Question about Fujitsu ScanSnap Manager
The manual says I can specify a custom file name with a counter. I set the file to "p" for page, and use a 4-digit counter. I am saving the individual pages as JPGs. The manual further says that if p0001.jpg already exists, the software will save the next file as p0002.jpg (assuming that doesn't also already exist). This is not happening. Instead, I get a pop-up informing me that the file already exists, and asking if I want to replace it. When I say "no", the file is not saved. This is a real problem, since the software also pukes if I try to process more than 100 files at a time. Thus, whenever I have a batch which consists of more than 100 pages (which is all the time), the only way I can see to work around the problem is to change the custom name for every 100-page portion of the entire batch I process.
SOURCE: Installing an application
Hi..
How do you connect to your computer?? RS232 or USB..??
First, you need to change the setting <PC Conncetion> in <Control Panel>.. change to the correct setting..
Second, you need to run <ActiveSync> on TP500 by yourself when TP500 connect to your computer..
Then you can transfer the files from PC to TP500..
Hope it useful for you!!
Best regard!!
Roscoe
Posted on Feb 20, 2008
mohanchennai
  • 490 Answers
SOURCE: pdf automatically opens, then system just hangs
I think the problem lies in your Comp or the Adobe reader. Reinstall Adobe reader, try a later version. Also run scandisk to check if the OS is okay.
S. Mohan
Posted on Jul 20, 2008
ServiTiendas
  • 44 Answers
SOURCE: Scan Snap - color/balck & white
You don't need to scan the doc again. If you have a graphics editing program (like Photoshop) you can change the mode to Grayscale and resave it. I bet you by now you probably have rescanned it anyway :)
Posted on Aug 22, 2008
  • 18 Answers
SOURCE: Bad jpg message
It can be a variety of problems, unfortunately. The images may just be truncated from the get go. Make sure all the extensions are lowercase .jpg. If they are not, OPEN them in a program, save as .jpg, close and reload them.
Do not try to just change the extension, this corrupts the image.
Also, check the size and make sure they are not too large.
For the digital picture frames, a 5x7 at 72 dpi is plenty big. Just make sure not to override the originals with the compressed images.
Then, check the name of the pictures. Remove any spaces, dashes or any other symbols. Strictly use letters.
When all else fails, delete all the images from the frame and reload them again.
How are you loading the images on the frame?
From a card, or directly from the computer?
If from a card, make sure to eject it from the computer first, don't just pull it from the reader. This can really messes it up and the images. Same goes with the frame itself.
Hope this helped.
Posted on Dec 27, 2008
  • 226 Answers
SOURCE: Scandall 21 Automatically Saves Scan As Temp Fil
go into the settings on your computer and change the setting to save all scans
Posted on Jul 20, 2009
I want to add fanfold 8.5*12 option on wep 800DX printer settings.How to done it?
This is the answer I found on the website for this printer. I do not have any knowledge of this printer other than to look for information on the Internet.
How to do the custom page setting with Windows XP
Follow below steps for custom size of page in WinXP. 1. Go to Start - setting - Printers and Faxes 2. Select the printer for which you need to set the page 3. Click on File - Select Server properties - 4. Select "Create New Form" , and name the form. 5. Change the Height and Width of the forms as per available paper size. 6. Press Apply and save the form. 7. Now you can able to see the form name in the driver setting.
Mar 06, 2014 | Microsoft Windows XP Professional
Can't download the photos from the MiCam Junior Digital Camera. Software has been correctly installed, laptop recognises camera but when try to download error message "there is a connection...
I have uploaded the installation CD here (188.81Mb): http://depositfiles.com/files/qmc5ykx6p
I have uploaded the user manual here (2.6Mb): http://www.filejumbo.com/Download/26D632AAF285B1D0
Acquiring images from a TWAIN Device PhotoImpression accepts images acquired via standard TWAIN devices. 1. Click the Get Photo button on the Main Screen, and select Camera/Scanner. A list of your TWAIN devices will appear. 2. Select your desired device from the Select Source pull-down. 3. Select the album to which you wish to link the acquired image(s). 4. Click the Acquire Options button to set your acquire parameters: a. Specify the file format for the acquired images. b. Specify the save directory for the acquired images. c. Choose whether or not to retain the original file format (for example, some cameras may save in a specific format-you can have the program convert the files to an option of your choice, or retain the original format). d. Set the file names for the incoming files. You can choose to have the program automatically name the files using the current date, or you can specify your own unique file name. 5. Click the Acquire button if you are capturing from a still camera or scanner; click the Video Camera button if you are capturing a still from a video. Follow the procedures specific to your device to import the image into PhotoImpression.
Updates for the Arcsoft application "PhotoImpression" are available from Arcsoft
If there are connection errors, that could be from:
  1. USB connection error
  2. Hardware issue
Try plugging the camera (via USB) to a different port on the computer, then acquire the pictures using the included software, or your own photo editing software that is capable of acquiring images from a TWAIN device.
Hope this helps!
Guy
Dec 31, 2010 | Cameras
Where can i buy a manual for a dmc-tz5
Can offer you free User manual from Panasonic.
DMCTZ5 DIGITAL STILL CAMERA 7899K DMCTZ4(file name)
1. Click here for the link
2. Below there is a page where you can select from 1 to 10. Click on [...] then look for page 28.
3. Then look for the Model number of your camera DMCTZ5 (file name is DMCTZ4)
To change the amount of rows per page, change the number, then press the "Enter Key". Select the model whose manual you wish to view by clicking on the File Name. To save the file to your PC, click the right mouse button on the File Name and select "Save Target As". Click on a column heading to resort the listing. Click on "Show All Rows" to display all results.
If this solutions solves you problem, please do not forget to rate my solution.
If not, then please comment back so I can help some more
Apr 05, 2010 | Panasonic DMC-TZ5 Digital Camera
Ms word does not print properly on tally 2250 printer
you need to create a forms for your specified paper size.
1.open printer and faxes in win xp.
2.file...server properties...create a new form(check)
3.type a name for forms
4.type a size in below boxes...(like 10 x 12 paper , width is 10 inch, height is 12 inch)
5.save it
6.close
7.rht click the printer...device setting tab... select a form name in the tray .
8.it will work
Feb 26, 2010 | Tally T2250 Matrix Printer
How do I scan multiple pages into one document
When Save as PDF file is selected: The Save as PDF file dialog box opens. Specify the file type, file name and destination folder.
Select from the following PDF file types:
PDF When multiple images are selected, each image is saved as a separate PDF file. PDF(Multiple Pages) Multiple images are saved in one PDF file. PDF(Add Page) Selected images are added to a specified PDF file. The images are added to the end of the PDF file. You cannot rearrange pages of the PDF file to which images are added.
Oct 01, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
PhotoShop CS3 Droplet automation
Try the following steps
  1. Choose File => Automate => Create Droplet.
  2. Specify where to save the droplet. Click Choose in the Save Droplet In section of the dialog box and navigate to the location.
  3. Select the Action Set, and then designate which action you intend to use within the Set and Action menus. (Select the action in the Actions palette before you open the dialog box to preselect these menus.
  4. Set Play options for the droplet:
    a. Override Action “Open” Commands Open commands in the action refer to the batched files, rather than to the file names specified in the action. Deselect Override Action “Open” Commands if the action was recorded to operate on open files or if the action contains Open commands for specific files that are required by the action.
    b. Include All Subfolders Processes files in subdirectories.
    c. Suppress Color Profile Warnings Turns off display of color profile messages.
    d. Suppress File Open Options Dialogs Hides File Open Options dialog boxes. This is useful when batching actions on camera raw image files. The default or previously specified settings will be used.
  5. Choose a destination for the processed files from the Destination menu:
    a. None Leaves the files open without saving changes (unless the action includes a Save command).
    b. Save And Close Saves the files in their current location, overwriting the original files.
    c. Folder Saves the processed files to another location. Click Choose to specify the destination folder.
    Note: You can record an action that saves using a specified file name and folder. If you do this and deselect Override Action “Save As” Commands, the same file is overwritten each time. If you record your Save As step in the action without specifying a file name, the droplet saves it to the same folder each time but uses the file name of the document being saved.
  6. If the action includes a Save As command, choose Override Action “Save As” Commands to make sure files are saved to the folder you specified (or to their original folder if you chose Save And Close.) To use this option, the action must contain a Save As command, whether or not it specifies a save location or file name; otherwise, no files are saved.
    Some save options are not available in the Batch command (such as JPEG compression or TIFF options). To use these options, record them in the action, then use the Override Action “Save As” Commands option to make sure that your files are saved where you specify in the Batch command.
  7. If you chose Folder as the destination, specify a file-naming convention and select file compatibility options for the processed files:
    a. For File Naming, select elements from the pop‑up menus or enter text into the fields to be combined into the default names for all files. Elements include document name, serial number or letter, file creation date, and file extension. Starting Serial Number specifies the starting number for any serial number fields. Serial letter fields always start with the letter “A” for the first file.
    b. For Compatibility, choose Windows, Mac OS, and UNIX to make file names compatible with Windows, Mac OS, and UNIX operating systems.
  8. Select an option for error processing from the Errors pop‑up menu:
    a. Stop For Errors Suspends the process until you confirm the error message.
    b. Log Errors To File Records each error in a file without stopping the process. If errors are logged to a file, a message appears after processing. To review the error file, open it in a text editor after the Batch command runs.
Give it a try.........
Jul 30, 2009 | Computers & Internet
'unable to save file. the system cannot find the path specified'
Had this same problem and just fixed it. You need to actually change the button settings in Navigator. Open MP navigator and choose One-Click, then click Button Settings. You can choose a new save destination from here. Even though you are using the software instead of the button on the device, it works.
Dec 04, 2008 | Canon PIXMA MP830 All-In-One InkJet...
I have a Stylus photo printer R1900
There are two different ways to create a custom page size within the Epson printer driver on Windows 2000 or XP. The method you need to use will vary depending on what type of driver is installed.
CREATING A CUSTOM PAPER SIZE IN SERVER PROPERTIES
This method will create a new page size accessible by all printer drivers installed in Windows.
1. Open the PRINTERS (2000) or PRINTERS and FAXES (XP) window.
2. Click on FILE, then select SERVER PROPERTIES.
3. On the FORMS tab, place a check beside CREATE A NEW FORM.
4. Input a new name for the paper size. Enter the desired height and width, following the existing format (#.##in).
5. Click SAVE or SAVE FORM to add the new form size to the list, then close SERVER PROPERTIES.
6. Right click on the printer name and left click PRINTING PREFERENCES.
7. Look for PAPER SIZE. (Depending on the driver in use, this will be found on the MAIN tab, the PAPER tab, or under the ADVANCED button). Select your custom paper size from the list.
8. Click APPLY to save this setting, or OK in Windows XP.
NOTE: If your new custom size is not available on the list of preset paper sizes, it indicates that the new size is either too large or too small for the driver in use.
CREATING A CUSTOM PAPER SIZE WITHIN THE EPSON DRIVER
This method will create a custom size within the Epson printer driver only.
1. Open the PRINTERS (2000) or PRINTERS AND FAXES (XP) window.
2. Right click your Epson printer name and left click PRINTING PREFERENCES.
3. On the MAIN or PAPER tab, select USER DEFINED from the PAPER SIZE drop down box.
4. Enter the new custom size and give it a name. Click SAVE to save the new size and OK to return to MAIN.
5. Click APPLY to save the changes (OK in Windows XP).
NOTE: this method is not available when using printer drivers resident within Windows itself. If your printer driver name ends in "ESC/P2" you will need to use the first method to add the new size in SERVER PROPERTIES.
Aug 05, 2008 | Epson Stylus Photo 2100 InkJet Printer
Frigidare model GLFU2067FW3 Deluxe temperature display flashes 'E' and set temperature every second and compressor runs continuously.
Step 1 go to http://www.frigidare.com
Step 2 click on CUSTOMER SERVICE on top of page
Step 3 go to PRODUCT MANUALS and click on DOWNLOADS
Step 4 type in MODEL NUMBER and click on search
Step 5 Access and save or print files: OWNERS GUIDE, and PARTS MANUAL. (Check in OWNERS GUIDE on pages 8-10 for basic trouble shooting.)
Step 6 save all PDF files to a new folder name it FRIGIDARE for easy availbility.
Sorry this is all the information that I have at this time.
Thank you and good luck.
Apr 27, 2008 | Frigidaire GLTF2940ES Front Load Washer
Epson stylus photo RX580
When you see the File Save Settings window, you need to select the location, name, and format of the scanned image file you want to save.
  1. In the File Save Settings window, specify the file folder in which you want to save your scanned image. Click the My Documents or My Pictures radio button (Windows XP or earlier versions), or the Documents or Pictures radio button (Windows Vista or Mac OS X).
  2. If you want to select another folder, click Other, then click Browse (Windows) or Choose (Mac OS X) and select the folder. If you want to save your image on the desktop, simply click Other.
  3. Specify a file name prefix with an alphanumeric character string. A 3-digit number is automatically added to the file name, but you can change the Start Number if you like. If you are scanning multiple images at once, each image will receive a different 3-digit number.
  4. Select a file format. Depending on the format, the Options button may be available for making detailed settings.
  5. The check boxes at the bottom of the window give you these options:
  • Overwrite any files with the same name: Select this option if you want to reuse the selected file name and location and overwrite previous files with the same names.
  • Show this dialog box before next scan: Select this option if you want the File Save Settings window to appear automatically before you scan in Home or Professional Mode. If you deselect it, you must click the File Save Settings button to open the window.
  • Open image folder after scanning: Select this option if you want Windows Explorer or the Macintosh Finder to automatically open to the folder where your scanned image is saved when Epson Scan finishes scanning.
6. Do one of the following, depending on the currently selected scan mode:
  • Home or Professional Mode: Click OK. Epson Scan starts scanning.
  • Full Auto Mode: Click OK, click OK again, then click Scan. Epson Scan starts scanning.
The scanned image is saved in the file and location you chose.
For more information click here
Nov 30, 2007 | Epson Stylus CX5400 All-In-One InkJet...
Computers & Internet Logo
89 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
