I purchased the lux tx9000ts and the 4 wires i have are red,blue,green,white how do i install plz help or the wife will kill me
Go to your furnace and open its door that covers the controller circuit board. You should see the thermostat wire going into your furnace and connecting to this circuit board. There are symbols where the color wires are connected (e.g. W, Y/Y1, C, R, etc.). Write down the wire colors and the corresponding symbols. Go back to your thermostat and connect each color wire to thermostat wall plate according to your recorded symbols from the furnace.
Posted on Nov 26, 2012
  • 43,501 Answers
We will try to keep you alive here... :-)
Red wire on the R terminal
Green wire on the G terminal
White wire on the W terminal
Blue wire on the C if no A/C and on the Y if you do have A/C
Thermostat Wiring and Terminal Designations
heatman101
Posted on Oct 13, 2010
Where does the red wire go?
What are you wiring it to? Post the make and model of the HVAC
May 01, 2013 | Lux Products TX9000TS Touch Screen 7 Day...
Help My LUXPSP511 Thermostat has 5 wires connected , Red yellow ,green white and blue.(marked C). There is a jumper between RH and RC. I bought a new LUX TX 9000RF which only has a 4 wire diagram, Do i...
Yes leave the C off if it is battery powered the only time you use the C is if it isnt battery powered.
Just to let you know LUX is an awful brand of t-stat they have a lot of issues with them. As a general rule always stick with white rodgers or honeywell stats they are made very well and reliable.
Jul 15, 2011 | Heating & Cooling
My dryer has a three prong cord and the house i live in has a 4-prong connection. I purchased a 4 prong cord at Lowe's. I know the black and red are hot- no problem there . The ground wire (green) is...
the only difference is that the 4 prong wire has a ground wire,on the block the white wire should be in the middle,the red wire on one side and the black on the opposite side and the green connects to the frame,so yes the white wire will connect to the blue/green combo....http://www.youtube.com/watch?v=-7kgMn5Frt8&feature=related check out this video,it has the blue/green wire you're talking about.hope this helps.
Apr 03, 2011 | Dryers
RED BLUE GREEN WHITE ARE THE FOUR WIRES THAT I HAVE TO CONNECT. PROBLEM IS THAT I FORGOT TO (AND I KNOW BETTER) MARK WHERE EACH CAME FROM TO PUT BACK IN THE RIGHT PLACE -- USED TO HAVE A DEHUMIDIFIER NOT...
On the back of your thermostat, you should have a R (Red), W (White), G (Green), Y (Yellow), and a C (Common). If you have a thermostat that also has a set up for a heat pump, you will have additional terminals, but you don't have to use them since you have a 4 wire, ( in case you do, make sure your thermostat is set up for 1 heat, 1 cool). Your wires are all color coded besides the blue. Red to R, Green to G, and so on. Your Blue wire is being used for Yellow which will go to the Y terminal. Blue is usually meant for a common, but with only having a 4 wire, that's the color that was used. Red is your power, Green is your fan, White is your heat, and Yellow is your A/C. Hope this helps clear some stuff up and good luck!
Mar 12, 2010 | Honeywell Electronic Programmable...
Wiring a TPH553 Surface Mounted Jack by RCA.
TPH553 T568A T568BPin 1 - BL White/Green White/Orange Pin 2 - OR Green Orange Pin 3 - BK White/Orange White/Green Pin 4 - RD Blue Blue Pin 5 - GR White/Blue White/Blue Pin 6 - YL Orange Green Pin 7 - BR White/Brown White/Brown Pin 8 - WH Brown Brown
REF: wikipedia
Feb 17, 2010 | Computers & Internet
Wiring on a RCA RJ-45 wall jack
the RJ45 wallplate is not meant for ethernet. It's an 8P8C connector for a phone. Will it work as a network jack? Maybe. I wouldn't use it, but if you really want to try, wire it thusly:
1 Blue --- Orange/White
2 Orange --- Orange
3 Black --- Green/White
4 Red --- Blue
5 Green --- Blue/White
6 Yellow --- Green
7 Brown --- Brown/White
8 White --- Brown
I'd still recommend a CAT5 wallplate with a CAT5 jack.
Apr 11, 2009 | Computers & Internet
Replacing Lennox Thermostat with Lux TX9000TS electronic t-stat
Unless you have a 2 stage heat system, all you wire up is W1
X is typically only used for humidifiers, dehumidifiers, air cleaners adn other such accesories. If you have none of these, X is unused.
It is typical to find that the original installer wired black or brown to X at the T-stat and left it unhooked at the unit. In such case, just leave X unused.
If your wires are
Red
white
yellow
green
blue
And if your system is a typical furnace with airconditioner then wire it liek this,
Red to Rc
Yellow to Y
green to G
White to W1
Blue to C (common)
Your installers manual will let you know if you shouild leave the jumper between the Rc and Rh terminals.
O terminal is only used for heat pumps and getas the orange wire.
If your T-stast has batteries and does not require an external power source, then you do not have to have the blue wire to C terminal.
If for some odd reason the maqnual does not inform you obout the jumper to RC/RH Try it firt without the jumper. Run it through all cycles. If all modes do not operate, install the jumper.
Jan 24, 2009 | Heating & Cooling
Radio installation
1995 Isuzu Rodeo Stereo Wiring Constant 12V+ Red/White Switched 12V+ Brown/White Ground Black Illumination Green/Red Dimmer n/a Antenna Right Front Front Speakers 4" Dash Left Front (+) Blue/Yellow Left Front (-) Yellow Right Front (+) Green/White Right Front (-) Gray/White Rear Speakers 4" Side Panels Left Rear (+) White Left Rear (-) Red/White Right Rear (+) Orange Right Rear (-) Black/Orange
Dec 30, 2008 | 1995 Isuzu Rodeo
Plymouth voyager
Hi Marlon,
Not a whole I can do to help. What I can do is refer you to go get a Chilton, or Haynes manual thac voers your Plymouth Voyager. They have schematics with wire colors labeled.You will have a good shot at figuring out which wire is which.
Nov 24, 2007 | Car Audio & Video
Heating & Cooling Logo
180 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
