Question about Kenmore 19001
The buttonhole function only sews the left hand side of the buttonhole and then quits. Any ideas of what the problem is. much appreciation
Pull down the button hole lever just behind the threader on the left side of the presser foot. This will stop the button hole process on the left side and turn it back up the right side.
Posted on Oct 19, 2010
Can I sew buttonholes on a 5525?
If your machine has a straight-stitch and zig-zag function, you can always sew buttonholes. It would be helpful if your machine has the ability to set the needle left-center-right, but a buttonhole can still be done even without this function. Whether or not your machine has a programmed buttonhole function will be included in the owner's manual.
How to sew buttonhole with an old machine
How to Sew Button hole tutorial
Just practice on scrap fabric before trying it on your garment.
Feb 19, 2016 | Sewing Machines
It does not have 4 steps to do a button hole and will only stitch on the right hand side when I put it on the button stitch. How do I do the end pieces and the left hand side?
You can perform all the steps of a buttonhole without the buttonhole option (ask how sewists used to do it before sewing machines offered the buttonhole option). You'll just need a machine that can zig-zag.
Making Buttonholes Without Special Feet
There are a lot of web sites and tutorial videos available.
Jan 22, 2016 | Sewing Machines
Buttonhole Husqvarna 6430. When it is supposed to sew the right side of the buttonhole it just goes back over the left side. The machine doesn't do the two buttonhole lines next to each other . An
the machine probably needs to be serviced to see why it's not making
a buttonhole and see if the gear or cam for the zig zag stitch is
worn or damaged.
Jan 30, 2013 | Husqvarna Sewing Machines
Machine only sews one side of a buttonhole
your machine may have a button hole lever that has to be pulled
down before sewing, it should be on the left hand side of the needle
if that doesn't help then the machine may need to be checked
Aug 25, 2012 | Janome Memory Craft 4900QC Mechanical...
Janome 2030 QDC How to predict whether the buttonhole (24) will start forward or backward? I power off the machine and reselect stitch 24 and move the buttonhole presser foot to the start position every...
does it sew buttonholes both ways?
My Janome 6500 always buttonholes away from me, so when it starts, it sews the near bartack, then stitches backwards down the right hand side of the buttonhole. It then comes back with little straight stiches on other side and sews the zigzag backwards on the left side, then the far bar tack. I would have thought your Janome would do the same stitch sequence.
Jul 16, 2011 | Sewing Machines
3rd step of buttonhole doesn't work
Souds like a stitch balance problem how long since the machine was serviced as the buttonhole mechanism can seize up if not used frequently.
Mar 17, 2008 | Husqvarna Daisy 310
Machine made buttonholes.
Here ya go! For 1 Step Automatic Buttonholes: 1. Place button into the buttonhole attachment. 2. Push slider to hold button securely in the slot. The button goes to the back! 3. Put button foot onto needle bar--just attach it securely. 4. Place needle thread and bobbin thread UNDER buttonhole attachment and let 4"-5" of thread trail behind it. 5. There's a lever called a Button Stop to the left of the needle bar. Give it a gentle tug and pull it down. Pull forward. Hear a click? Now the machine knows what length to STOP sewing! 6. Put foot on pedal and machine will sew barrack closest to you first. It will continue all around until it makes complete rotation of each side. 7. You must do these steps for each of your buttonholes! IMPORTANT: Make sure you set your dial for making buttonhole pattern because that "tells" machine to zig zag, and use appropriate size needle for the particular weight of your fabric. A new needle before you begin is recommended. Turn screw on needlebar to loosen screw. Hold it so it does not slip down into the feed dog area! New needle is inserted flat shank toward back of needlebar as far as it will go. Tighten screw. Did this help? Hope so!
Jimmy
Mar 03, 2008 | PfaFF Tiptronic 2030
How do i make a buttonhole on this machine?
I do not have a buttonhole foot, but I can tell you how I do it with the zig zag foot on the Singer 132Q machine.
1. Mark the spacing and size for the buttonholes with chalk or marking paper. This consists of a straight line with a perpendicular line at the top and bottom that lets you know how big to make the hole. There is probably a pattern piece to let you know what the spacing should be, and you can get the size of the hole for the top and bottom line by laying the button you are going to use on top of the line you draw with the pattern.
2. Make sure the bobbin has plenty of thread.
3. Put the zig zag foot on the machine.
4. Set the stitch size to 1 or maybe a little less. You want a tight stitch to hold the hole together.
5. Start at the top of the buttonhole with the perpendicular line barely visible in the zig zag foot. Think of it as placing the "T" made by the mark in the "T" made by the opening in the zig zag foot.
6. Set the needle pattern to #1 of the buttonhole pattern (2nd from the top). Make sure it is toward the top of the number to insure you get a wide zig zag stitch. If you are getting a narrow stitch, you may have to fiddle with it, but it will work. Stitch 4-6 times making sure the stitch is wide, and end on the left side of the stitch.
7. Change the needle pattern to #2 of the buttonhole pattern and zig zag stitch down to the bottom mark. Do not pull the fabric or you will stretch the stitch. Make sure your last stitch is on the left hand side.
8. Change the needle pattern to #3 of the buttonhole pattern (same as #1), and zig zag stitch 4-6 times ending on the right side this time. Make sure the stitches are wide.
9. Change the needle pattern to #4 of the buttonhole pattern and straight stitch back to the top mark. Be prepared to hand roll the needle the last few stitches to make sure you do not pass the top stitches you have made.
10. Change the needle pattern to #5 of the buttonhole pattern and zig zag stitch back to the bottom mark. Hand roll the last few stitches and end on the left side.
11. Raise the foot and remove the fabric. You are now ready proceed to the next buttonhole or cut the buttonhole open with a small pair of scissors or a seam ripper. Make sure you do not cut any of your stitches.
Make sure you practice on some scrap fabric of the same thickness (2 layers of fabric plus pellon) to make sure you have the size right before you sew the buttonholes on the garment.
GOOD LUCK.
Aug 28, 2007 | Singer Featherweight 132Q Mechanical...
Sewing Machines Logo
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
SewTechWayne
SewTechWayne
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
