Most likely one of the things that the belt drives is frozen. Check that your water pump, power steering pump, alternator, etc all turn without the belt.
First you need to remove the serpintine belt or alternator belt. If it is a serpintine locate the tension pully(the one that doesn't look like it does anything) place a wrench over the pully bolt and pull while removing the belt. Most generaly all alternators have two bolts holding them in. Remove both bolts. and remove alternator on some vehicles you need to remove the top engine mounts to remove the acctual alternator. make sure you if you do this you put a jack under the bngine block. NEVER ON THE OIL PAN. After that simply remove the old alternator and replace it with the new one reinstall the serpintine belt as instructed on either the underside of your hood or where the hood latch is.
Look at the pullies to see if they are smooth or if they have lines on then. The back side of the belt the ( smooth side) goes against the smooth pullies.The side with lines on it goes to the other pullies. Some vehicles have the diagran in the engine compartment. Under the hood or by the top of the radiater.
You shouldn't need to most of the time all you need is a 15mm wrench. Use it by turning the spring tightener inward toward the center of the motor than the belt should come off. Also when you take it off make sure you know how the belt goes around the pulleys so everything will work together like normal. when putting the belt on you should use the wrench to turn the tightener back inward and slip the belt back on and make sure it looks just like the old one when its on.
