Question about Kenmore Refrigerators
53202, my freezer is working fine, but the fridge has been getting warmer and warmer. The outside seal of the fridge door and where it meets the inside are hot. ???
  • Kenmore Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 13, 2010
Igloo refrigerator's freezer: -16 deg. Fridge: 60 deg. No evap fan & duct from freezer to fridge. Cond coil clean. Discharge line warm. T/STAT@coldest temp. Fridge gasket seals. Condensate drain clear
freezer is working fine, refrigerator won't go above 60 degrees.
www.shopyourway.com > Manage My Life > Questions
Freezer is working fine but fridge won't go about 60 degrees. Cleaned out pass through from freezer to fridge, clean vents, and cleaned coils. All to no avail.Missing: gloo
Beckly Powerful Suction Cup Handle No Tools Necessary!
www.amazon.com > ... > Bathtub Appliques
Amazon.com, Inc.
Rating: 3.6 - ‎85 reviews
Just Turn 60 Degrees and place on any Flat Smooth surface. For Bath Safety and Cabinet Doors Also Fridge Accessory. Beautiful ... No tools, no glue! No need ...
[PDF]Operate Refrigerator In Room Warmer Than 60°F
Jan 03, 2016 | Refrigerators
Fridge freezer gets warm every 24/48 hours
A few things to consider. What is he temp in the FF side of the unit? Putting a thermometer in a glass of water overnight on the bottom shelf should read 40F in the morning. If that's fine its cooling properly. Assuming your not opening and closing the doors excessively, you could have a leaking/bad door gasket or the interior light door switch has failed and is stuck in the on position, which would make the interior temp slowly rise. To check the door gasket, close the door on a dollar bill (at various places around the doors), slowly pull out the bill you should feel good resistance,, if it pulls out easily or no resistance is felt the door gasket is bad or door is misaligned. Also don't forget door gaskets and sealing surfaces need to be checked and cleaned regularly for them to seal properly.
Nov 04, 2014 | Refrigerators
Refrigerator not cold
You say refrigerator SIDE not cold? You would expect the outside panels of a refrigerator to be around room temperature or warmer as the fridge removes heat from inside the cabinet and expels it outside. If you mean the inside of the fridge is not cold then check the door seals are sealing correctly around the door frame. You could also check that there is nothing inside the fridge protruding and therefore inhibiting the closure of the door correctly.
Jan 04, 2014 | GE 20 CFT GSE20JEWF BB BLACK COLOR SIDE BY...
Kenmore freezer too warm
Are you referring to the internal temperature of the freezer? If so
have you checked that the door is closing ok and that the door seals are meeting the door frame all round?
It might be that the coolant gas has slowly leaked out. A good indication this has happened is that the bottom of the freezer is a lot warmer than the top. If this is the case a serviceman will need to drain the existing gas and then recharge, re-pressurise and seal.
If you are referring to the outside cabinet temperature then it's probably ok and there is no fault. You would expect the outside panels of a freezer to be around room temperature or warmer as the freezer removes heat from inside the cabinet and expels it outside.
Jan 01, 2014 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Frig is very hot on the outside ban that meets the seal
That heat that you feel is part of the design of all refrigerators. Those heaters are there to keep water from condensing on the outside of the cabinet around the freezer door. Just like water condenses on a cup of Ice water. It will do the same on a refrigerator. If those small heaters were not there. The water would cause the paint to rust badly. There are various arrangements of heaters used on Freezers and refrigerators around the doors. Particularly the Freezer door.
As long as the fridge is cooling properly it is fine.
If the fridge fails to get cold, the outside of the cabinet will actually get quite hot.
Hope this helps,
Best, Mark
Dec 28, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
We have a Kenmore Fridge. The freezer will not freeze anymore but the fridge works fine. We did unplug the fridge and let it sit for 24 hours to see if that would help the freezer to work again. it...
IT'S FUNNY THAT THE FRIDGE SIDE IS WORKING AND THE FREEZER ISN'T,ALL THE MACHINE DOES IS GET COLD IN THE FREEZER AND THE EVAP FAN BLOWS COLD AIR FROM THE FREEZER TO THE FRIGE SECTION.IF THE FRIDGE IS COLD AND THE FREEZER IS RUNNING WARMER THAN IT SHOULD YOU COULD HAVE A SEALED SYSTEM PROBLEM,SOMETHING WGONG WITH THE COMPRESSOR OR A LEAK IN THE SYSTEM.THE GAS WILL CONTINUE TO LEAK AND THEN BOTH SIDES WILL GET WARMER AND WARMER.YOU CAN REMOVE THE INSIDE FREEZER WALL,LOOK AT THE EVAP COIL AND CHECK THE FROST PATTERN ON IT,WHEN IT'S RUNNING CORRECTLY THE WHOLE COIL WILL FROST UP BUT IN YOUR CASE YOU'LL MOST LIKELY FIND THE COIL PARSIALLY FROSTED OR JUST THE TOP OF THE COIL WILL HAVE ICE ON IT,THAT MEANS NEW FRIDGE TIME,IT WOULD BE TO MUCH MONEY TO REPAIR IT.LET ME KNOW WHAT YOU FIND WHEN YOU LOOK AT THE COIL AND WE CAN GO FROM THERE
Nov 23, 2010 | Kenmore 14.8 cu. ft. Top Freezer...
Freezer working fine the fridge is not
The motor running constantly means the fridge is not sealed properly so that it is losing cold to outside. Check if the door of the fridge seals properly.
Jul 05, 2010 | Maytag MSD2756G Side by Side Refrigerator
Model gss20iepcbb freezer side works fine ...fridge
on most units they have two controls refrigerator control is electric t-stat that runs compressor freezer control think of it as a door colder freezer door is barely open warmer freezer door all the way open all cooling coils are in the freezer and a fan moves the air to refrigerater side possible problem fan not running
door freezer control all the way closed
light switch broken light staying on door gasket not sealing tight find door switch press verify light shuts off and fan starts
look for torn or damaged door gasket can look from outside with light and see if gasket contacts case on all four sides
freezer is cold enough so compressor is ok hopr this helps good luck ron
Dec 10, 2009 | Refrigerators
The fridge is cold but the freezer won't freeze
The grill being the condenser coil- The sealed system is low on freon or the compressor isn't working correctly.
Jul 01, 2009 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
197 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
