Question about Mitsubishi WD-62825 62" Rear Projection HDTV
My Mitsubishi WD-62825 says the air flow is blocked and will shut down in 1 minute?
    Master:
  • 473 Answers
Hi... To response to your problem... Check if your fan cooler is working at the back panel... The Lamp need air to cool down,
Never touch the lamp with your bare hand.. take a dry cloth if you have to change it.
Posted on Oct 13, 2010
I have a mitsubishi 1080p wd-65731 just replaced lamp , tv comes on works fine for about 30 minutes and then shuts off , cleaned vents good , has good air flow light that says lamp turns red in the fr
Could be the fan. It will cool tv but could also be to much for tv to handle.
You can also try reseating the lamp. It may say ok but be wrong.
I have a Mitsubishi 5500 projection tv . have had the type of issue you have had and I have replaced a lamp as well.had to reseat the lamp three times before it worked without shutting down.
Hope this helps.
Jan 14, 2015 | Mitsubishi Televison & Video
Area around TV is clear, nothing is blocking TV or air flow. When we use the TV we frequently get this message: The TV will shut off in one minute. Check to see if air flow is blocked. Happening more...
you need a new power supply unit these after some time get old and start over heating causing the tv to heat up intermediately if you take it to a repair shop and have that replaced it will be like new again
Feb 25, 2011 | Mitsubishi WD-52525 52" Rear Projection...
Air flow blocked come on screen and then shutts down
Call Mitsubishi they will tell you an authorized service center in your area to come out and change the thermal sensor in this set free of charge.
Oct 17, 2009 | Mitsubishi WD-57732 Projection Television
Air flow blocked message appears when turning on
Replacing the thermal sensor is the cure for this. If you call Mitsubishi at 1-800-332-2119, press 5 for Customer Service. Explain the problem and they will probably approve a extended warranty claim and get the repair done for free through a Mitsubishi Auth. Repair Facility. They will also help get you in touch with one near you. Do not delay in acting on this. I do not know how long the extended warranty claims for this problem will last.
Hope this helps,
Skyassoc
Jun 20, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Has Sound but no Picture and shuts down
I have the same tv and the same problem happened to me (Actualy twice). It turned out to be the color wheel motor. thats what the clicking noise is.
May 15, 2009 | Mitsubishi WD-57732 Projection Television
Horizontial lines and picture deteroration
This one is tough. Can be either the DM module, formatter board or optics block assy. Check for bad capacitors first in DM module, then signal board then formatter board. If your lucky, bad capacitors maybe what it is. If not, a new optics block is what you'll be needing.
Dec 20, 2008 | Mitsubishi WD-62825 62" Rear Projection...
Wd-62825 mitsubishi dlp tv
Had the same problem. Service replaced the lamp engine. It did help.
Dec 18, 2008 | Mitsubishi WD-62825 62" Rear Projection...
Wd-65731
AIr flow is blocked?.....is this the message you get on screen mitubishi have a problem with what is called the thermal sensor.. the processor says its getting to hot... mitsubishi suggest service center replace this thermal sensor.
Jun 02, 2008 | Mitsubishi WD-57731 57" Projection HDTV
Green people on my mitsubishi wd62827
could be the green bias control on the crt board
May 26, 2008 | Mitsubishi WD-62825 62" Rear Projection...
Mitsubishi wd 52525 dlp shuts down
mitsubish has issued a service bullietin about the problem. which means ussally they will pay for its repair. the reson it says airflow bock is that there is a temperture sensor that is at fault... it needs replaced.
Dec 13, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-62825 62" Rear Projection HDTV Logo
121 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
