Question about Whirlpool Dryers
Timer knob doesn't turn. Wherever you leave it, it stays.
    Sergeant:
    Champion:
  • 351 Answers
Hi sound like your timer need to be replaced to do this you have to get top panel off there to screws. at each end pull them out flip top over you will see timer some times they just twist out or a have screw that hold them in . also take knob off or if you don't feel good doing this call a tec jim
Posted on Oct 13, 2010
The knob just spins round and doesn't catch. It received a bash and it now won't accept a wash cycle. Any thoughts?
It seems that the timer has failed and needs a replacement. If this seems to turn around without clicking and if there is no action when the program cycle is initiated, this seems a failure of the timer controller unit. This happens in cases when it is turned around in reverse order or violently.
Jan 14, 2013 | Zanussi Washing Machines
General Electric WHDSR209DWW Top Load Washer. Timer works but has lost proper synch with knob and skirt. Can force timer to a position that will run the machine from an unknown starting point. When knob...
Hello:
Its either your knob is stripped or the timer itself is..Most commonly its the knob assembly that's bad.(part# WH01X10061) I would try it first since the knob is only around $7.00 where the timer is around $140.00or so...
Good luck
Jun 04, 2017 | General Electric WHDSR209DWW Top Load...
I have a Kenmore washer model 110-20712991. the timer doesn't advance. Wherever I put it, it stays there and only does that functions, never advancing to the next position. Is there any test i can perform...
It does sound like a bad timer:
See the following: This is a Whirlpool / Kenmore Service Manual for top load, direct drive washers. It has testing instructions as well as directions for removing each of the two types of timers.
If your timer is the one with a knob that un-screws, use a thin needle nosed pliers to hold the shaft going thru the timer while you un-screw the knob.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Oct 12, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore model 110.24642300 will not cycle through wash cycles...will stay stuck in wash cycle until the knob is manually turned to rinse/spint/etc. Would this be a bad knob or timer or both? Thanks!
Start a cycle and remove the knob. If it still stays in agitation mode and won't advance to the spin, then you have a bad timer, or no power to the timer motor(very unlikely). If your washer goes through the cycles with the knob off then you have a bad timer knob. I have seen stripped knobs causing the timer to bind up and not advance. Good Luck Appliance Specialists
Dec 31, 2009 | Washing Machines
My Simpson Riviera 966 wont complete wash cycle,whats wrong with it ?
1) timer- it stays wherever you leave it and does that action.
2) No fill -cold- for rinse
3) No pump out
4) Syphoning- where is your drain hose ?
5) Set to " no spin" drip dry" -- reset control
6) Lid switch - not engaging
Sep 12, 2009 | Dishwashers
Machine don't fill & Control knob don't advance automatically
Every machine is wired differently. It's possible but not likely that it has a fuse in the circuitry. My guess is that the level sensing tube is blocked and the washer thinks it is at the preset level, ior that the sensing tube has a leak in it. Similar to a hole in a straw. The washer can not advance and operate in automatic if its preset is not satisfied. The preset here is wherever you or it sets the level. Once thw washer fills then a contact closes and turns the timer motor on and advances the timer.
Mar 25, 2009 | Dishwashers
Dryer not heating up
If the timer knob does not turn in a clockwise direction, then chances are the timer is bad.
Heating is a different issue, although, if the timer knob will not turn, then it may not be at a position that turns the heat on.
Replace the timer, then check the heating. If the heater then works, then the problem was in the timer. If it doesn't, then we need to look at problems within the heater circuit.
Reply back what you find out.
Jan 23, 2009 | Whirlpool LER5636P Electric Dryer
Buzzer wont quit
have you tried to turn the knob slightly at end of cycle to see if it would shut off? try that if it does shut off then replace your timer
Jan 06, 2009 | Kenmore 73952 Gas Dryer
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
