Question about RCA P52926 52" Rear Projection Television
Convergence problem The shape of the screen is in an odd shape, and everything is doubled. The green and red lines are not lined up properly. I tried to go to setup and do the auto convergence but it is not listed under there anymore. I unplugged the tv for 30 min hoping it would reset itself, but still no luck. Any suggestions???
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 317 Answers
Leave it alone and call tech
Posted on Jun 01, 2008
My picture is doubled on my toshiba TN50V71 as if there is a shadow behind everything? Please help!
hi, sounds like a convergence issue. try this...
  • Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  • Enter the menu on your TV. Use the remote control and bring up the menu.
  • Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  • Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  • Press "Enter." A crosshair pattern will appear on your screen.
  • Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  • Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  • Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  • Repeat these steps for all colors.
    good luck!
  • Feb 02, 2011 | Toshiba TN50V71 50" Rear Projection...
    I have a Panasonic HDTV and suddenly the colours went double!
    hi, if you know little fixing tip's? here's my tip's sound's like converging ic's,gone bad. on the left board there's two a touched to a big heat sink.but before you start'.there's three wire connected to the board written. red .blue.and green.check for burn film resistor's on line red. replaced it with the same.good luck.
    Feb 02, 2010 | Panasonic Televison & Video
    Red green blue signals are not lined up. There
    Convergence problem. Replace the convergence ICs and check the low ohm feed resistors as well.
    Jan 03, 2010 | Televison & Video
    The tv is showing everything kind of double and everything is double lined in red and green
    Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
    This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
    Common Symptoms include....
    • Screen looks 3D
    • Colors don't line up
    • One or more colors can't be adjusted when using the convergence menu.
    • Screen is bowed or warped.
    • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
    Here are some photos of convergence problems.
    Here is a quick test....
    Using your original remote go-to the settings menu then goto the convergence section.
    Try to adjust the red and then the blue convergence.
    You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
    If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
    Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
    69189a5.pngCONVERGENCE SOLUTION
    You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
    This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
    Jun 28, 2009 | Hitachi 43UWX10B 43" Rear Projection...
    Getting "red" double image
    Your TV most likely has a Convergence Chip Failure ( common problem )
    Here are some of the most common symptoms and example photos of a convergence problem
    • Screen looks 3D
    2c07611.pngSolution #1
    You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together convergence repair kits for most models.
    The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
    Apr 27, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
    Double Image Red and Green
    • Screen looks 3D
    Using your original remote go-to the tv settings then goto the convergence section.
    You should be able to move them up, down, left, and right.
    If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
    2c07611.pngSolution
    You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
    Feb 08, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
    Toshiba TP50G50 Theaterview picture is double with red color only
    Your alignment is off. Go to the set up menu then convergence. hit right and you will be in the convergence menu. select the color that is not in alignment. The green line does not move. if blue and green are lined up the line will be cyan. if red and green are lined up the line will be yellow. when all three are lined up the color will be light. Best of luck!
    Nov 16, 2008 | Toshiba TP50G50 50" Rear Projection...
    Suddenly, the screen shows double images on letters and numbers plus red/greenish like shadows on characters.
    Youre convergence Ics need to be replaced. post the model number of your set and I will post the STK number that you need and a link where you can get new replacement ICs
    May 25, 2008 | JVC AV-48WP30 48" Rear Projection...
    RCA P52926 52" Rear Projection Television Logo
    Top RCA Televison & Video Experts
    matt martin
    matt martin
    Jaime Hernandez
    Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
