Question about Bachmann James The Red Engine Train Set
I have an 1976 steam loc. and the wheels are just locked up ! What can I do to fix this?
  • 132 Answers
If possible try useing some graphite/or dab a qtip in some liquid wrench and carefully touch it up till you feel some movement.
Posted on Oct 13, 2010
What does a LOC code mean?
loc has to do with control lock:
control lock (press and hold)
to lock the controls between or during cycles, press and hold the add steam button for 5 seconds. loc will be displayed if you attempt to wake up a "between cycle" locked unite and loc will alternate with cycle time remaining in a "during cycle" locked unit. repeat to unlock the controls when you are ready to operate the washer. use this feature to reduce the likelihood of accidental operation by children.
Sep 03, 2015 | Kenmore Dryers
What does loc mean on kenmore elite dryer
It indicates that the control panel settings are locked.Which is a safety feature. Press the SELECT and OPTION button or press & hold the "Add steam" button for 6 seconds to reset it.
Sep 13, 2014 | Dryers
2004 kawasaki 110cc took apart back tire area and have a thick metal cylinder shaped object and forgot where it goes
hi there hicks32
that metal object is a rim loc , it should have a rubber top bonded on it , this fits into another hole other than the one that the tube valve stem goes into
you should have 2 holes ,fit rim tape, fit one side of the tyre bead, instal rim lock ( with rim tape running over the rubber on the rim loc ) fit the washer and nut losely on the rim loc bolt stem by at least 4 or 5 threads fit the tube as you normally would, push the rim loc stem fully up ( so that the nut rests on rim )do not let the rim loc stem receede into tyre ) refit the other tyre bead and inflate the tyre and seat the beads on the rim , tighten the rim loc nut and the valve stem nut
make sure that that both rim loc and valve stem are straight when inflated and tightened
refit your wheel
cheers pauly46
Jun 08, 2011 | kawasaki Motorcycles
Loc on dryer
"LOC" indicates that the control panel settings are locked. Press the SELECT and OPTION button simultaneously to toggle this 'feature' on or off. This will fix the issue.
Thank you !!
Jul 06, 2010 | Frigidaire ATF6000ES Front Load Washer
1976 lincoln ignition wont turn.key will go in and out ok
The lock cylinder is probably worn (assuming that you have the right key!) Try wiggling the key while trying to turn it. Try ay other copies that you have. If the key locks the steering you may have to move the steering wheel to get the key to turn.
Apr 23, 2010 | 1996 Lincoln Town Car
Removal of 1976 chevy truck ignition switch
need a special tool to remove the locking plate behind steering wheel then pull turn signal switch back a little then remove screw that keeps lock cylinder in place
Oct 22, 2009 | Chevrolet C3500 Cars & Trucks
75 chevy k10 range selection
H-loc is high range with locking diffs
H is high range with open diffs
N is neutral with no engine power to the wheels
L is low range max speed is 15 mph
L-loc is low range with locking diffs
Apr 16, 2009 | Chevrolet Lumina Cars & Trucks
Replace an ignition lock without the key on a 1976 Volare
you take off the stearing wheel and under it there is a spot that you slide a flat head into and push a little tab on the lock cylender to release. its kinda hard to find but good luck
Dec 29, 2008 | 1990 Jeep Cherokee Limited
LOC Error
I agree with the suggestion on the clarification request.
I also have a Saturn. If the steering wheel is turned too far in either direction when the key is pulled, it leaves a lot of tension on the lock plate. The solution is turning the wheel a little further while turning the key.
The only time I see LOC on a radio, it specifies the type of signal. (LOC = Local, DX = Distant Transmission).
Hope this helped,
Mike
Jun 14, 2008 | 1999 Saturn SL
Bachmann James The Red Engine Train Set Logo
114 people viewed this question
Top Bachmann Crafts & Hobbies Experts
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Steve
Steve
Are you a Bachmann Craft and Hobby Expert? Answer questions, earn points and help others
