Question about Jensen XA2125 Car Audio Amplifier
I have an old Jensen XA2125 that I had removed from my car and now putting it back in. My problem is I have everything hooked up but it appears the amp is not working for some reason. No red light and no green light. Its hooked up exactly like it was when I got it. No sound, no lights. Its hooked up to my head unit with Monster RCA cables.
  • 631 Answers
SOURCE: both green and red ligt or on my jensen ka3
Generally, the power light is green and the protect light is red. If the protect light is on there could be a short in the wiring or there could be an internal fault in the amp.
Disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down (goes into protection), the amp likely has blown output transistors.
Posted on Dec 28, 2007
jerryg50
  • 1667 Answers
SOURCE: Jensen Amp and Sub
If you followed the instructions correctly, then the amp must be defective. This is sort of simple.
My generic suggestions:
You have the power, the ground, the outputs to the speakers, and then the input.
Make sure that none of the speaker wires are somehow being grounded. Make sure that nothing is shorted that feeds the speakers.
Jerry G.
Posted on May 01, 2008
  • 12 Answers
SOURCE: Jensen LXA400 Fuse Size and RCA hook up for 2 channel mode?
take it to a stereo shop. there are variables you may not be aware of when hooking up speakers to an amplifier like ohms, very important!
Posted on Dec 10, 2008
  • 11 Answers
SOURCE: Jenson a300hlx 300 watt amp
DISCONNECT THE GROUND WIRE. SAND ALL THE PAINT FROM THAT AREA AND REGROUND IT. WHAT I WOULD RECOMMEND IS DRILLING A HOLE THROUGH THAT TRUNK, SAND THE PAINT AWAY FROM WHERE THE GROUND WIRE WILL GO AND BOLT THE GROUND WIRE TO THE TRUNK BOTTOM. THE PAINT WILL CAUSE THE AMP NOT TO GET A SOLID GROUND
Posted on Feb 24, 2009
  • 149 Answers
SOURCE: similar prob.did the 12 steps on how to install
If you are running a set or a single subwoofer with the jensen amp than you will want to hook up the rca cord to the subwoofer rca connection on the back of the stereo unit-the other rca outputs are there in the event that you want to run a 2 or 4 channel amp to power the speakers that are generally located in the doors or back deck-with that set up properly you would still be able to adjust the balance and the fader just as though you were powering the speakers with the deck. Pug the free ends of the RCA cord into the input rca receptacles of the amp- the stereo now will feed a signal to the amplifier that only contains bass - good luck
Posted on May 19, 2009
Jensen XA 2100 Amp. Need High Level input plug diagram. In other words need to know what each of the 6 pins connects to.
the black wire is ground, white is + and white/black is - that's for the left side speakers and the gray is + and gray/black is - that's for the right side speakers and that hooks up to the speaker wires coming from radio to high level input plug if you need a diagram this is the website http://a248.e.akamai.net/pix.crutchfield.com/manuals/110/110xa2100.pdf and look on page 5 it will show you. please vote and leave high marks. Thank you and I hope i answered your question
Jul 30, 2010 | Jensen XA2125 Car Audio Amplifier
I'm getting power to it but the screen isn't coming on and it's not putting out any sound.
how do you know you're getting power to it? did you check for power at the conector? make positively sure you've got a good ground and that it's hooked up right. and check the fuse in the back of the radio, and in line with the wiring.
Feb 16, 2010 | Audiovox JENSEN VM8012 3" WIDESCREEN...
Jensen cd player no longer working(self-installed)
First check the wiring to the radio. You may measure the power being ok but you also need to make sure the ground connection is ok. If this is all ok it may be that you have dry solder joints on wiring socket inside the radio or a blown track or protection diode.
Sep 17, 2009 | Car Audio & Video
I have a Jensen A222HX amplifier. I want to hook a subwolder to it. How do I bridge the connection
Hello rcell66,
The Jensen A222Hx is an "old school" amp and the channels are probably not bridgeable. I'd recommend posting and/or researching your question on one of the "Car Audio" forums. Many of the members are old school trained and may even be able to locate a manual for Jensen's.
Hope this helps.
May 12, 2009 | Jensen Car Audio & Video
Jensen uv8 bypass code didn't work
no the code should work . unless jensen put a stop to the code in the newer modles.
Jan 19, 2009 | Jensen VM9510 Car DVD Player
Jensen uv8
They have it installed that way because they have signed a purchase agreement stating they will not bypass. If they do, they can lose the line.
Do this and you will never have to mess with the E Brake or any toggle ever again...:
1: Go into AM/FM mode
2: Hit "setup" on the remote control
3: Enter 543210 on the remote, listening for the beep for each number entered
4: A new menu will appear. Touch the button that has the hammer/screwdriver on it in the upper left-hand part of the screen.
5: Select Brake bypass to "ON" and hit the "X" near the bottom of the screen.
6: Use the unit wisely and above all safely. A ticket is one thing, causing a fatal accident due to negligence is another.
Jan 16, 2009 | Jensen VM9411 Car Video Player
Jensen VM9311TS wont play cd
you are probably mising to power on the factory amp from the vehicle
Nov 04, 2008 | Jensen VM9020TS Car DVD Player
How do i hook up the r.c.a to the back of VM9312
try hooking up your rem wire I.E. blue/white wire to blue wire (not to power antenna) then check ground and power wire. never hook up power wire while car is on...you will blow amp
Mar 18, 2008 | Jensen VM9510 Car DVD Player
Jensen VM9311/ UV7i wont turn on!!?
Yo, I've got the perfect solution to your problem. Pull out the head unit from your dash. Then, remove the wiring harness carefully from the unit. Now, push in the yellow power wire (even jiggle it a little) making sure it's tightly snug the small port of the wiring harness. Then, plug the harness back into the unit and try turning it on. I've found that the wires come lose easily on this unit. hit me back up at Darkintel74@aol.com.
Mar 03, 2008 | Jensen VM9510 Car DVD Player
Jensen XA2125 Car Audio Amplifier Logo
66 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
