Question about EnGenius Technologies ESR-9752 300mbps Wireless N Router With Detachable Antenna Smartnat 4-port 10
I can not access the 192.168.0.1 wizard - EnGenius Technologies ESR-9752 300mbps Wireless N Router With Detachable Antenna Smartnat 4-port 10
    Sergeant:
  • 270 Answers
Just because it is a wireless device, does not mean you are required to connect to it wirelessly. In addition, if you change settings wirelessly you might not be able to connect again, either to surf, or to correct it.
I suggest using the ethernet port on your computer and one of the ports on your router.
to test if the IP addy is good, using this command : ping 192.168.0.1
If it times out, then you (or someone else may have changed the IP address.
You could download a free copy of NETWORK MAGIC (trial version for 30 days) and it will tell you what your IPs are on your network.
The type in the proper IP to acces the wizard. If you can not access it all, then you may need to reset it and start from scratch.
Good luck and don't forget to vote.
Posted on Oct 13, 2010
Can not find the set wizard
to get to the set up wizard, you need to access the router. to access the router, you need to be securely connected to the router hardwired. after doing so. open up a browser, and type in 192.168.1.1 or www.routerlogin.net on the address bar. username is " admin " password is " password ". it would take you now to the netgear and set up wizard, where you can start configuring your router.
Sep 14, 2011 | NetGear WGR614 Wireless Router
How can i activate internet on nokia E63?
Your device can detect and connect to wireless local area networks (WLAN). Using a WLAN, you can connect your device to the internet. To use a WLAN connection, you must create an internet access point (IAP) for the WLAN. Use the access point for applications that need to connect to the internet.
Use the WLAN wizard to create an access point
1. You can access the WLAN wizard directly from your home screen's information area. Another way to get to the WLAN wizard is to select Menu > Connectivity > WLAN wizard.
2. If the search finds WLANs, you can create an internet access point - scroll to the connection, select Options > Start web browsing. If you select a secured WLAN, you will be asked to enter the relevant password. To connect to a hidden network, you must enter the correct network name (service set identifier, SSID).
3. To end the active connection, select the connection > Options and Exit. If you want to define whether you want to use the WLAN or packet data connection when starting to browse the web, you can set it so that the device always asks which access point is to be used.
Set up an access point inquiry when you open the browser
1. Select Options > Settings.
2. Select General > Access point, and from Always ask - You always get to select which access point you use.
Nov 02, 2010 | Nokia E63 Cell Phone
I dont know how to access setup wizard for cwr-854 cnet router
To access Router type that --> http://192.168.1.254 into your browsers address bar, a password & logon box should appear, The USERNAME is root The PASSWORD is 1234
Now you should be able to access wizard.
Here is a better manual.http://www.cnetusa.com/eng/Manuals/Wireless/CWR-854/CWR-854%20ver%20F%20Quick%20Install%20Guide.pdf
Feb 09, 2010 | Computers & Internet
I have problem setting up my wireless network and redirecting my wireless client to my local webpages before they can access to internet.   see this diagram below :...
you need to replace your modem with a router that is capable of running Network Address Translation. You are trying to route private IP's (192,168.x.x) over the public IP (internet) network.
Jan 31, 2010 | Microsoft Windows 2000 Professional for PC
How do i properly set up my printer to my computer so i can use it as a fax and as a phone line
I would try going thru the printer wizard. And the only way i know how to tell you to access the printer wizard is by clicking print and if your printer is not connected when you click to print something the printer wizard will be prompted and you will have access to the printer wizard
Nov 09, 2009 | Canon Office Equipment & Supplies
Cant access set up wizard for d-link DI-524UP wireless router
Here is a link to the D-Link's site based wizard:
http://support.dlink.com/emulators/di524/h_wizard.html
Mar 24, 2009 | D-Link AirPlusG DI-524UP Wireless Router
Nothing happens when I click form wizard?????
You might cancel the security wizards option during your 1st time click of "Form Wizards" of More Forms menu. To solve this problem follow this steps.
  1. In Access 2007, click the Microsoft Office Button, and then click Access Options (the office 2007 logo on your left top area of access 2007 or the Circle button on your top)
  2. Click Trust Center.
  3. Click Trust Center Settings.
  4. Click Trusted Locations.
  5. Click Add new location.
  6. In the Microsoft Office Trusted Location dialog box then click Browse.
  7. In the Browse dialog box, locate and select the folder that contains the Access database, and then click OK.
Nov 18, 2008 | Microsoft Office Professional 2007 Full...
Access 2007 forms wizard
If you run a repair install of office 2003
Jun 04, 2008 | Microsoft Office Professional 2007 Full...
Can't bring up Setup Wizard
yeah the same problem. not able to launch the wizard from the URL.
Actually i was trying to change the password for the wireless secure access and i tried typing different combinations and got in problem, then thought of doing a reset and start again the whole configuration, so i did used the reset hole and followed the instructions as listed in the document (ie like doing the configuration for first time). after restarting computer and access the http://192.168.0.1 URL, nothing happens, i'm not able to get the setup wizard. I also noticed that the LEDs are displaying properly as mentioned in the manual... now.. how to get it setup wizard....
plz help
Apr 15, 2008 | D-Link DI 514 Wireless Router (DI-514)
Unable to access the set-up wizard to install my wireless router.
just reset the router... do you know how?
there is a small hidden button on it that you must press and hold for some minutes firs with the router powered and then with the router not connected to power line... Try this at leas 2 times with and 2 time without power, then try accessing the router as if it were new... with the default pass that comes in the manual...
Mar 03, 2008 | D-Link DI-624 Air Plus XtremeG Wireless...
EnGenius Technologies ESR-9752 300mbps Wireless N Router With Detachable Antenna Smartnat 4-port 10 Logo
430 people viewed this question
Top EnGenius Computers & Internet Experts
Michael Vincent Cruz
Karen Gibson
Level 1 Expert
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
