Question about GE (PSS26MSRSS) Side by Side Refrigerator
The compressor makes a big clunk clunk sound when it shuts off
  • GE Master
  • 43,501 Answers
The compressor motor mount is broken and that allows the compressor to flop around and clunk when shutting down.
That also allows it to twist and turn as it starts...
this will have to be fixed before the refrigerant piping breaks...
heatman101
Posted on Oct 13, 2010
3 Suggested Answers
  • 107 Answers
SOURCE: Hotpoint fridge makes clunk-clunk-clunk noise when it shuts off
You need a new compressor. Probably time for a new frig.
Posted on Nov 19, 2011
  • 235 Answers
SOURCE: my refrigerator makes a clunking sound whenthe
Condenser fan might be hitting the cardboard panel or the compressor is loose at the base.
Posted on Jul 05, 2009
Nov 18, 2011 | Hotpoint Refrigerators
We have an 11 year old fisher-paykel fridge .For past 6 months several times a day it makes a loud knocking noise
If this noise happens when the compressor turns on and shuts off it is called a compressor knock. All the internal workings of the compressor are supported by springs, over time the springs wear out and become weak. When the compressor stops or starts the tourq causes the internal parts to hit aginst the casing of the compressor. Sounds like a clunk clunk clunk noise. If you can deal with the noise do not go out and replace the compressor cause it will work just fine like that.
Sep 01, 2011 | Refrigerators
I have a 1995 24.5 cu. ft. GE Profile refrigerator. When it shuts off there is a loud clunk. I think it could be the compressor turning off. Other than that it seems to be working fine. Is this a serious...
The compressor is sitting on springs inside a metal case. When it stops, the centrifical force is absorbed by these springs. If one or more springs become weak or break, the compressor hits against the outer case a time or two. (CLUNK CLUNK clunk) There is really nothing you can do about it, short of replacing the compressor. (read big bucks) NOTE: If you take a new compressor and give it a shake, you will hear the same clunk. If the noise is really bothering you, I'd say after 15 years, it's time to move that refrig to the basement and get a new energy star model for your kitchen. (the old one most likely has several more years worth of clunking before it truely dies)
Sep 25, 2010 | GE Refrigerators
My Kenmore refrigerator is making a loud noise when running and when it shuts off it makes a loud clunking noise. Also, it is running about every 10 minutes. The refrigerator is 7 years old.
it sounds like the compressor insides are loose and you will be needing a new compressor, but just check and make sure the rubber mounting feet on the outer compressor base where its mounted to the refrigerator base are all tight and the rubber shocks are all good
Nov 17, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
My refrigerator is about 15 years old and has made a clunking noise when it shuts off since I moved into my home many years ago, but has always kept food cold/frozen. Recently, the clunk noise is getting a...
Oct 12, 2009 | Refrigerators
A matallic "clunk" when compressor stops
Compressor is the sound you hear and it sound as if it is about to bite the big one. The sound is the piston hitting the top of the housing. Hope this helps Good luck on your repairs
Dave
Sep 15, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Kenmore fridge, about 8 years old, making noise
The compressor on your fridge is mounted on rubber grametts and inside the dome the internal parts the do the pumping of the refrigerant are mounted on springs. When a compressor gets old some people complain about two much vibrating, this could be the rubber grommets the support the compressor. When one of the support springs inside the compressor is broken it will have a distinct rapping sound when the compressor shuts off. There isn`t anything you can do about this, short of replacing the compressor. It will eventually get worse untill something is seriously broken inside the compressor and the compressor will die. You may want to consider replacing the compressor now or purchase a new fridge. You will need to consider the cost of both and the age of the fridge" Is it worth repairing?". You can actualy find a repair company in your area from this site if you like, and compare the costs.I hope I have helped explained the problem well enough for you. I will help you as much as I can.
Nov 15, 2008 | Refrigerators
Freezer noise
clunk comes from the compressor - possibly dismounted or sometimes assembly inside hits casing on switch off or switch on. no cure except replace compressor
Jun 19, 2008 | Kenmore Freezers
GE (PSS26MSRSS) Side by Side Refrigerator Logo
574 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
