Question about Safe T Alert Lp Propane Gas Alarm Rv Trailer
The SAfe-T-Alert is bliinking red/green and will not return to normal green and stay there. Even when I do reset and get it green only it only stays that way for 10 minutes or so and then returns to blinking red and solid green. It is 11 at night and how do I get it to stop until we can get it looked at inthe morning?
Reset Water Filter Button; Stays Red after changing filter on Frigidaire Refrigerator/SideBySide LGUS2642L
Thank you for your inquiry, John Sodt!
From what you have described your Frigidaire refrigerator's filter display is not changing back to green after the filter has been changed. This could be a miscommunication within the control panel and to clear out any miscommunications I would suggest performing a reset on your refrigerator. The best way to reset your refrigerator is to unplug the power cord for roughly ten minutes. If that does not help your issue you may want to speak with a professional technician. Good luck. -Matt
Feb 11, 2015 | Frigidaire Refrigerators
CO ALARM KEEPS GOING OFF FOR NO APPARENT REASON
Check the manufacturer's date on the alarm. There should be an expiration date, usually 5 years. You may have to buy a new unit.
Good Luck.
Aug 28, 2014 | Alert Safe-t-alert Co Alarm Direct Plug-in...
Should my green light be on at all times on my freezer and should temp be on normal
My green light stays on all the time unless I open the door and it needs to get back down to temperature. The red light will come on then and return to normal after 30 seconds to a few minutes if on a hot day. Good luck hope I could help
May 22, 2014 | Frigidaire 20.6 cu. ft. / 583 liter...
Makita bl1830 charges but stays on static red light
Chargers have been known to lie about what they are indicating. Even though you say the batteries were charged only a hanful of times, they may, in fact, have expired
Apr 03, 2013 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
First alert 9120b
Hi hislop_amand,
I know this is coming to you late yet I just seen your post and hope the following can still help you or others.
Kind Regards,
SD
FIRST ALERT Model: 9120 9120B
Normal Operation (AC Power)
Green LED ON; flashing Red LED once/ minute
No Audible Alarm
Normal Operation (DC Power - 9120B only)
Green LED OFF; Red LED flashes once/minute
No Audible Alarm
Mar 23, 2013 | First Alert SC9120B Smoke / CO Detector...
The weather/alert light stays on when got it the switch on cb, is the light supose to stay on? The light blinks when given out a weather alert, but no alarm goes off.
Normally the lights are on when close to a weather beacon and theres a warning of some kind. but i think there a light thats stays on just to let u know its on the wx band. What radio is it? cobras and galaxytypes lights are green showing that you are rx-ing a signal. some radios lights turn orange color when on the wx band.
Aug 11, 2010 | Radio Communications
Charging indicator stays red
Hmmm...is the USB cable plugged in to a powered PC? Could be cable or battery issue. Red light means that the battery is very low on juice. Return it to where you got it from if you can't solve it on your own.
you want a repair service
Oct 16, 2008 | HP iPAQ hw6965 Smartphone
My motorola H700 keeps staying red when charging
Wait, how long have you waited for it to charge? It's supposed to stay red until over 80% charge, then switch to yellow. When it is fully charged, it goes to green. When you mean it stays red when plugged in, have you waited the 2 hours?
Jul 10, 2007 | Motorola Mobility H700 Wireless Headset
Safe T Alert Lp Propane Gas Alarm Rv  Trailer Logo
138 people viewed this question
Top Camper Vehicle Parts & Accessories Experts
Jim Goldsmith
Jim Goldsmith
Mike
Will Halftowaite
Are you a Camper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
