Question about Pioneer Audio Players & Recorders
Is there a phono input for the Pioneer VSX-D514? If not, how do I connect my phono? (Do I need a phono preamp?)
4 Suggested Answers
robotek
  • 1512 Answers
SOURCE: pioneer a858 amp no sound
Hi Big John
This is a nice reference series amp with a decent phono preamp stage. It is unusual to see a phono stage get damaged in this way.... but Murphy's law tells us "If it can be blown up, then someone will do it". I recommend that you do fix it. First up, perhaps check the settings for the preamp on the rear of the amp(from recollection). Be sure that you have it in moving magnet (mm) mode if you are using a MM cartridge.
Although its been a few years, My recollection is that there is a separate power supply for the phono preamp, with maybe even power regulators on on the actual preamp board. First check would be here to see if both DC rails are present for the phono Preamp stages. Most common failure here is heat stressed cracked/dry solder joints.
You need a good HiFi/Audio tech to have a look at it for you if the problems run deeper than DC supply for the preamp. Good luck. A FixYa rating is a great reward for my time to address your problem. Cheers
regards
robotek
Posted on Nov 07, 2008
SOURCE: receiver problem
Try this, it may work for you.
1.)Plug the unit into your mains voltage.
2.)Depress the enter and advanced surround buttons (on the front panel of receiver) at the same time for
at least 2 seconds, you should hear the relay tick and front panel should light up.
Posted on Dec 31, 2008
  • 118 Answers
SOURCE: insignia stereo reciever inputs stopped working
check a button on the front labeled 'straight' or 'direct'
Posted on Nov 04, 2009
How can I connect an analog turntable to my Pioneer VSX-D710S? Also, do I need a turntable with a built in pre-amp?
According to the specs there aren't any phono inputs which would have their own preamp. Everything else is line level so I'm pretty sure you'll need a preamp either between the turntable and one of the line level inputs or built into the turntable.
Mar 21, 2014 | Pioneer VSX-D710S Receiver
My pioneer pl-200 doesn't play loud enough through my pioneer vsx-521-k receiver
The PL-200 has no pre amp and your VSX-521 has no phono input. You need an RIAA preamp.
Jul 11, 2017 | Pioneer Vsx-521-k 5.1 Channel A/v Home...
App err
PDF]VSX-D414 VSX-D514 - Pioneer
www.pioneer-latin.com/downloads/xre3077a.pdf
Increase the separation between the equipment and receiver. - Connect the .....AUDIO/VIDEO MULTI-CHANNEL RECEIVER VSX-D514. RCE. VSB. MODE.
Pioneer VSX-D514 Receiver Repair Questions,... - Fixya
www.fixya.com > Forum > Audio & Video Receivers > Pioneer
Recent Pioneer VSX-D514 Receiver questions, problems & answers. Free expert DIY tips, support, troubleshooting help & repair advice for all Audio & Video ...
app err Turns on then says amp err. - Fixya
Jan 26, 2012 | Pioneer VSX-D514 Receiver
How to hook up a turntable to a pioneer vsx-1019
receivers with a PHONO input can connect a turntable easily by just connecting the white and red stereo audio cables from the turntable to the phono inputs on the receiver. receivers without a PHONO input can still connect a turntable by using a phono-preamp whose output can connect to any analog stereo input on the receiver like CD or AUX. See this webpage for more info:
http://columbiaisa.50webs.com/turntable_to_pc_hookup.htm
May 02, 2011 | Audio Players & Recorders
Turntable doesn't play at volume of other components. seems muted. Do I need to install a pre-amp in line?
"PHONO" is the only designated connection on an audio device that is literal and exclusive. Nothing but PHONO will work right on it and old-school turntables would require it to preamplify the tiny current produced by a Phono cartridge.
If your unit doesn't have a PHONO connection you will have to get a Phono Preamp to connect between the TT and any Line Level input, like Aux.
eBay always has some... http://shop.ebay.com/?_from=R40&_trksid=p3984.m570.l1311&_nkw=phono+preamp&_sacat=See-All-Categories
Apr 30, 2011 | Pioneer VSX-D812 Receiver
I have a Pioneer VSX-515 6.1 system and I am trying to hook up my phono to it. I am not sure which input to use. Right now the only input I have is my CD player.
Like many newer receivers, this model doesn't have a phono input. I guess manufacturers think nobody listens to vinyl today. You can still hook a turntable to one of the extra audio inputs on this unit, but you'll need a phono preamp. The output level from the turntable is too low to drive a "line level" input directly, and the preamp boosts and equalizes the signal so it will work properly. Radio Shack still carries a preamp; you can order online or find it in some of their stores. Many other sources are available online, and if you have a good stereo shop in your area they probably stock one. Plug the turntable to the preamp input, connect the preamp output to the receiver and that's it. You'll also need an AC outlet nearby as the preamp needs power.
Mar 21, 2011 | Audio Players & Recorders
My turntable won't work with the pioneer vsx-d608
Your old-school un-preamplified turntable requires an outboard Phono Preamp (*) to PRE-amplify and RIAA-equalize the tiny voltage signal produced by the phono cartridge. It will not work on any Line Level input like Aux or CD. What you will hear is a useless, barely audible, tinny playback.
* Like this one...
http://cgi.ebay.com/Behringer-PP400-Compact-Phono-Preamp-Preamplifier-NEW-/310288044769?pt=LH_DefaultDomain_0&hash=item483e9bd2e1
Feb 11, 2011 | Pioneer VSX-D608 Receiver
Pioneer turntable Pl-560 and Pioneer Receiver VSX-D409
No phono inputs?? You will need a phono to line level preamp to use aux input.
Nov 03, 2007 | Audio Players & Recorders
Poor sound
You need to connect most turntables to a PHONO input or buy a PHONO preamp. Many newer receivers do not have a PHONO input. The AUX port you are using would work fine for a device like a CD player, but turntables need to be amplified. You can buy an external Phono pre-amp from Radio Shack. I don't know anything about this site, but something like this device should work for you. http://www.phonopreamps.com/tc400pp.html
Jun 19, 2007 | Pioneer VSX-D711 Receiver
157 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
