Set top digital antenna,tunes in radio but not normal t.v. channels
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 317 Answers
Listen to xmRadio
Posted on Jun 01, 2008
Hello, I am currently having a problem with my Audiosonic KM0767 Standard Definition Set Top Box. When we first bought it we wired up all the plugs and it worked great. We then moved onto Foxtel...
did you switch the TV's incoming signal to digital antenna? For the cable box it was probably set to cable antenna or analog inputs, not all TV's have automatic switching for antenna feeds. My Mitsubishi has 1 digital and 1 analog antenna input and the cable box will only work through the antenna input if it's the analog antenna input and it's tuned to channel 3 or 4, -(or through a seprate HDMI, PROSCAN, SVCR,or a yellow RCA plug input)- and when the analog antenna input is selected the TV will tune all analog cable channels that the cable service offers if a box is not used. likewise the TV will not tune any channels at all if it's set to digital antenna inputs. It will tune all local channels only when set to digital antenna inputs.
Dec 26, 2010 | Televison & Video
Got it peaked and tuned and hooked up a new coax and mirror bracket and my swr is at 4. Before I did all this I had the stock coax and swr was under 2. What do I need to do to get the swr down?
The antenna needs to be tuned. The reason all of a sudden your SWR is a 4 when it used to be a 2 is, after a peak and tune, the radio is putting out more power, there for more RF energy is being reflected back into the radio. That is why the antenna has to be tuned.
It is important to tune your CB radio antenna to the proper length. The length must exactly match the wavelength of the frequency you transmit on. Or be really really close.
All Cb antenna's have a way to adjust the length of the antenna. If it's a mag mount, the metal whip can be slid in and out of a metal collar. Usually a set screw. If its a fiberglass whip, the way to tune it is on top. It either has a small metal rod with a set screw to adjust the length, or it threads in and out to adjust length.
Either type you have it will need to be adjusted for proper length. Here is how to tune the antenna to lowest SWR.
Some radios have a built in SWR meter. Some do not. If yours doesn't have an SWR meter, then you have to use an external SWR meter. Radio shack carries one, and you can find them cheap on ebay.
If you have a built in SWR meter or external, the procedure is the same:
1. Turn the radio to CH 20.(This is the center of the band.)
2. Switch the meter switch to CAL. (CAL stand for calibrate.
3. Key the radio. (Important. Do not talk while keying the radio.)
4. turn the CAL knob up until the meter hits the CAL mark.
5. Now while still keying the radio flip the meter switch to SWR.
Where the meter falls after that point is you SWR reading. If its above 3, that is real bad. 2 is not gonna kill your radio but its not the greatest. 1.5 and under is a good place to be, but the lower the better.
If your SWR is high, Here is how to find out if your antenna is too long or too short.
1. Turn to CH 1
2. Repeat SWR procedure. You must calibrate every time you do it.
3. Remember the SWR reading.
4. Turn to CH 40.
5. Again repeat SWR procedure.
6. Compare the reading between CH 1 and CH 40.
Now if the SWR is higher on channel 1 then channel 40 your antenna is too short. You must make it longer.
If the SWR is longer on channel 40 then on channel 1, then the antenna is too long, you need to make it shorter.
Make height adjustments about an eight inch at a time, and take reading each time.
once the SWR is significantly lower and the reading on channel 1 and 40 are about the same, you a about matched. At this point turn the radio to the center of the band, channel 20 and take an SWR reading.
You should now have a low SWR reading, 1.5 or under. If you are 1.5 or under, you are good to go.
If you cannot get the SWR to an appropriate level, there may be an antenna problem.
Nov 17, 2010 | Cobra 29 LTD CB Radio
I just need to know how to use it for conversations and what every turn dial means.
you need to hook this up to an antenna. If you are putting it in a car, you need a mobile antenna, if in a house, you need a base antenna. The antenna needs to be tuned for best SWR or you will damage the radio.
Starting from the left of the radio.
Knob 1. Volume/ squelch. The little knob does the volume of what you hear. Big knob squelches out static noise.
knob 2. Dynamike. This is the volume of your voice transmitted. Its how loud people hear you.
Knob 3. RF gain. This is the receive sensitivity. The higher you turn this, the further you can hear. There is almost no reason for you to have this anywhere but full.
knob 4. Delta Tune. This knob should be in the center. If you encounter some one transmitting off frequency, you can move your receive up and down frequency so you can tune that person in. It does not effect your transmit frequency.
Knob 5. CAL. This is to calibrate the meter for taking an SWR reading off the antenna.
Switches starting form the left.
Switch 1. Meter switch. S/RF - will show on the meter, Your signal going out when transmitting, and the signal coming in while receiving. SWR - will show on the meter, your SWR on that channel after you have calibrated the meter. CAL - This is used to calibrate the meter in conjunction with the CAL knob.
Switch 2. ANL - Automatic noise limiter. - This gets rid of electrical interference noise from the vehicle, or other interference sources. ANL/NB - This is the same as ANL, but with NB "noise blanker" This function blanks louder noises that may make it hard to hear people. It's kind of like an automatic squelch, but not nearly as effective as the actual squelch. Also, NB will lessen your receive in that, really low signals will be blanked out.
Switch 3. CB - the radio is in CB mode. This is the normal operation mode of the radio. You can transmit and receive as normal. PA "Public Address" - If you hook a PA speaker to the PA jack in the back, you can mount the speaker on the out side of the vehicle, and talk over it (Its loud). Also, anything you receive over the radio when not holding the mic key, will come over the PA speaker. This is useful when you are not in the vehicle, and need to hear when some one comes on the radio.
Switch 4. BRT and DIM - this is the brightness of the meter light and channel display. BRT stands for bright.
Switch 5. Normal and CH 9, When the switch is in the normal position, everything is normal, but when you flip it up to CH 9 it instantly puts you one channel 9 with out having to turn the dial. CH 9 is the international emergency channel. So it lets you go to Channel 9 quick. when you put it back to normal it will put you on the channel you were on.
Meter explanation. - You have 3 horizontal lines on the meter. the top line is your SWR (only when in SWR mode on the switch. The next one down is you Signal going out. And the bottom one is your signal coming in, in DB's. ***Also noted that part of the SWR line has a CAL )calibration mark. When you have the switch in CAL, and key the mic, you turn the CAL knob up until the needle is at CAL triangle, and then put the radio on SWR and key it. where the needle falls, on the top line is your SWR. If it is in the red your antenna is not tuned, and you can damage your radio.
HERE IS HOW TO TUNE YOUR ANTENN:
1. Turn to CH 1
4. Turn to CH 40.
Nov 12, 2010 | Cobra 29 LTD CB Radio
I have a cobra 150 gtl dx cb radio. my reception and transmition is not at peek performance. can you help me please? i have tried everything i know to do.
If this radio has been peaked and tuned already, and it is not in need of a full alignment, then it's most likely the antenna.
Your antenna is everything. You need a good antenna, and it needs to be tuned to the lowest SWR.
1. Turn to CH 1
4. Turn to CH 40.
Oct 20, 2010 | Cobra 150 GTL DX Base CB Radio
Tunning the antenna on radio shack cb trc-447
After installing the antenna, follow these steps to adjust the
standing wave ratio(SWR).
1. Turn on the CB.
2. Set S/RF/SWR/CAL to CAL.
3. Key the Mic and rotate SWR CAL so the meter points
to CAL.
4. Unkey Mic.
5. Set S/RF/SWR/CAL to SWR.
6. Key Mic again and note the actual measurement on
the SWR scale. Refer to the following table to interpret
the reading.
1:1 - 1.5 Great
1.5 - 2:1 OK
2:1 - 3:1 Not So Good
Higher than 3.1:1 Terrible
The ideal standing wave ratio (SWR) is 1:1, or a meter
reading of 1 on the SWR meter's top scale. A SWR ratio
of 1.5:1 to 2:1 is excellent for most mobile CB antenna
applications.
Check the SWR on Channel 1 and Channel 40
If the SWR is higher on 1, make the antenna longer
If the SWR is higher on 40, make the antenna shorter
Most antenna's are adjustable. Make small adjustments at a time.
Oct 10, 2009 | Radio Shack TRC-447 CB Radio
The words "weak signal" flashes on screen at different places and do not receive a picture.
seems like you are using an "off the air antenna" that receives weak signal, you may be too far from the station, go get a roof top amplifier antenna or subscribe to digital service from cable, satellite or at&t uverse. If you think your antenna is getting good signal, try to rescan your tv for available channel. Make sure your TV set up is correct, if you are using Off the air signal, your setting should be set at "Antenna or off the air", then rescan your TV. Normally on Satellite or cable box, you just watch it on video channel or component input, if you are using HDMI then tune to HDMI channel.
Check your connection to make sure they are making good contact. If you can post your set up, I can better solve your problem.
For a resource on "off the air" antenna, go to www.antennaweb.org for help.
Aug 16, 2009 | Sceptre X32BV-Naga 32 in. LCD TV
Problem with tuning digital channel
I would believe from what you said, you have solved your problem. You will need a UHF antenna to receive the signal. Walmart or Radio Shack has a great amplified antenna that will work for you.
Mike
Mar 22, 2009 | Televison & Video
No antenna lite when transmitting
Antenna light should be a warning indicator for high VSWR..... simple rule of thumb for CB antenna.... the lower the frequency "channel" the longer the antenna length, higher the frequency "channel" the shorter the antenna length. Your vehicle is a ground plane, where you mount the antenna will also affect its operation and tuning. A properly tuned antenna will have lower reflection on the midband channels and gradually rise as you near the upper and lower end of the band. Some base loaded antennas will be noticably narrow in bandwidth, if you have that problem then tune it for the channel you use most!
K40 has always been good for easy tuning and band coverage, center it on the vehicle top for good omni coverage!
PS... always make sure your connectors are secure, a loose shield will ruin your day when adjusting SWR!
Dec 20, 2008 | Cobra 29 LTD CB Radio
Xm2go direct entry tuning problem
You have it set on a preset mode now. On the unit or the remote control press the "pre/dir" button a few times until you see the word "DIRECT" at the top left of the screen next to the antenna strength. From "direct" you can then key in the channel numbers directly to go to them.
Nov 15, 2008 | Delphi MyFi SA10113 XM Radio Receiver with...
High swr ch. 1- 5 and ch. 40 - 5
This is a common problem in CB's. You can either get the radio tuned properly or tune the antenna. Sometimes the CB will put out more power on a channel than is needed and this could end up in a damaged radio. You can get the radio tuned to prevent the RADIO from high SWR, or you can tune the ANTENNA so tha antenna will better suit your CB's power.
Hope this helps!
Jun 06, 2008 | Cobra 29 LTD CB Radio
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
