Question about Refrigerators
It stops getting cold and freezer warms up. then within 24 hrs, its starts working fine again
  • Refrigerators Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 13, 2010
Freezer won't stay cold
What is the model number of your unit?
Feb 10, 2013 | Gladiator Chillerator Top Freezer...
GE pss25ngnacc____refrigrato is to cold can't control tem
start by putting freezer control on half way on the numers. lets say it goes to ten set on five, do the same on refrig side . let run for 24 hrs. so it can stabalize. if it is ok in freezer and things are frozen and too cold in fridge side turn the refrig side to one smaller number. check again in 24 hrs. don't keep opening the door so that it can stabalize. if that doesnt work then it could be the cold control not senseing the temp of the refrig.
May 26, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Why has my fridge stopped working but my freezer still works its Hotpoint mistral plus
Possible that there is block on the air passage from the freezer fan which can be due to frost or failure of the fan.You need to check if there is free flow from the fan, also the setting of the fridge temperature.
Nov 26, 2011 | Refrigerators
Side by Side Whirlpool. Both compartments will stop working then 24 hrs later start up again
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
heatman101
Feb 24, 2011 | Refrigerators
My Magic chef refrigerator/freezer has a problem with the refrigerator part getting warm. I tried shutting it off and letting it set for 24 hrs and that worked a couple of times, but now it just doesn't...
sounds like your refir has an interior circulation fan which is not running. If not the vent to allow cold air to recirculate is closed. Could be the freezer is icing up and defrosting it is helping somewhat.
Feb 03, 2011 | Magic Chef Refrigerators
Refrigerator is not cold (50);freezer is working; vents not blocked. What can I do? Fan is working, & compressor does kick on.
Nine out of ten times it turns out to be a defrost issue. What most people dont understand is the refrigerator gets its cool air from the freezer. If the evaporator coil in the freezer becomes a block of ice then the airflow from freezer to fridge section is blocked. The block of ice along with already frozen foods in the freezer compartment help to keep those foods frozen. Therefore you assume the freezer section is fine. However, the lack of cool airflow to the fridge side quickly turns that 38 degree air into 50 degree air. You could try unplugging the fridge and leaving doors open for 24 hours, this will thatw the evap coil. Plug it back in after the 24 hours, and within 12-24 hrs everything should be cool. If the fridge continutes to cool for about 3-6 days and then fails again, you certainly have a defrost problem. This is long winded, but hope it helps
Mar 01, 2010 | Refrigerators
Temperature in refrigerator is now at 60 degrees even with the dial at setting of 9 other side freezer is fine
sounds like the defrost system is cutting up, it melts the ice in the freezer compartment to allow cold air from freezer to travel to fresh food side and back again, could be a damper control but very rare event.we use to have to melt ice manually in freezers now we have automatic defrosters do it for us. this is not the easiest repair but the defrost sysem is replacable and not the end of your frig.u can empty frig and turn it off for 24 hrs with doors open and let it defrost naturally,so as to make sure that it is a defrostsystem, after 24 hrs turn back on and see if it works correctly after 6 or 8 hrs, if so definite defrost problem.
Oct 08, 2009 | Refrigerators
Refrigerator not getting cold
hello, my refrigerator got the following problem; it works fine at the freezer but there is no cold in the frig, when i unplug it from the wall connection and after few time connect it again, it start working, after few hours, the refrigerator stop, the freezer is fine and very cool,but the frig is not cool and the refrigerator do not start working again, even after the freezer gets warm.Please i hope you can help me with this problem.
Sep 03, 2008 | Refrigerators
Amana bottom freezer working fine but refrigerator not/ warm since 24hrs.
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Apr 28, 2008 | Amana ARB2517CC / ARB2517CB / ARB2517CW...
Refrigerators Logo
53 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
