Question about Whirlpool Duet GHW9150P Front Load Washer
Wont spin, I can hear the ever slightest hmm so I know the motor is working
  • 2,019 Answers
Perhaps the drum is jammed? Try turning it by hand, and make sure nothing has gotten under the drum rim to jam it.
If it is not jammed, then perhaps the belt broke.
You have to take the back off to see the belt.
If it broke, it will be piled up on the bottom. If it is not broken, it should be tight to the drum.
Posted on Oct 13, 2010
Kenmore washing machine model 20712990 wont spin
If you don't hear a click when you close lid, replace lid switch. If when in spin, you hear motor but does not spin, replace motor coupler.
Sep 02, 2014 | Kenmore Washing Machines
2406026 fm54
Dryer will not spin, but can you hear the motor start when the button is pushed? If you hear the motor then the belt is probably broken. If you cannot hear the motor, then open the lid and check to see if there is a belt in place. A second cause for not dryers spinning are misaligned door switches. Shut the door and if it does not spin. Carefully hold the door switch closed by hand and see if does spin (for a second). This test will show that the door switch is working, but that the door is not closing the switch and that is it probably misaligned.
Jan 05, 2014 | Kenmore Dryers
Wont spin or drain makes ticking noise
Maybe the timer is not running.
Can you turn the timer ahead manually a step at a time? Then if you don't hear the motor running the timer may not be working or sending signals to motor to start. . But If the motor starts a spin cycle then the timer is just not running itself probably dut to not getting power.
All this is difficult without the diagrams. There are so many interlocks and safety switches that you wont know about
Jun 26, 2011 | GE WWRE6260D Top Load Washer
Water will fill but wont do anything else
Does the water turn off when filled? If so can hear a motor humming or running? If so you have power to the washer.
All this is difficult without the diagrams. There are so many interlocks and safety switches that you wont know about.
Jun 26, 2011 | Whirlpool Washing Machines
Dryer motor will not turn on to dry load of clothes. We know the circuit breaker is in working order. We know the plug is plugged into the socket. We hear the motor click but it won't run. I'm wondering if...
ok,. hmm,. sounds pretty likely that there is something blocking the drum from turning if you are hearing a clicking noise... if not then the motor itself may be seized,. if you can get the cover off the dryer you'd be able to test the motor to be sure... How old (or how many loads have gone through this puppy?)
Good luck with it!
Ck
Feb 13, 2011 | Kenmore 63942 Dryer
It will not play the dvd
I was wondering if you get the "No Disc" indicator on the screen when this happens. Also, can you hear the disc spin up?
Could try a disc cleaner that has the little brushes. It will clean the laser lens. If there is the slightest bit of dust on it in just the right spot, it wont play any disc.
Cheers
Dec 29, 2009 | Sylvania Televison & Video
Volume
Hmm... Maybe try removing the battery without turning the player off. I know it sounds crazy, but it resets the player to the default volume settings.
Mar 21, 2008 | SanDisk Sansa m250 MP3 Player
Player wont Spin all CDs
It mighr be spindle motor failing, possibly salvageable by spraying CAIG DeOXIT into motor and on shaft bearing. Run unit for several minutes to work into bearings.
Nov 15, 2005 | Kenwood CD-424M 200-Disc CD Changer
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
