Health & Beauty Logo
Posted on Oct 13, 2010
I have a conair hair razor and the charger is not working. It is a class 2 transformer the model number is ud0312A would it be possible to order a new charger?
frank bisceglia
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 04, 2014
frank bisceglia
Contributor
Level 1:
Answers
Questions
Helped
748
Points
0
Where can i find a new class 2 transformer for my conair hair clippers? model: UD0312A
4 Related Answers
Anonymous
  • Posted on Nov 20, 2008
SOURCE: lost charger for conair GMT182
Call Conair, 800-326-6247. I lost charger for GMT183 and they replaced it for $5 + $.50 S&H.
Anonymous
  • Posted on May 26, 2008
SOURCE: conair hc318d reassembly
you can buy another blade set for that model. Call 1-800-3-CONAIR
Anonymous
  • Posted on Jun 07, 2009
SOURCE: Conair GMT200 Assembly
Hey dude i had the same problem n_n. Attach the screws in place and try to screw one by one gently. Soon this pressure will keep the spring tighten (instead your finger's pressure) then it will be easier to reassemble the component. I know you'll fix it n_n.
Anonymous
  • 35 Answers
  • Posted on Sep 22, 2009
SOURCE: where can i find a new class 2 transfomer for my
This is a test by FixYa Staff.
MODS - DO NOT REMOVE
Thank you!
1helpful
I lost my old original power adaptor so I need more specific info for the bms10m.
It is a class 2 transformer. The Conair part number is TEAD-57-121600U Input: 120 volts AC 60 Hz 29 Wats Output: 12 volts DC 1.6. You can try getting an alternative as long as it has the specifications as shown above. I wish you luck.
1helpful
Need replacement blades for hair trimmer
Hi. Order them from Conair: customer service representatives will be happy to help you. Please call 1-800-326-6247 for a Conair appliance.
I have a Wahl clipper Pro Series Rechargeable model 9550 and can't figure out which charger goes to it. I have one labled for model 5550 only - is that it?
My clipper, model 8552 says use with model PCC charger only.
On the charger / transformer it lists the clipper models it will work with. It says class 2 transformer model A30316Q then lists the models in the middle of the unit and then at the bottom says model PCC PT#97562-103
Mar 06, 2010 • Wahl 8550
Power chord frayed and I need a new one for a conair hair iron CS36. The chord pivots in the handle 360 degrees.
go to (www.fixit.com/small apliance)
what I found out with my hair dryer (conair infinity model) was that there was a short at the plug and when I bent the wire a little to left or right the dryer would work. The plug is GFI protected that means there is a test and reset switch built in to the plug. There for for me to fix my hair dryer I would have to replace purchase order the whole cord. The cord assembly cost almost half the price it would cost to replace the dryer with a new dryer. I purchased a new dryer.
13helpful
4answers
Conair hc318d reassembly
i have hc318d clipper it been use two time and havent use it in a year so was going to use it last nite and the small blade fell out. i try to put it back in and it want hold keep falling out
Top Conair Health & Beauty Experts
ZJ Limited
ZJ Limited
shaveroutlet.com
shaveroutlet.com
TUSHAR PANDYA
TUSHAR PANDYA
Level 1 Expert
Are you a Conair Health and Beauty Expert? Answer questions, earn points and help others
