thin tube, they hook to the large white container that you fill with water. Just look and you will see where they go. Then there is a tube that hooks to the shampooer head at the bottom. The you take the little bottle and fill it with your shampoo. You should have gotten some clips to hool onto your hose so that you can keep the tubes attached to it so they aren't in the way. You should be set. I hope I helped.
Jan 27, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Garden Logo
1,598 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
