I have a Peavey Renown Solo Series guitar amp. It's 450 Watts. It's a great sounding amp. My problem is that now when I turn it on, the light comes on but there is no sound. This used to happen a few times in the past but what used to work was whenever I would turn up the volume up pretty loud, THEN the amp would come blasting on. So I would turn the volume down to wherever I wanted it and it would be fine. This was very rare whenever this happened since 95% of the time whenever I turned on the amp, it came on fine. Now no matter how loud I turn up the volume, it doesn't come on. I need help right away! Can anyone there help me?!
If the amp is not turning on at all (red light near the power switch is dark), the fix may be as simple as a blown fuse. With the amp unplugged, remove the head from the case. you'll see three fuses, two on the circuit board, and another connected to the wire coming through the bottom of the case from the power supply underneath. If the power supply fuse is blown, replace it with a 250v 5a fuse (there should be a label in the case with the fuse specs - double check it). I own two '83 Renown 212s and both had this issue. Yes, 160w output...and loud as hell.
Posted on Nov 19, 2011
You'll need to have the amp in for some troubleshooting. It's not easy to say what the problem is and it could be a number of things. Also, that 450 watts is the power the amp uses, not how much audio power it puts out. The Renown was originally made in a 160 watt format and on the back of it, it says "450 watts" on the left side of the back, but that is the power it uses... This is why I say you should take the amp to a shop...
Posted on Nov 25, 2010
Peavey solo series SPECIAL 112 ; Loud him , intermittently
Most of the time amplifier hum is caused by the outlet that it's plugged into, maybe no ground or there's other appliances on the same circuit causing interference? And sometimes it's as simple as a little internal feedback, certain C notes on the Guitar cause distortion with tube amps, the best fix is a $100 power conditioner like made by Monster cables or others.... hope this helps?
Feb 27, 2015 | Peavey Music
My peavey 5150 guitar amplifier turns on but does not put out sound. The light above the standby switch does not come on. I changed the fuse after it immediately powered off the first time. Now its just no...
Hi!
Unfortunatly, it's time to take it to the shop. Check the Peavey website for an authorized repair center in your area. An authorized repair shop will have better access to the parts and tech help from Peavey service.
No sense digging into the amp and getting a bad shock!
May 23, 2014 | Music
I have a peavey 700 tour series amp. When i turn it on the protect clip light comes on and there is no output to my speakers. Could you please help?
Are you an Electronics Technician? preferably with a good understanding of class H amplifiers and surface mount soldering skills. If not take it to the shop.
Dec 10, 2013 | Peavey Tour 700 Bass Guitar Amplifier Head
Peavey renown 212
If no fuses blown you probably have an issue on your +15V and -15V power supply regulators, this can be tested by checking opamps supply voltage which should be +15V at pin-8 and -15V at pin-4, let me know further.
Jun 22, 2013 | Peavey Music
How to fix a gt5 peavey rockmaster amplifier
Hi. My name is Danielle and I have a peavey rockmaster GT-5 guitar mini amp, and it can work with/without the cable. I lost the cable and I didn't need to worry because the amp still worked as long as it had good batteries. But, after about 4 months of no use of it, I put in a brand new battery and the light wouldn't turn on. I looked all over the amp to see if something was missing but I found nothing. I'm really not sure what to do because this is a very good amp and I'd hate to throw it away. Can anyone Help Me?
Mar 24, 2012 | Peavey Electronics Peavey Rockmaster...
Peavey Vypyr 75w
If you hear any difference in the sound while moving the pot and not scratching sounds while moving it then its not the pot...
If i understood the problem right, i have seen it in 2 ELKA guitar amps.
In their case it was the TL072 opamps in the preamp section the problem and i tracked it and it must occured due to no earth connection in the wall socket and as a result to the amp...
Mar 11, 2012 | Peavey Electronics Peavey Vypyr 75 -...
I have a peavey Renown 400 model 212 without speakers. What speakers should I install to replace the missing ones?
THe speakers should be a good quality and rated jointly at 1.5 times the power of the amp.
Nov 15, 2009 | Audio Players & Recorders
My amp and cable are working... but my guitar wont make sound... when i turn up the amp it makes white noise... HELP!!!
PLUG YOUR LEAD INTO AMP TURN UP JUST A LITTLE SEE IF IT BUZZES WHEN YOU TOUCH THE END OF YOUR CABLE.IF IT BUZZES THEN THE FAULT IS IN YOUR GUITAR MOST LIKELY THE ACTIVE WIRE HAS COME OFF THE INTERNAL GUITAR PLUG.
Nov 04, 2009 | Peavey Music
No sound coming out of speakers when turned on
If you get absolutely no sound, not even a pop when changing the standby switch, this probably means the rectifier OR the switch has failed. The red light just means power is getting to the power transformer... probably fuse is OK.
Sep 27, 2009 | Peavey Music
971 people viewed this question
 Grubhead
Grubhead
