Question about KitchenAid 24 in. KUDM01TJ - Multiple Color Built-in Dishwasher
RINSE ONLY LIGHT BLINKING Kitchenaid KUDM01TJBS0
RINSE ONLY light is blinking and no functions of the dishwasher work. Turned off power for 2 hours, no change. Removed ribbon cable from between keypad and contrioller (?) for 30 minutes, rplaced and restored power and was able to start the washer through the wash cycle. Stopped when starting the rinse cycle and RINSE ONLY light blinking again.
Kind of a pain to rinsh dishes by hand! Any solution?
  • 4 more comments
  • VG25 Jun 02, 2008
    It is a KitchenAid KUDM01TJBS0.
  • VG25 Jun 02, 2008
    You are saying the keypad interface, part number 8269197?
    Thanks.
  • VG25 Jun 02, 2008
    You are referring to the keypad assembly? Part number 8269297?
    Thank you
  • VG25 Jun 02, 2008
    The keypad assembly is a completely molded part with only a ribbon cable and connector exiting the assembly.
    Which sensor are you referring to?
  • VG25 Jun 02, 2008
    thank you. I've ordered the part and will give it a shot.
  • Anonymous Mar 20, 2014
    My Kleenmaid DW29 X dishwasher has a constant error light flashing (! in a triangle). All the other top lights remain illuminated (salt rinse, keypad lock and washing product.
    the bottom indicator lights - the 45 min remains constant whilst the 30 min cycles with the 15 min and end light together.
    I have tried disconnecting the power. I have tried holding done the start button. Has not fixed the issue.
    The dishwasher still works but once started it will not stop until i manually turn it off.
    Any suggestions please. Jamie
  • 3,037 Answers
The keypad interface is bad, you would need to replace that and then it should work great. Let me know if you run into any trouble or have further questions and I would be glad to help.
good luck
Posted on Jun 02, 2008
  • 1 more comment
  • Benjamin Patri
    Benjamin Patri Jun 02, 2008
    from www.partselect.com the part number is PS393302
    Let me know if you need anything else
  • Benjamin Patri
    sounds good, please let me know how it goes
  • Benjamin Patri
    Benjamin Patri Jun 08, 2008
    Were you able to fix this, if so then please give me some feedback by
    rating my solution. If you need any more help, I would be glad to
    assist you, just ask.
    Thanks for your time and service and I hope you have a Great Day!
  • 1,031 Answers
When such occur it has to do with the control board you will need to replace your control panel key assembly
Posted on Jun 01, 2008
  • Starnley Johnwells
    Starnley Johnwells Jun 02, 2008
    once you replace the keyboard assembly there should be improvement you ought to have done that but if the problem persist after that let me knw
    Genius:
  • 1,142 Answers
To get the best cleaning results, the water entering your dishwasher needs to be hot enough. Try running the hot water in your kitchen sink for about 30 seconds before starting the dishwasher, to pre-heat it. Also, if your dishwasher lets you select a higher wash or rinse temperature, try that to see if it helps.
To check the temperature of the hot water that comes from your kitchen faucet use a waterproof thermometer. If the water isn't 120 degrees Fahrenheit, your dishwasher may have trouble getting your dishes clean. You could increase the temperature of the hot water to the whole house--and therefore the dishwasher--by adjusting the hot water heater thermostat.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
    Scholar:
  • 198 Answers
Open the assembly unit and check out for the loose wire connections. the wire connecting the RINSE ONLY light might have become direct. and the wire connecting the other controls are malfunctioning....
there seems to be a problem with the sensor also... just check it once
here s the user manual for ur dish washer...just create an account here to get the manual
http://www.kitchenmanuals.com/manuals/mfg/kitchenaid/kudm01tj_1.html
    Brigadier General:
  • 3,614 Answers
I want to know what was the exact maker/model, part# of your unit
Thanks
I HAVE A KUDI01IL DISHWASHER THE NORMAL,RINSE ONLY, AND CANCLE LIGHTS ARE ALL BLINKING AND THE MACHIME WITLL NOT WORK ANDY IDEAS ON THIS?
Try turning off the power for 10 minutes and see if the control panel will reset itself when it is turned back on.
Aug 07, 2013 | KitchenAid Dishwashers
KitchenAid dishwasher KUDM01TJBS0 does not start.
Most likely your keypad is bad. Will need to replace the console.
Nov 20, 2011 | KitchenAid Dishwashers
Clean light keeps blinking and washer will not function. Cancel runs the pump for 2 minute, but the blinking light keeps going with no functions working.
if the clean light is blinking that mean you dishwasher is having a heater issue. it is an error code. either your control board is bad or the heater or the ntc therm. if you take the bottom panel off you will see or should see a tech sheet that will tell you how to clear the error code or this website will help you. just enter your model number http://servicematters.com/docs/wiring/wiring_main.htm
Jul 03, 2010 | KitchenAid Dishwashers
I HAVE A DISHWASHER, KITCHENAID SUPERBA, I DON'T HAVE THE MODEL OR SERIAL NO#. THE ONLY NO#. I CAN FIND IS 8270140, THE DISHWASHER IS NOT RESPONDING TO ANY COMMANDS, THE RINSE LIGHT IS BLINKING AND THAT...
I HAVE A DISHWASHER, KITCHENAID SUPERBA, I DON'T HAVE THE MODEL OR SERIAL NO#. THE ONLY NO#. I CAN FIND IS 8270140. The unit is not drying the dishes?
Oct 02, 2009 | KitchenAid Dishwashers
Whirlpool quiet partner III clean light blinking green
you have to hit heated dry and normal and toggle these till all the lights light up. then hit cancel . you are going to have to turn the power of and slide the dishwasher out and look directly behind the dishwasher you will see that a wire off of the heater is more than likly burned of repair the wire you should be fine. replug dishwasher in after wire is repaired. if you do not have a burned wire you have a bad heating element replace the element.
Apr 14, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
Kitchen Aid Dishwasher--model #KUDS01DJ
On mine the "normal" light was the one that was flashing; after a cycling of the breaker switch in the electrical main panel and closing the washer door, it went to a 2 minute rinse before shutdown.
May 17, 2008 | KitchenAid 24 in. KUDP01IL - Multiple...
KitchenAid 24 in. KUDM01TJ - Multiple Color Built-in Dishwasher Logo
1,309 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
