Question about Humminbird 798ci SI Combo GPS Receiver
Humminbird 798 has erratic gps speed readouts at slow speeds between 1 and 3 miles per hour. Speeds bounce up and down between 0.1 and 3.0 mph even when sitting in the boat in my driveway!
  • imalyshko Mar 15, 2013
    Thanks for your reply. My problem was solved with adding an external antenna. This solved the problem immediately. The internal antenna seemed to lose signal at slow speeds. I have now replaced my unit with a 900 series Humminbird with external GPS antenna. Works like a charm.
    New Friend:
I had the same problem. I talked to 3 different technicians on the Humminbird support line about it. All 3 of them confirmed that this is how their technology works. They ping the GPS satellites continuously, and at low speeds the GPS accuracy causes the speed measurement to fluctuate wildly. It smooths right out when you go faster than 3 MPH, since your boat moves far enough at that speed that the GPS accuracy is no longer a problem.
Seems like they could easily overcome this issue by averaging GPS readings over a longer time period at low speed (i.e. give the boat enough time to move far enough to eliminate the accuracy issues), but they don't do that.
It was a big issue for me since I do a lot of trolling at low speed and need an accurate speed indicator, so I returned the product and bought a Lowrance instead. Lowrance doesn't have this issue.
Posted on Mar 14, 2013
2 Suggested Answers
hydetech
  • 113 Answers
SOURCE: Humminbird NS25 GPS
This is a common problem on lots of boats with any brand of electronics. Most likely it is being caused by a bad crimp in a wire connector, or by having too many connectors on a terminal in the power supply bus. Start at the power supply source and ground and replace any butt or terminal connectors with high quality heat shrink connectors (such as Ancor). Make sure that the connector is the right size for the wire.
On Humminbirds the problem could also be in the swivel mount that holds the power and data cables. The cables should be held in place by a metal bracket which is located under a panel held onto the swivel bracket by to small philips head screws. If any of those components are missing, the plug may be loose in the socket which could cause it to disconnect temporarily when the boat hits a wave. While you have it apart check the plug and the socket for corrosion.
I hope this helps. Please contact me if you have any more questions.
Posted on Feb 11, 2008
Why when i put in drive and go it goes into 1 or2 or drive by it self while driving
It always starts out in first, it's a 3 speed automatic, that's what automatics do. they start out in first and at about 15-20 miles per hour , they shift to second gear, and when the speed is about 35-45 MPH, the transmission automatically shifts into third gear, or Drive.
Bigger automatics have 4 or more speeds. Till recently, 4 speeds were the norm, and fourth gear was often dubbed Overdrive, as it allowed the engine to run slower in 4th gear, than it had to maintain speed in 3rd gear, drive. It's good, it increases your mileage per gallon of gas, so you save that way, but like all things more complicated, they cost more to fix when something goes wrong.
Nov 27, 2015 | 2003 Hyundai Santa Fe
Tip
Save Money on Gas/Petrol
  1. Avoid idling. While idling, your car gets exactly 0 miles per gallon while starting the car uses the same amount as idling for 6 seconds. Park your car and go into the restaurant rather than idling in the drive-through. Idling with the air conditioning on also uses extra fuel. Also, avoid going so fast that you have to brake for someone. Whenever you brake, you waste the gas it took to get going that fast.
  2. Drive at a consistent speed. Avoid quick acceleration and hard braking. Cruise control will keep you at a constant speed, even when going up and down hills.
  3. Avoid stops. If approaching a red light, see if you can slow down enough to avoid having to actually stop (because you reach the light after it is green). Speeding up from 5 or 10 miles per hour will be easier on the gas than starting from full stop.
  4. Anticipate the stop signs and lights. Look far ahead; get to know your usual routes. You can let up on the gas earlier. Coasting to a stop will save the gasoline you would otherwise use maintaining your speed longer. If it just gets you to the end of a line of cars at a red light or a stop sign a few seconds later, it won't add any time to your trip. Ditto for coasting to lose speed before a highway off-ramp: if it means you catch up with that truck halfway around the curve instead of at the beginning, you haven't lost any time. In many cities, if you know the streets well, you can time the lights and maintain the appropriate speed to hit all green lights. Usually this is about 35 to 40 MPH.
  5. Slow down. Air resistance goes up as the square of velocity. The power consumed to overcome that air resistance goes up as the cube of the velocity. Rolling resistance is the dominant force below about 40 mph. Above that, every mph costs you mileage. Go as slow as traffic and your schedule will allow. Drive under 60-65 since air grows exponentially denser, in the aerodynamic sense, the faster we drive. To be precise, the most efficient speed is your car's minimum speed in it's highest gear, since this provides the best "speed per RPM" ratio. This is usually about 45 to 55 miles per hour.
  6. Use A/C only on the highway. At lower speeds, open the windows. This increased the drag and reduces fuel efficiency, but not as much as the AC at low speeds (35-40 mph). The air con - when used a lot - is known to use up about 8% of the fuel you put into your car.
on Jul 31, 2010 | Acura Integra Cars & Trucks
How long will it take to get to missoula mt from billings mt at 75 mph ?
4 hours and 36 minutes if you are really able to maintain a consistent 75 mph speed.
http://imgur.com/uUwdeJO
Oct 24, 2014 | Games
Distance 1.00 equal 1 mile
Dear Sir:_
I will try to help you.
Please check this:
It is simple to change your treadmill so it reads MPH.
Treadmills are an easy and relatively inexpensive way of maintaining physical fitness. Most modern treadmills have a readout on their console that will track your speed over time in kilometers per hour or miles per hour. If your treadmill came with the wrong setting, it is possible to toggle between these two settings.
Instructions
Things You'll Need
  • Pencil
Oct 19, 2011 | Weslo Cadence 55 Treadmill
My 2004 elantra speeds up and slows down when driving. it does do it as hard when you go over 65 mph.
Hi and welcome to FixYa!
This can be caused by a faulty MAF (mass air flow) sensor or TPS (throttle position sensor). If one of this sensor is faulty the engine tends to speed up, slow down or have an erratic idle. Have it checked and replace if necessary.
Hope this helps and thank you for using FixYa! Have a good one!
Jan 26, 2011 | 2004 Hyundai Elantra
My milage or my miles per hour dont jump over im stuck at 2179mi and in 0 mph i changed clusters and its the same
check speed sensor, if no signal from it you do not get any change at the cluster.(no speed no distance)
Apr 15, 2010 | 2007 Suzuki GSX-R 600
ABS light & brake light on, problems with speedo working properly
The rear wheel speed sensor is the most common problem on those trucks and will do what you are talking about. It is located at the top of the rear axle in the center. It picks up it's signal from a tone ring on the diff inside! If a tranny input or output sensor is bad then the tranny won't shift properly!
Aug 13, 2009 | 1998 Dodge Dakota
Abs sensor
there is more than likely a piece of rust stuck to one of the front abs wheel speed sensors. this happens during brake service sometimes.
Dec 13, 2008 | 2003 Ford E250
Netgear dsg834gv3 erratic download speeds
I had the same problem, now i have none...............
how?
login to....
http://primustel.blogspot.com
and find out how............ Check out the ONSPEED banner
and also run a speed test. Good Luck
Oct 16, 2008 | NetGear DG834G Router
383c transducer gives nothing but noisy red feedback at medium or high speeds
If it works at low speeds fine but has problems at higher speeds, basically you need to lower the transducer down further as it is lifted by the boat at higher speeds, or is getting caught in the turbulence of surface water created at higher speed. Lower the transducer a half inch at a time and re-test.
Sep 19, 2008 | Humminbird XNT Transducers XNT 9 20 T ...
Humminbird 798ci SI Combo GPS Receiver Logo
316 people viewed this question
Top Humminbird GPS Experts
Mike Marcotte
Mike Marcotte
Steve
Steve
Jerry Greenberg
Jerry Greenberg
Are you a Humminbird GPS Expert? Answer questions, earn points and help others
