Question about Freud FT1702VCEK 2 1/4 Hp Router With 2 Base Combo Kit
I need a base plate for a Freud FT1702VCEK to make a router table will a FT1700 work.
  • Anonymous Mar 12, 2014
    Freud RTS5000 Stationary Router Table System
  • 2,019 Answers
I don't think I understand, because all routers come with a base plate, and to make a router table, you would want to remove the base plate from the router, and use the holes underneath that.
But there was a whole lot of discussion about the very same subject on a router forum, so maybe you will find the answer you need there?
http://www.routerforums.com/guide-bushings-templates/12216-freud-ft-1702-vcek-combo-router.html
Posted on Oct 13, 2010
How to attach to my craftsmen router? I've inherited my Dads router, router table,and router guide. I have no idea how to use them. Will you please help me?
I have a craftsman router and table. On mine you remove all the screws from the base plate, set the base plate aside and use same screws to mount the router to the underside of the table.
May 08, 2017 | Saws
Freud ft2000 switch
You can find a part diagram and parts list on-line. Just enter the model #. The variable speed control module is no longer available. You can bypass the control, and connect the router directly. You will no longer be able to control the speed, or turn off the router. I used a variable 15A control box instead. It will function the same way.
You may want to just replace the router with a new up-to date router, I just purchased a 2 1/2HP Skil router kit tah has a 1/2 chuck, and both a plunger base a flat base, for $100 at a big box store.
Mar 23, 2014 | Freud FT2000E 3 Router
Router schematics
Hi I am a dealer for freud in Canada .Do you still need the schematics if so give me your email and I will send you one no charge.
Larry
haltonmaintenance@yahoo.ca
Jan 17, 2014 | Freud FT1700VCEK 2 1/4 Horsepower Variable...
I have a Freud 2000E plunge router. It is about 10 years old, but I've never changed the router bit I have in it before. Now I want to remove the bit I have in, but cannot turn the bolt to remove it....
Hello Davis gr,My name is larry I am an auth Freud service tech.
The first thing to do before you attempt any repairs is of course to unplug.In the full plunged position make sure the router is locked in position out of the table on its side.You twist to loosen the bit nut
and tap gently on the side of the bit with a rubber hammer
turning it slowly and it will come loose to remove.
second--If the router will not spring up to its top position it is because
the posts that are spring loaded are dry.again you must remove the router from the table clean the postd with a dry cloth and while still locked lubricate with lite oil using a clean cloth the metel posts.
after that with the same rubber hammer tap the base plate and it will come loose
I hope this is some help
Larry in Canada larry_boccioletti@yahoo.ca
Sep 11, 2011 | Freud FT3000VCE Router
How do I remove the base of a Freud FT2000e router so that I can remove the plunge springs? GeneSimm7@aol.com
Hi There, My name is Larry --I am a FREUD DEALER IN CANADA
To answer your question about the router springs.You must first remove the cap carefully to prevent any damage to the speed module. Under the cap you will find two nuts first lock the base and leave about 2 inches for a socket to go over the nut .Remove normally and be careful when you release the base do it slowly it will spring up fast and hard --
Nov 13, 2010 | Freud FT2000E 3 Router
I need the operating manual and the instructions for assembly, neither of which are in my box. Model 26464 Industrial Routing Table
Hi Ruggbob
My name is Larry Boccioletti from Toronto Canada.
I am a service dealer for Freud. I can get you an operating manual for your router BUT there is no assembly instructions for it.
If you need parts for your router I can supply.
I am the last dealer in Ontario for Freud because they were bought out by Bosch and are being fazed out.
my company is Halton Maintenance Centre and my email is haltonmaintenance@yahoo.ca
Larry
Sep 03, 2010 | Freud FT3000VCE Router
Square base plate and circular template guide missing. where are they available from?
Woodhaven sells all kinds of router accessories, or you can call freud, or you can make them yourself. We always made our own, to fit the job. It is nice to have the original for a template though.
Feb 22, 2010 | Freud FT2000E 3 Router
Freud router won't turn on
Check the continuity of the actual switch and second, I would verify that the brushes are connected. Hope this can help or atleast eliminate some possibilities.
Good luck
Jan 28, 2010 | Freud FT1702VCEK Router
How does one change from one collet size to another size. My Freud router came with the 1/2" collet installed and I need to change to the 1/4" size supplied with the router to fit a bit I want to use....
I just did this on my black and decker router. You need to unscrew the nut that holds the collet and remove it altogether. Then slip out the collet in there and replace it with the new size. Take care to notice how it goes in when you take the old one out. Then rescrew the nut that holds it in place and tighten. My router had three collets and only one of them works for each size, so if it doesn't tighten properly, it may be the wrong size. Good luck.
Apr 28, 2009 | Freud FT1702VCEK Router
Freud FT1702VCEK 2 1/4 Hp Router With 2 Base Combo Kit Logo
281 people viewed this question
Top Freud Tools & Hardware - Others Experts
freddyfox
Tom Chichester
Are you a Freud Tool and Hardware - Other Expert? Answer questions, earn points and help others
