Question about Garden
I have a old b&s 16h.p.twin cyl..garden tractor i have to run it with the choke pulled out,why AND how do i fix it?
  • 760 Answers
If it runs with choke pulled out it's not getting enough fuel. Either the carburetor is dirty, or you have to open the hi speed screw. Another possibility is a bad fuel float or needle valve in the carb. If doesn't drop fully it won't let enough fuel into the bowl. Buy a carburetor kit and rebuild it and clean it. Find the model number on the B&S engine to get proper kit.
Posted on Oct 13, 2010
21 hp twin briggs engine cranks runs
Try replacing your air filter
Sep 20, 2013 | Craftsman Garden
Tractor runs only when choke is pulled
A gas engine runs on a mixture of gas and air. Too much air, not enough fuel, and you have to decrease air to maintain balance.... Many things could cause this, clogged fuel filter, gas cap not venting, old/defective gas line, dirty carburetor.... If "popping" is involved, there is too much water in the gas.
Apr 13, 2012 | Sears Garden
Will only run if you hold the choke half way
It is starving for fuel. Can be partially clogged fuel filter or the carburetor needs cleaning.
May 23, 2010 | Garden
Cleaned gas and changed fuel filter. Mower only
There are a number of things that can cause this, depending on the engine fitted. Assuming a Briggs & Stratton V-twin...
Check that the carb solenoid under the float bowl is connected, has battery voltage when the ignition switch is at 'RUN', and is functional.
As a quick check, with the engne OFF, turn key to 'RUN' there should be an audiable 'click' from the carb if the solenoid is working.
After that, check that the fuel pump is delivering fuel (disconnect output, and crank engine). SHould be a good flow.
Oct 01, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Runs for 5 seconds with choke pulled;no crank without choke
check your fuel pump to see if working,, then clean or replace carb,, and do tune up on it,,, hope this help you,, good luck
Aug 12, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
MTD lawn tractor. 16 hp twin briggs straton
THIS SOUNDS LIKE A THROTTLE CABLE LINKAGE PROBLEM.WITH THE HOOD OPEN AND MOTOR RUNNING RUN YOUR THOTTLE UP AND DOWN WHILE LOOKING @ THE LEFT SIDE OF THE MOTOR TO SEE IF THE CABLE IS FROZEN IN PLACE OR BROKE OR DISCONNECTED .HOPE THIS HELPS
Jul 15, 2009 | Mtd Garden
Engine on riding lawn mower surging
Dirty air cleaner.
Clogged fuel filter.
Replace or clean both...
May 29, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
