Samsung fax/printer model scx5315f
The above said machine is perfectly okay,Today it started showing problem on the screen"OPEH HEAT ERROR"since then the functions are held.
  • 43 Answers
Your machine has a fuser unit fault and either needs a new fuser lamp or fuse, you will need a service technician to fix this fault.
Posted on Jun 02, 2008
Open heat error displayed on screen of Samsung sf650 fax
you sould replace your fuser unit. it is not heating up.
Sep 14, 2011 | Samsung SF-560 Plain Paper Laser Fax
Heat error
samsung SF-565PR laser fax machine
(low heat error)
Apr 29, 2010 | Samsung SF-565PR/XST Printer
Samsung SCX 4521F: Incoming faxes 'receiving' but fail to print
Has the main board been changed??if yes the liu board(modem) board needs replacing.
Jul 18, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Fax not receiving
if there are "empty toner"
the printer not print received fax until cartridge replacement.
May 21, 2009 | Samsung SCX-4828FN All-In-One Laser...
Wont send fax
Error 350: Under rare conditions incompatibility between the two machines may cause the remote machine to simply abandon the call.
Try these steps...
1. Press setup, then go to TOOLS.
2. press okay on TOOLS, then look for RUN FAX TEST. then press okay.
3. It will print a fax test page. Check if everything passed.
4. If it passed everything, try to press setup again, then go to ADVANCE FAX SETUP.
5. Scroll, down and look for ECM (Error correction mode), then press okay
6. Under ECM you will have to options "ON or OFF" try to choose OFF then press OKAY.
7. Now, try sending a fax.
Please let me know if the steps that i gave resolve your issue or not. So that i can still go ahead and give you another possible solution.
Thank you so much.
adonscott
Jun 29, 2008 | HP Photosmart C7280 Printer
Black vertical line appears on faxes i send and receive
Small slit of glass "scanner glass" needs to be spotlessly cleaned, open lid to left 2cm wide runs width of lid.
G'day from Oz
Dec 03, 2007 | Samsung CLX 3160fn All-In-One Printer
Samsung Fax/phone model 1600
You could try opening the feeder and clean the gray rollers with mentholated spirits and see how that helps as it just maybe the rollers are slipping slightly.
Once you have done the above take out all of the paper from the back feed and using one sheet blot the leading edge with some spirit and place back into the machine (The back of it) then try coping something there will be a paper jam and do this a couple of times. Once you have done this wipe the area dry put new paper in and then try doing a copy and the paper should feed perfectly now and the test will come when fax comes in.
I do hope this helps you
Thanks J
Oct 30, 2007 | Samsung SF-4500 Plain Paper Thermal Fax
Sending Faxes
When the last page of your document has been sent successfully, the machine beeps and returns to Standby mode. When something goes wrong while sending your fax, an error message appears on the display. If you receive an error message, press Stop/Clear to clear the message and try to send the document again. You can set your machine to print a confirmation report automatically each time sending a fax is completed. If you get the error message write it down it should always supply an error message if the fax did not go through.
Jul 25, 2007 | Samsung SCX 4521F All-In-One Laser Printer
43 people viewed this question
jasbo
jasbo
