Question about GE Spacemaker JVM1640SJ Microwave Oven
Our microwave keeps saying service may be needed keypad shortage what does that mean?
3 Suggested Answers
  • 2468 Answers
SOURCE: microwave beeping and says keypad short may need
the membrane gets dirt under them and shorts out the keypad,you may as well just replace the control board which includes the display and keypad on the same board
Posted on Jul 26, 2010
  • 65 Answers
SOURCE: my GE microwave (model# JNM1541DN1BB)
HELLO.
The GE problem is with the magnetron being to close to the computer. If your microwave runs for a few seconds to minutes then resets with funny characters on the screen, you can follow these simple instructions to fix it.
needed things.
* Phillips screwdriver
* Foil
* Large ziplock baggie
* Tape
* 1 Unscrew the 2 screws in the top vent grill and remove it.
* 2 Unscrew the 1 screw above the computer keypad, then slide it up to unlock it and it will hinge down, revealing the computer circuit board behind the keypad.
* 3 Put a sheet of foil into the large ziplock bag and seal it up.
* 4 Then tape it to cover the whole circuit board in the back of the computer. You may have to let the wires stick out of the middle of your foil covering. The ziplock is to keep the metal foil from short circuiting anything on the computer, and the foil protects the circuit board from the small amount of leaking microwaves inside.
* 5 Lock the keypad back up and plugin the microwave to test it before screwing everything back together.
the way to keep it from happening again is to use the microwave with more caution.
Willing to help to help on other problems.
Thanks.
Posted on Oct 01, 2011
My ge is Microwave beeping and says keypad short may need service
PCM/Smart board (comes with the keypad), If it is less that 30 days beyound the 12 month warranty call GE and ask for a "good will concession" ... 1800-GECARES
Apr 28, 2014 | GE XL1800 1100 Watts Microwave Oven
My ge jvm1540 over the range microwave is displaying service needed keypad shortage what does this mean
see this steps and follow and fix it. God bless you
If you have a stuck key or non-responsive key, most of the time you will have to replace the keypad for this microwave oven repair. If your keypad is connected to your control board by a flat ribbon wire, try disconnecting it and clean the silver contacts with an ordinary pencil eraser. After cleaning, plug it back in and try it. If it doesn't fix it, replace the keypad unit. Some units actually have keypad tests to confirm your diagnosis of a bad key.
If your keypad and control is the same unit, replace that unit. Another note, unlike stove/oven keypads and controls, most microwaves do not have error codes or tests to distinguish whether it is truely the keypad or control. Most of the time, it is the keypad that needs replacing, but a small percentage of the time it can b
Nov 15, 2012 | Microwave Ovens
Keyboard shortage
The keypad control board or smart board needs attention," membrane in keypad is shorted"
Mar 27, 2012 | GE Spacemaker 1.5 Cu. Ft. Over-the-Range...
My GE microwave (model# JNM1541DN1BB) is giving me a message; service may be needed keypad shortage. Question 1 how can I fix it myself? Question 2 why did my microwave go out and how can I keep it from...
HELLO.
needed things.
* Foil
* Tape
Thanks.
Aug 30, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My microwave readout say "SE"/
This is indicating a bad keypad. There is a quick reset solution and that is to unplug the unit for a while and plug it back in. But if this is brand new it needs to go back to the dealer you purchased it from. One quick note, do not ever use a liquid cleaner on the touch pad these can leach into the electronics and kill them. The following is the service note from Samsung on this issue.
For all error indications, including the SE or 5E error, try unplugging the microwave from the outlet for at least ten minutes and then plug it back in. If the error persists, the microwave may require service. Please use our ASC Locater to find your nearest Authorzied Service Center."
If this was helpful a vote on the thumbs up would be greatly appreciated.
Aug 16, 2011 | Samsung Microwave Ovens
My GE microwave is beeping and the display says F3
F3 on a GE / Hotpoint microwave means you have a shorted membrane keypad.
We would need your model number to give you more specific info, part ordering info, and en estimate if needed.
Simply contact me here with your model number and symptoms for free help.
On some models, the membrane keypad is peeled off and a new one stuck on.
In other models, the plastic frame must be replaced, and it comes with a keypad already installed.
May 12, 2011 | General Electric Microwave Oven
The microwave is blocked and you press the buttons and it wont work and it says -se-
The microwave oven is showing a systems error, which means there is a short keypad membrane. The solution is to change the keypad to get it functioning.
Mar 16, 2011 | Maytag MMV1163DB Microwave Oven
Microwave is beeping, lock comes on, F2, just keeps beeping by itself
F2 on a KitchenAid mike usually means a Keypad short. Beware if it is a KHMS155LSS, it can self start on its own with a KeyPad short. A real stunning defect.
Sep 08, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Ikea micro wave whirlpool
F3 usually means a keypad or temperature sensor / thermistor problem.
The fact that you can't use the microwave leads me to believe it's a keypad or control circuit board problem.
If you have the owner's manual that came with the unit, I would suggest you look there for a contact numer to call for service.
Otherwise I would suggest calling the store from which you purchased it.
Please write back with more details if you need further help.
Nov 20, 2007 | Microwave Ovens
GE Spacemaker JVM1640SJ Microwave Oven Logo
1,270 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
