Question about Franklin MWD-1490 Dictionary / Translator
I have franlin dictionary mwd-1450 . I lost manel and i try to set clock,, but I don't know how. please show me how to set clock ( time date year). thank you
4 Suggested Answers
SOURCE: need battery info
Got manual from etaco.com. Also had battery info in it. Thank you. LJ
Posted on Jun 23, 2009
SOURCE: my Franklin Merriam Webster MWD-400 Dictionary ...
first check the patta of lcd and after this check the lcd
Posted on May 26, 2010
  • 15 Answers
SOURCE: Unable to start Franklin MWD-1450, battries are
There will be a ram problem... change tam
Posted on Jun 24, 2010
FRANKLIN MWD-1450
http://www.franklin.com/corporate/images/manuals/mwd-1450/
May 05, 2014 | Franklin Office Equipment & Supplies
Help me out
First, make sure the batteries are in the correct orientation and that there is no corrosion in the battery compartment. Then hold the CLEAR button and press the ON button. If that doesn't do it, straighten a paper clip and gently press the reset button located on the back in a pin-sized hole below the book card slot.
Nov 30, 2011 | Franklin MWD-1470 Dictionary and Thesaurus...
Need the manual for th WM 1200 Don't remember
Here's the manual (.pdf file) for the Franklin "Merriam-Webster MWD-1450 Dictionary & Thesaurus
User's Guide", which has a "Games" key to get to the Franklin Games Menu, which hopefully
will let you use all the Games features of the WM 1200, since I can't find any evidence online that
a "WM 1200" exists.
http://support.radioshack.com/support_radios/doc73/73417.pdf
Sep 14, 2011 | Franklin Merriam Webster DBE-1450...
Don't know how to set time and date on Franklin TWE-118 translator. Lost instruction booklet.
I believe that this is the manual that you are looking for, http://www.franklin.com/manuals/twe-118/twe-118english.pdf and if you go to page 5 it explains how to set the date and time.
Hope this helps, and good luck DJRYDR
Jul 26, 2011 | Franklin TES-118 Translator
Setting the correct dateon a sharp organizer yo 530
first of all you shoud find the time and date setting on sharp pw then set it if it not work same problem again then open carefully your sharppw and find the cell battries and replace it
Mar 29, 2010 | Sharp PW-E350 Electronic Dictionary
Need battery info
Jun 22, 2009 | Franklin Merriam Webster MWD-1450...
Zelco Bookmark dictionary II cannot change clock to from AM to PM
Are you in the 12 hour or 24 hour format?
Start here:
-Press the little clock icon (it's above the letter "Q")
-Press the "A" key to toggle between 12 and 24 hour mode. Sometimes I have to do it a couple times to make sure I know exactly which mode it's in.
-Press the "Space" key to enter time setting mode.
- Use your number pad to enter the time...
- Press "ENTER" key to confirm. It will then take you to the Date Setting Mode. If your date is already set just press "ENTER" again.
I think that should help. If not, let me know.
Please rate as a FIX YA if I helped. ;-)
Feb 01, 2009 | Zelco 90112 Bookmark Dictionary II
How to Set the Time on the Royal rp6s
1. Press the "time" icon just below the screen until the date and time shows up (not the count down screen)
2. Press the "edit" button (same as the "new" button)
3. Use the number portion (to the right of the screen) to enter the information.
4. To change the am/pm setting, use the "am/pm" button (same as the letter "B") to toggle between the two.
5. Hit "OK" after correct information is set.
5. Screen info should show exactly what you put in with the corresponding day of the week.
Nov 06, 2007 | Royal 29549X Dictionary
Clock radio, small
This little guy has the most complicated date setting procedure I have ever seen! From the manual: "Manual Time and Date Settings 1. To change your time setting, press and hold the J Time Set Button so that the clock display begins flashing. 2. While the display flashes, press the 1 Reverse and 6 Forward Buttons to set the time. Hold a button for a few seconds to set the time rapidly. Be sure to set the correct AM/PM time, shown by the PM Indicator. 3. After setting the time, press the 4 Enter Button or wait about ten seconds for the clock to beep twice and the setting to lock into place. 4. To change the calendar, press and hold the 9 Date/7-5-2 Button until the display shows the flashing year. 5. Press the 1 Reverse and 6 Forward Buttons to set the current year. When you have selected the year, press the 4 Enter Button, then use the 1 Reverse and 6 Forward Buttons to set the month/day. 6. After you have set the date, press the 4 Enter Button or wait for the display to beep twice and lock into place." You can download the manual from the link below: http://www.timexaudio.com/pdf/T307_IB56281_07.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 24, 2007 | Timex (T307S) Clock Radio
Franklin MWD-1490 Dictionary / Translator Logo
46 people viewed this question
Top Franklin Office Equipment & Supplies Experts
k24674
Andrew Taylor
Andrew Taylor
Are you a Franklin Office Equipment and Supply Expert? Answer questions, earn points and help others
