Question about GE MiniCam Pro HO98067 Webcam
Dropping Frames & No Sound
My web cam says as it is capturing, (Dropped Frames:xx) at he bottom. How do i mak this stop? also, It doesnt' capture sound in my videos but functions well as a microphone and camera in my video chats. Please Help!
    President:
  • 8,637 Answers
Normal 0 Go to Control Panel and Click on Sounds, Clickon Audio, then Click on the Microphone. Then Click on the dropdown and select Camera Microphone.
Click OK and it should work.
Hope this helps. Bud
Posted on Feb 28, 2009
Video recording on my laptop
Cause you did not specified your problem exactly ..I will refer about video capturing in general using the web camera and a laptop ..No matter if the camera is built in or external the procedure is the same...Open the AMcap..program in start menu / all program s..This is the program usually present when you install a web cam driver..and when you open it the camera will open a window for capturing ..If it shows nothing use the setings to enable video and audio and also the preview... This will make you an idea about the quality ..After that all you have to do is open the capture using the start capture function in options or so ..and stop them ...when you stop ..usually it asks to save the file in a location ...You may also be asked when you start to assign a size for the file ..
There is a better way to make a capture and this is using a capture program ..and I will recommend the windows movie maker...Itis present in all windows..and has a capture from device feature..and you have the editor advantage with i t..and the fact that will capture from other devices than web cam alone .too..so you can increase the quality as well ..
Please ask if you have any future question s..
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Aug 25, 2011 | Compaq Presario CQ50-215NR Notebook
Sony DCR-TRV19: New capture problem
Hello, please try with changing the compression data rate. Best regards, Arpi
Aug 19, 2007 | Sony Handycam DCR-TRV19 Mini DV Digital...
Dropping frames during capture with Studio 12 Ultimate for Windows Vista
Hello , rozkr
This means the video quality settings are to high for your machine .
Reduce quality . Issue should be solved but image will be less sharp .
Best results for capturing video movies or tv programs are obtained with a stand alone DVD or Blu Ray recorder .
Regards ,
fanaudi
Mar 13, 2011 | Pinnacle Studio Plus 12 for PC
Hi, I am having great difficulty capturing video, frames are dropping continually plus there is no footage display on the monitor window. Footage allready within the program plays back OK. Any help that...
Hello bazmaz
You need a very powerfull computer to capture and edit video , at least a Pentium 4 at 3GHz , 2 GB RAM . You will still probably loose frames in High Quality mode , meaning a recent Intel 7 series will give the best results .
I have myself experienced that the best results are obtained with a stand alone DVD recorder , preferably with a HD included . This is really the best way .
Regards,
fanaudi
Mar 05, 2011 | VideoLabs (A02105) Video Capture
Delay in video. is there a way to fix this? Is thi sdone through video filter/ frame rate? tks
hi,
Some of the cheaper web cams are only capturing 15 frames per second (FPS) or less, whereas better web cams can capture 30 FPS and a larger picture too.Visit the website of the manufacturer of your webcam and see the details of that camera. It's possible you can increase the speed some through your camera settings. Look for your camera's icon in your Control Panel or in your Device Manager section and check your settings.just needed to change fps and the back lighting. <3
thank you for using fixya,rate my answer
vijay
Oct 01, 2009 | Ezonics EZCam III Webcam
I just installed driver for my Pleomax 2100 chat cam but pc doesnt recongnize it... it says i dont have a video capture device plugged in my pc
you download only the webcam software, not the video capture device so go to the web site and i think there u will find a free web cam capturing software.. n enjoy
www.softpedia.com
shafky
Jun 20, 2009 | Computers & Internet
Capture
We do recommend to capture in your Internal Hard driver first then transfer it later to your external hard drive. To avoid any eperience like video and audio is not sync or dropping frames.
Feb 07, 2009 | Pinnacle Dazzle DVD Recorder
Looking for Manual or Description for Intel cs431 camera.
20717861-177x150-0-0_intel+cs431.jpg Intel Pro Video PC Camera CS431 Web Cam Consumer Rating: Be the first one to write a review on this product Information: Compare prices at 1 store Manufacturer: Intel - See Site Product Details and Features Key Features Web Camera Type Personal Web Camera Image Sensor Type CCD Interface Type grayquestion.gif USB Video Capture Resolution grayquestion.gif 640 x 480 Digital Video Capture Speed 30 frames per second Miscellaneous Compatibility grayquestion.gif PC Product ID 20717861 Compare stores & prices http://www.shopping.com/xPF-Intel-CS431
Jan 02, 2009 | Intel Easy PC Camera Webcam
Dropped frames during capture from camcorder
Firewire cards are quite cheap, under $20, replace the card. If you still have problems then it is most likely with the camcorder.
Jun 05, 2008 | Canon ZR830 Mini DV Digital Camcorder
GE MiniCam Pro HO98067 Webcam Logo
74 people viewed this question
Top GE Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Are you a GE Computer and Internet Expert? Answer questions, earn points and help others
