Question about Dryers
Dryer just shut down in the middle of a load. the top push switch appears to be working, the breaker is not tripped and the motor was replaced about a year ago. also the timer still runs by itself but does not buzz at the end. could the problem be a sensor ?
  • Dryers Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Oct 13, 2010
Dryer doesn't start
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=sTRP6kHqAFs
Mar 07, 2015 | Dryers
Dryer blows circuit breaker after running 10-20 minutes.
indicates problem motor , overheating in the wiring or excessive loads in the drier
Jun 07, 2017 | Kenmore Dryers
Our dryer stopped working in the middle of a load. Now when I press the start button the timer does nothing but click. I am not sure but I thought it might be the push start button was faulty. Any ideas?
  • Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
  • If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
  • Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Hope this will fix your problem for sure.
May 08, 2010 | Kenmore 64892 Electric Dryer
Breaker keeps tripping when I use Amana NED5500TQ electric dryer.
Heating element or motor. Usually heating element. Replace limit switch (inside dryer) during repair. Limit switch should shut off before breaker if working correctly.
After repair clean or replace plug/wire. Inspect or replace receptacle in wall.
Sep 28, 2009 | Amana NED5500TQ Electric Dryer
Whirl pool dryer LEC9000PW0 will not turn on
Has a household fuse blown or has a circuit breaker tripped?
There may be 2 household fuses or circuit breakers for the dryer. Make sure both fuses are intact and tight, or that both circuit breakers have not tripped. Replace the fuse(s) or reset the circuit breaker(s). If the problem continues, call an electrician.
Is the correct power supply available? (Electric dryers only)
Electric dryers require 240-volt power supply. Check with a qualified electrician.
Is the dryer door firmly closed?
Your dryer door may not be fully closed. It may look shut, but may not be latched. Push on the door to engage the latch or latches. Some models have an upper and lower latch. Both latches must be secure for the dryer to run.
Was the Start, Push to Start or Hold to Start button firmly pressed?
Large loads may require the Start, Push to Start, or Hold to Start button to be pressed and held for two to five seconds.
Is the Cycle Control knob set on a Sensor Dry or Timed Dry cycle? (on some models)
The Cycle Control knob must be set in a Automatic Dry or AccudryTM or Timed Dry cycle. The dryer will not start if set on the Wrinkle ShieldTM option.
Is Controls Locked status light on? (on some models)
Press and hold the Cycle Signal button for three seconds. This will turn off the Controls Locked feature.
Did you recently install a power supply cord on the dryer? (Electric dryers only)
The power supply cord may be incorrectly installed. If the power cord is incorrectly installed, the dryer may not start or heat. Review the Installation Instructions to check that the power supply cord is properly installed.
Dec 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore dryer stopped working, start button does nothing
hi thanks for the question i would check the thermal fuse at the back remove back panel . by the air duct theres a small thermal fuse with 2 smaller blue wires to it check that it does cause this thanks appliance doc
Sep 13, 2008 | Maytag PYE2300AY Electric Dryer
Dryer hums when start switch is turned
you don't have to "pop" the top off the dryer. the only thing you can do to possibly solve this problem without a professional is to:
  • tape down the door switch with strong tape, or have someone else hold it down.
  • physically turn the tub inside the dryer while pushing the start switch.
  • this will hopefully loosen whatever has the motor stuck.
if this does not work then the motor in the dryer might be bad or going bad, especially if a burning smell is present when you hear the humming sound.
Aug 01, 2008 | Hotpoint NVL333EY Electric Dryer
Dryer
I WOULD CHECK DOOR SWITCH FIRST
Jan 31, 2008 | Frigidaire GLGT1142CS Top Load Stacked...
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
