Magnavox tv model #20mf605t/17
When turned on, power light is green as was before but then turns yellow and has no picture
  • 1 more comment
  • Anonymous Jul 02, 2008
    getting power and volume in the magnavox 20mf605t/17 but no picture
  • Anonymous Dec 22, 2008
    IN NEED OF A D C IN 16 VOLT CORD
  • kcollins1 Dec 25, 2008
    Turn on with power button and remote - only get yellow light. No picture.
SOURCE: magnavox 32mf23id/37 wont tun on
Had the same issue, I replaced two 1200uf caps on the power supply board and now it works fine again. Remember to replace the caps with caps rated for at least 35wvdc.
Posted on Mar 27, 2009
  • 21 Answers
SOURCE: magnavox 15mf605t/17 15'' LCD HDTV won't turn on
Have similar TV. If it is set to the PC source, it goes into standby when there is no signal, like a regular monitor. Even though the monitor is in standby, you can still press the Source button to change to, say, HD input, and will use the familiar on/off action when pressing Power on the remote.
A little weird, but I've gotten very used to it.
Posted on Jun 26, 2009
maatmartin7
  • 1229 Answers
SOURCE: magnavox tv model #20mt1331/17 no picture no sound....
Bad eeprom. location 4764. It went corrupt do to bad grounds near the rear of the board. resolder these and replce eepromm part# 996500022895. These are on backorder. be patient. Soon your tv will be alive. Just to the point.
Posted on Jul 08, 2009
roety
  • 585 Answers
SOURCE: MAGNAVOX 32MF605W/17
Hi my name is Eric,
I hope I can help you with your issue ,
 You main a bad mainboard, a repairman will charge about $450 to replace it , use google to try and locate one yourself
If I have helped you with your issue please click accept.
If you have more questions you can still respond
I will reply asap
Thanks
Eric
Posted on Sep 26, 2009
  • 8 Answers
SOURCE: magnavox 37" flat screen model no.37mf23id/37
Yes, he means 2200 microfarret (called uf from here on out). Another important concern when buying a replacement is the voltage. You need to get something that is at least 25v. I recommend a 35v or better. Another notable point is that this may not always fix the problem. As with mine, there was also a 1200uf (microfarret) 35v capacitor that was blown. You can tell this because they bulge at the top. I have both of these caps (2200uf 35v and 1200uf 35v) on order and they will be here tomorrow. If I do not post back here then they fixed the issue for me. I suspect that this will resolve the problem. Look for bulges on top of the caps. This is an indication that they are blown. Most all of you experiancing these symptoms will see the 2200uf cap bulging but you may also see others bulging too. If you do then you need to replace those too. No electrolitic capacitor should be bulging at the top so if its bulging its bad, and if its bad then your tv will definitely not work. Have fun.
Posted on Oct 13, 2009
Tip
Service menu codes phillips magnavox
I provide this information for those that are qualified and trained to do TV repair work. Entering or making changes in service mode by untrained persons can cause significant and permanent damage to your television. If you are not qualified to service your television, please DO NOT ENTER these service menu codes
# Press {0} {6} {2} {5} {9} {7} {INFO+} on the remote.
or
# Press {0} {6} {2} {5} {9} {7} {STATUS} on the remote.
or
# Press {0} {6} {2} {5} {9} {7} {MENU} on the remote.
# Turn the TV off to exit the Service Menu
* Press {0} {6} {2} {5} {9} {6} {INFO+} on the remote.
or
* Press {0} {6} {2} {5} {9} {6} {STATUS} on the remote.
or
* Press {0} {6} {2} {5} {9} {6} {MENU} on the remote.
* Turn the TV off to exit the Service Menu.
* Press {0} {6} {1} {5} {9} {6} {MENU} on the remote.
or
* Press {0} {6} {1} {5} {9} {7} {MENU} on the remote.
* Turn the TV Off to exit the Service Menu.
* Press {1} {6} {2} {5} {9} {6} {MENU} on the remote.
or
* Press {1} {6} {2} {5} {9} {6} {STATUS} on the remote.
* With the TV off:
Models 15MF605T/17, 20MF605T/17, 15MF500T/37:
To Factory Mode:
Step 1 : Select the source "PC" and then turn off LCD-TV.
Step 2 : [Push "power " button and then push the "VOL- " and "VOL+" buttons at the same time immediately and hold it] about five seconds then release all buttons.
Press "menu"button and bring up factory mode indication
on Apr 29, 2015 | Magnavox Televison & Video
Hello, I have a Magnavox tv 32" model 32mt3305/17.
you should bye a surge potecter power cord.surges happens all the time and destroys electronics
Aug 17, 2013 | Philips Magnavox 27MS343S 27" TV
I have a Magnavox 15MF605T 17 that when the power button is pushed it goes green for a couple of seconds then turns amber. No picture, sound, etc. I unplugged the TV for about 10 minutes and when I...
Try to turn it on with a remote if one is available. If you don't have the original remote you can look up the universal code for the cable or satellite remote. Also try to turn it on with the input source(vcr,video game, cable box,etc...) on first. I have the same TV and if it has no signal prior to manual power up it will go to standby mode.
Jul 08, 2011 | AOMNI Corporation Magnavox 15MF605T/17 15...
Need manual
does your tv have a round button in the front of the tv push it then see if it turns on.
Nov 09, 2008 | Televison & Video
I have Direct tv and pused the wrong button on the remote to my Magnavox 20MF605T/17 TV. Now I can't get the picture back. How do I fix? Thanks, Curt
Depending on your TV and receiver there should be a button on the remote that says Format push that button a few times and see if the picture comes back.
Nov 05, 2008 | Televison & Video
Televison & Video Logo
512 people viewed this question
Top Televison & Video Experts
