Question about KitchenAid KGST307 Gas Kitchen Range
Ran self cleaning oven now the door will not open and all the electric will not work.. thank you
Inside door gasket on my gas cooking stove is burning. WHAT CAN BE THE CAUSE OF THIS ? Is the flame on the oven too high and if so can I lower it?
Posted on Mar 27, 2011
  • KitchenAid Master
  • 43,501 Answers
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Posted on Oct 13, 2010
We used the self cleaning option and now we cannot get the oven door open. The lever is stuck in lock mode. Can you give suggestion?
IF you can locate the model number tag (bottom left of door opening) you can look up the manual at www.geappliances.com
The only button on your stove that should make the door lock would be the clean button (self clean model) if that is pressed simply hit the clear/off or cancel key and wait for the door to unlock.
IF the self clean option ran for an hour or so, you will have to wait for the oven to cool down before the lock can unlock (safety feature)
Thank you and thanks for using fixya
Sep 29, 2010 | Jenn-Air JGW8130A Electric Single Oven
How do we unlock the oven door! Accidentally pushed a button in front. We have no manual or SS#. Oven was in house when we bought it. We unplugged it to turn off and was able to open the door. Please...
The only button on your stove that should make the door lock would be the clean button (self clean model) if that is pressed simply hit the clear/off or cancel key and wait for the door to unlock. IF the self clean option ran for an hour or so, you will have to wait for the oven to cool down before the lock can un-lock (safety feature).
Good luck with this!!
Aug 18, 2010 | GE Profile JTP18 Electric Single Oven
Touch pad will not unlock after running self clean cycle,
ran the SCC and the oven door unlocked when completed but the touchpad did not. Can;t use over at all, top of stove works fine. None of the bottons for the oven works. still says self clean completed, will not go away, can't use oven at all.
Dec 14, 2009 | KitchenAid KESC307 Electric Kitchen Range
Can't disengage oven door lock
Lock disengaged on its own after a day. Oven is now clean, everything working properly.
Jul 06, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
How much time to leave on self cleaning...clock does no work
Depending on the condition of the oven, it could take up to 4 hours.
I ran the auto self clean on my oven last week for the first time and it set automatically for 3 1/2 hours. (It stunk, but it worked.)
A couple things to remember is: (1) Make sure you do not turn the light on inside the oven. The clean cycle should disable it. (2) Lock the door if it does not lock itself. (3) Do not open the door during the clean cycle.
Remember the self cleaning temperature is extremely high. Do not allow children in the area while doing it.
Dec 15, 2008 | GE Profile JTP18 Electric Single Oven
Self Cleaning
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 03, 2008 | Kenmore 94220 / 94221 / 94222 / 94224 /...
Oven door won't open after self cleaning
it hapen to me i activated the self cleaning gently hit the top of door and turn the self cleaner off the latch came off was able to use the oven did not used cleaner again clean it manuelly did not whant to spend the money
Jan 16, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
1990 Kenmore Self Cleaning 24in Elec Double Oven - Top Oven door does not open
hit cancel or stop clear see if that helps if that doesnt work start self clean then stop it
Jul 29, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
KitchenAid KGST307 Gas Kitchen Range Logo
102 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
