Question about Xerox Phaser 7300DN Laser Printer
Phaser 7300 Error Code/Message
I have a Xerox Phaser 7300 service call fro Monday and the end user stated they were getting a U6 error code/message. Not sure what that is? Thanks Mark
  • Paul Cavinee Jun 01, 2008
    Thank you. I normally work HP Laserjets and know them pretty well, b ut the Xerox never worked that much on.
U6 error code on a 7300 can be casued by a faulty power supply - improper voltage to the board, etc causing the error
Posted on Aug 20, 2008
    Guru:
  • 1,342 Answers
Seems to be something to do with the Ram.
More help HERE
Posted on Jun 01, 2008
  • Georgia B
    Georgia B Jun 02, 2008
    You're welcome. Thank you for voting.
I moved my printer and now I get phaser 7300 power supply failure code u6 on start up. The printer just stops dead.
U6 is a low voltage psu failure. It may be that the power connector to the engine controller board became dislodged during the move. You can check the details in the manual which you can download here.
Oct 18, 2011 | Xerox Phaser 7300DN Laser Printer
Xerox 7300 DN color printer, I am getting an error message "Fuser Fan Failure" reference code U32. What does this mean, How do I fix this? Do you know of any people who service printers in the...
It means you need to replace the fuser rear cooling fan the part number is 116-1024-00. New it is about 100 dollars you can find a refurbished one for 35 to 40 dollars. I am sorry i dont know anyone the the dc area that services printers.
Apr 19, 2011 | Xerox Phaser 7300DN Laser Printer
What is the Xerox Phaser 8400 printer error code 07.010.43:43923? Much appreciated. Thank you.
Try this:
The printer has encountered an error state without the benefit of a code. Turn the printer off for 30 seconds, then power back on.
If the Printer Error message returns, press the i button on the printer's front panel. The actual error or fault number should be displayed. Note the error or message and search the knowledge base for the error.
Also:
Based on the problem description provided, we have determined that your printer needs service.
Please turn your printer off and use one of the methods below to make arrangements for service:
If using the local service provider website, please perform the following steps:
  1. Enter your zip code in the space provided.
  2. Choose a mileage distance. The search will locate a Service Provider within the specified range if available.
  3. Click Go. The web site will return a list of Authorized Service Providers (ASP) with their company name, address, phone number, and fax number.
Feb 12, 2011 | Xerox Phaser 8400 Laser Printer
Phaser 8400 Error Code 07.009.42:265696
Hi carlt322:
Here is your problem.
7,009.4x: PM_FAULT_HEADTILT_PARK_ ERROR
The printhead is tilted back but not in the park arms and restrained properly. This is due
to the wiper assembly not moving up far enough for the park arms to hold it.
1. Check the printhead heater wiring.
2. Check for an obstruction or damage in the process
gearbox. Ensure the gears are correctly aligned and
homed, see page 6-8. If faulty replace the process
gearbox assembly.
3. Run the Head Maintenance Clutch test, if it fails replace
the clutch.
4. Run the Wiper Drive test. If the test fails, inspect the
maintenance drive system.
5. Replace the exit assembly.
Hope this helps
Sep 25, 2009 | Xerox Phaser 8400 Laser Printer
Phaser 8560DN Printer ~ Error Message
An error code due to the print head, check the waste tray area for a spill, has the printer been moved lately? remove left cover and look for spill.
-Carl, please let me know if this helps.
Jun 25, 2009 | Xerox Phaser 8560DN Printer
Tektronix Phaser 840 Model Z840 shows error 08 001 44 215264
Check for broken Maintenance Drawer Guides, or the Printhead Cap/Wipe/Purge assembly is defective. (If it is for a Phaser 840)
Dec 05, 2008 | Xerox Phaser 8400 Laser Printer
Replace Black Imaging Unit
My advice is to throw the printer out the window!! Just a suggestion!
Ted
Jan 30, 2008 | Xerox Phaser 7300DN Laser Printer
Error message
Cause:
This message is related to the on-board SRAM on the Print Engine Control Board Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. Replaced the Print Engine Control Board,
Dec 19, 2007 | Xerox Phaser 7300DN Laser Printer
Printer error meaning
I found a couple of references to the error ?07,010.43?, it?s a generic message with lots of possible causes. Xerox?s official web site says to turn your printer off a contact their technical support. I did find one reference that said for them it turned out to be a wiper assembly stuck between the print head and the roller. I?ve never owned a Xerox printer (I?m an HP guy) so I can?t help you beyond that. Xerox?s support site for the phaser series is here: http://www.office.xerox.com/color-printers/phaser-8500-8550/sprt-enus.html
Dec 04, 2006 | Xerox Phaser 8550DP Printer
Xerox Phaser 7300DN Laser Printer Logo
465 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
