Question about Garden
My McCulloch Pro Scaper II HD start right up but has little power. The line doesn't spin fast enough. I am using the recommended weight of line. Could this be a carburator issue?
    President:
  • 1,545 Answers
An engine running at reduced power could have different issues. Check for carbon build up in the muffler and on the spark arrestor screen at opening on muffler. Cleaning it fixes this issue. Yes, it could be a carb issue also. If you can, remove the carb and its covers and gaskets, noting where they go, and spray the carb liberally with aerosol carb cleaner. You may just need to adjust the H and L speed jets on the carburetor. There is no one solution to your problem, but it is most likely carbon build up or a malfunctioning carb. A gasket and diaghragm kit (under $10) can fix a lot of carb issues, so after cleaning and if you see no improvement, consider installing a new G & D kit.
Also, don't forget to check the condition of the spark plug. The way a plug looks tells a real story about how the engine is performing. With the plug removed, shine a flashlight into the engine down onto the piston and note how much carbon/crud/buildup there is. Removing this buildup improves engine efficiency and lost power also.
Posted on Oct 14, 2010
Changed filters in my shark rotator pro and now it doesn’t suck through floor brush.
If the brush roll isn't spinning fast enough it will not pick anything up off carpet leading many people to think they don't have suction. Check your belt.
Mar 28, 2018 | Shark Vacuums
Model #AIR STREAM 335-VAC II 385 Mcculloch Blower power vibrates
I recommend contacting your local authorized service center for assistance.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Nov 27, 2013 | McCulloch 12 Amp Electric Blower/Vac...
Mcculloch ms1435 chainsaw will not start
Could be a variety of causes. I recommend contacting your local service center for assistance.
Contact us
User manuals
McCulloch Service
Sep 19, 2013 | McCulloch Ms1435, 14" Chainsaw Chain 49dl...
I have a McCullough Mac 3216 chain saw. The fuel lines to the primer bulb are completely disintegrated. I have purchased a replacement kit for the primer & lines, but don't know which line...
New kits often include a diagram. You can try a google or youtube search. Otherwise I recommend contacting your local authorized service center for assistance.
Contact us
User manuals
McCulloch Service
Apr 19, 2013 | McCulloch 300985-33 224831 Air Filter...
Doesn't spin fast enough to remove water from tub. makes a steady noise that doesn't get louder or softer just stays steady
HI,
Check back of washe with a flashlight for a bent or clogged drain hose. Do not move washer to check it. When you move it , it will straighten out and you will never know if it was bent
Also while it is pumping , pick up end of drain hose at drain and observe the volume of water being pumped.
If no water then the Pump may need replaced
Thank you for using fixya
Leo Ponder
Please rate me if this helped
Aug 12, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a L G and it does not spin dry the wash load How can this be fixed
Do you mean it doesn't spin at all...or it doesn't spin fast enough to dry the clothes?
If it will not spin at all you may have a loose belt or broken belt.
If it does not spin fast enough, you may have a loose belt or too latge a load.
Jun 26, 2011 | Washing Machines
I have a kenmore 80 series and its not spinning out the water.
does it drain out the water and spin but the clothes are still wet or is it not draining or spinning?set the timer to spin,open the lid and stick a screw driver into the lid switch hole and see if it spins and drains,also if it doesn't push down and let the switch up,or close the lid down and open it a little do this a few times,you should hear the switch make a clicking sound,if it doesn't click you have a bad lid switch.if the machine is draining and spinning but the clothes are wet,do the same thing with the lid switch and watch it spin with the lid open,is it spinning fast,if not you have a bad transmission and it's not spinning fast enough to remove the water out of the clothes or you could have a kink in the drain hose or something in the pump and it's not draining all the way.let me know what you find and send the model number off of the washer,the number should start with like 110.
Apr 14, 2011 | Kenmore Washing Machines
I need the gas/oil ratio for an old Pro-mac 10-10S
40:1 according to Mike Acres site, same as current recommended mix:
Chain Saw Collectors Corner
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/8f167f396637c29d88256c2e0073560e?OpenDocument
Oil Mix Ratio:
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Stihl & Tanaka; all recommend 50:1.
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
McCulloch & Poulan; recommend 40:1.
1 gallon of premium fuel to 3.2 ounces of quality 2-cycle oil.
4 liters of premium fuel to 100 milliliters of quality 2-cycle oil.
Chinese chainsaws recommend 25:1.
McCulloch Manuals
Operators Manuals: are much more difficult. I have dialed this number many times (Contact Us - All McCulloch Products 1 (800) 521-8559) and have yet to get a satisfactory response. Please try this! If enough of us try they will fix it! If unsuccessful with McCulloch try here:
Beg for manuals thread (ArboristSite - free to join). Please use the search function first, it has probably been asked and answered.
http://www.arboristsite.com/showthread.php?t=72322
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Apr 26, 2010 | McCulloch Garden
Whirlpool not spinning fast enough. Not
We had same problem which got worse. I had to take the tub out as it wasn't engaging on spin. I feel a washer
was left out at factory as it wouldn't tighten down.
After a few attempts I finally found a washer that was
right ( elec dept ). You basically take the whole thing apart.
It works now but we bought extra washers
Feb 12, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Garden Logo
166 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
