Question about Pioneer DEH-P2900MP CD Receiver /AM/FM/MP3/ CD Player
2000 oldsmobile alero 2.4l stereo wiring color codes are?
  • 625 Answers
OK A DOBLE A BATTERIE WILL HELP YOU TO IDENTIFY SPEAKERS YOU JUST APLY INTERMITANT POWER TO THE SPEAKERRS AND THEY WILL SOUND THEN YOU MARK IT AND KEEP CHECKING OTHER SPEAKERS AND DO THE SAME OR GO TO AUTOZONE.COM AND YOU SHOULLD BE HABLE TO FIN THE DIAGRAM THERE
Posted on Jun 01, 2008
I have a 2000 oldsmobile alero and I can't get sound out of my rear speakers good speakers and connection just no sound
OLDSMOBILE ALERO 2000 speakers - Sonic Electronix
www.sonicelectronix.com/oldsmobile-alero-2000-car-speakers.html
OLDSMOBILE ALERO 2000 speakers - find speakers that fit your ... sound. This size is capable of delivering exceptional mid-bass that can't be found in smaller ...
2001 Oldsmobile Alero Car Radio Stereo Audio Wiring ...
www.modifiedlife.com/2001-oldsmobile-alero-car-radio-stereo-audio-wi...
Easy Plug and Play Wiring Adapter. ... 2001 Oldsmobile Alero Car Radio Stereo Audio Wiring Diagram ... If you can't find your car audio wire diagram, car stereo wire diagram or car radio ... Right Rear Speaker Positive Wire (+): Dark Blue ... olds alero and I have replace the stock stereo and have found that the sound out put ...
Request a Oldsmobile Car Radio Stereo Wiring Diagram
Jan 21, 2016 | Oldsmobile Cars & Trucks
How do I unlock my stereo on a 2000 alero
Call the dealer and give they the vin# they will give you a code to unlock it.
Jul 29, 2013 | 2000 Oldsmobile Alero
Wiring diagram/stereo
THis could helpful... 1998 Oldsmobile Intrigue Car Stereo Radio Wiring DiagramRadio Constant 12V+ Wire: OrangeRadio Ignition Switched 12V+ Wire: YellowRadio Ground Wire: Black/WhiteRadio Illumination Dimmer Wire: Gray/BlackRadio Antenna Trigger Wire: Dark GreenRadio Amplifier Trigger Wire: N/AFront Speakers Size: 5 1/4" SpeakersFront Speakers Location: DoorsLeft Front Speaker Wire (+): TanLeft Front Speaker Wire (-): GrayRight Front Speaker Wire (+): Light GreenRight Front Speaker Wire (-): Dark GreenRear Speakers Size: 6" x 9" SpeakersRear Speakers Location: Rear DeckLeft Rear Speaker Wire (+): BrownLeft Rear Speaker Wire (-): YellowRight Rear Speaker Wire (+): Dark BlueRight Rear Speaker Wire (-): Light Blue
Hope helps.
Mar 28, 2012 | 2000 Oldsmobile Alero
Wire harness dont know how to hook up radio cause colors dont match up
If your puting in a aftermarket stereo system, they make adapters that will plug into the factory harness and have a diagram of what to hook up to your new stereo. They should have one of these at a stereo store or even auto parts or Wal Mart. I had to put one in my 89 Caravan and 88 Prelude. I got them from the local stereo store and they were about $12 bucks or so. Depends on how much your stereo place overcharges.
Hope this works for you....
Oct 16, 2009 | 2000 Oldsmobile Alero
Installing my deh 2300
Heres all the radio wiring colors for your car:
2002 Oldsmobile Alero Car Radio Stereo Audio Wiring Diagram
Car Radio Constant 12v+ Wire: Orange
Car Radio Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
Car Stereo Antenna Trigger: Dark Green
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Negative Wire (-): Light Blue
window.google_render_ad();
Jun 02, 2009 | Pioneer DEH-2300 CD Player
Where is use for radio on a 2000 alero
Turn off the car before pulling out a fuse. Find the two fuse boxes in the passenger compartment of your Oldsmobile Alero. One is on the driver's side and the other is on the passenger's side of the instrument panel.
Consult your owner's manual to find the location of the fuse you need to change. You can also find this information on the inside of the fuse box cover.
Locate the blown fuse. If it's a radio fuse in a 2000 Oldsmobile Alero, you'd find it in the slot marked "Radio Batt" in the fuse box on the passenger's side. Use the fuse puller inside of the fuse box to remove the fuse.
Check the inside wire of the fuse. A blown fuse has a burned or broken wire.
Put in a new fuse with the same rating. Verify the fuse rating against what's listed on the fuse box or owner's manual for the particular model and year in question. Click it into place and close the fuse cover. Restart you car and verify you've corrected the problem.
If the radio calls for a code: If you bought the car new then there should be writen in the manual the code for the theft lock system on the radio. Pre-owned then it might ,might not be in there. or if you don't have one at all.
Go to your nearest GM dealer and have them fix it by finding the code using the Vin #. Make sure to have them write it down for you in case this happens again.
Good luck and hope this helps
May 13, 2009 | 2000 Oldsmobile Alero
Im hooking up a pioneer radio in a 1999 alero
anytime you are installing aftermarket stereo in car you should purchase wiring harness converter which comes with schematic, but if you insist on doing it old school youll need a repair manual to show color codes on wiring or a 12 light meter but lucky for you I looked up the wiring codes online heres link:
http://www.the12volt.com/installbay/stereodetail/1690.html
Feb 25, 2009 | 1999 Oldsmobile Alero
2001 Oldsmobile Alero Speakers/Chimes
Hi!
Please check the link for the wiring info--
Alero 2001 wiring diagram
Please ask for further clarifications.
Please rate this solution as fixya if found useful.
Thanks
Rylee
Feb 24, 2009 | 2001 Oldsmobile Alero
Pioneer DEH-P2900MP CD Receiver /AM/FM/MP3/ CD Player Logo
167 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
