Question about Sony Optiarc AD-7240S 24x DVDRW DL SATA Drive Burner
I have dvd rw discs can i use them to copy ? - Sony Optiarc AD-7240S 24x DVDRW DL SATA Drive Burner
  • 734 Answers
Of course!
Your drive is advanced architecture and can even copy Dual Layer (DL) DVDs holding up to 8.5 Gigs of info.
Regards,
selk
Posted on Oct 13, 2010
  • Sony Master
  • 32,281 Answers
Yes, but you need to format the DVD R/W then you can copy and then paste to the DVD R/W disc.
Dvd write protection
Over the air broadcast has to contain a FLAG that makes it copy protected.
Nov 26, 2013 | Sony Electronics - Others
Using Windows XP. Want to copy vidoe from Media
Is the drive you are using a DVD writer or only a DVD reader? The drive that writes to RW disks is labeled DVD/RW or DVD Recordable.
These are the only drive types that will read and write a DVD/RW disc.
Jan 04, 2010 | Acer Aspire E500 PC Desktop
I am trying to record with a sony dvd-r disc and the recorder don't recognize it. the only disc that works is the dvd ram 4.7 but that disc does not work on other standard dvd players. what is the answer?
According to the official description of that recorder, you should have no problem, this is from the description for the DMRES15:
Recordable DVD Media
Record your favorite shows onto DVD-RW, DVD-R, DVD+RW, and DVD-RAM DVD discs. The DMR-ES15 is also compatible with DVD+R Double layer media and provides up to 14 hours of media recording.
Multi-Format Player
Don't worry about limited playback capabilities, the DMR-ES15 can play DVD, DVD-RW (VR Mode), DVD-RW (Video Mode), DVD-R, DVD+R, DVD+RW, DVD-RAM, VCD and CD-DA discs. Also, you can play your favorite songs from CDs or MP3 files, and JPEG images.
Nov 29, 2009 | Panasonic DMRES15 DVD Recorder
Won't work with the same kind of discs i've used before
I not sure as to which type of Discs that you are refering to (ie DVD+R or DVD+RW). This player will only recognize 4x (max) DVD+RW and 8x (max) DVR+R discs. If the DVD+R Disc is 16x, the DVD recorder will not recognize it once you start to record. The player will read the blank Disc and give the impression that it will record on it. I have noticed that when a 16x speed Disc is in the Drive, The recordable hours for the disc seems to double. The normal 6 Hour recording length comes up as 12 Hours when you hit the info button. Since the 8x Speed (max) discs are not available any longer, I found it best to use the DVD+RW 4x Discs and make it compatible. I then copy the compatible DVD+RW disc to a 16X DVD+R disc using my computer DVD burner. The DVD+RW disc can then be erased so that it can be reused.
Nov 23, 2009 | RCA DRC8295 DVD Recorder/VCR Combo
Can read but can't burn dvd drive in toshiba laptop
IF YOU HAVE WIDOWS VISTA, IT WILL WONT ALLOW TO MAKE COPIES, OR THE DISK YOU ARE BURNING IS RIGHT PROTECTED...IF THESE ARE NOT THE PROBLEMS CHECK YOUR BURNING SOFTWARE SETTINGS...OR LAST THING IS TO CHANGE YOUR DRIVE
Oct 14, 2009 | Sony Toshiba Qosmio F45-AV411 Notebook
I have an error 25 on my dvd recorder
Technically, E25 is a copy-protection error, but I have some additional background on this issue. On the one hand, it could be a legitimate copy-protection error - you are trying to record from a copy-once or copy-protected source - this is especially true if you are trying to record from a Cable/Satellite Box that has a DVR box - since copying to the DVR is considered the first "copy," the Magnavox will not allow you to make a "second" copy.
On the other hand, Magnavox/Funai players see all programs recorded in V mode (as opposed to VR mode) as "copy-prohibited". It records all +R discs in VR mode automatically, so the solution in this case would be to record on a compatible -R disc (or vice versa).
There are two simple fixes for this issue in either case:
1) If you are using a +R disc, switch to a -R disc. If you are using a -R disc, switch to a +R disc. Simply switching the disc type will "fix" Magnavox recorders (long story).
2) If your TV has a "Video Out" or "Monitor Out" (most TV's don't), you can connect a yellow video cable from the OUT of the TV to the Video IN on the back of the Magnavox. This will permanently resolve your problem by fooling the recorder.
Here is additional info about the type of disc to get:
IDiscs that have been tested and are proven to be compatible with this recorder:
VERBATIM DVD+R 8x, VERBATIM DVD+RW 4x
VERBATIM DVD-R 8x, VERBATIM DVD-RW 2x, MAXELL DVD-R 16x, JVC DVD-RW 4x
IWe strongly recommend for good recording quality:
TDK DVD+R 4x/8x/16x, SONY DVD+R 4x/8x/16x, MAXELL DVD+R 4x/8x/16x, SONY DVD+RW 4x,
MAXELL DVD-R 8x/16x, MAXELL DVD-RW 4x
Good Luck!
-Tha Mp3 Doctor
Feb 01, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Dvd burner question
First off is the drive a read only drive or a Read/write drive? If you look at the front drawer check to see if there is a big RW(read/writable) on the front of the drawer. If it doesn't have the RW then you won't be able to burn discs. If it says RW then you will be able use it to copy DVDs. You accomplish this by using software to copy the disc you're interested in to your hard drive and then using the copy on the hard disc to copy back to a blank recordable DVD placed in to tray.
Jul 23, 2008 | Computers & Internet
Writing to a DVD+RW disc
You need to use DVD software such as Nero that supports DVD-RW. from the app is where you would erase and so on
also make sure your blanks are +RW and not -RW
Jan 10, 2008 | Toshiba Satellite A75-S206 Notebook
Copying data on to a DVD
What type of application are you using? I know that the new nero requires you to choose whether you want to write to dvd or cd before it will work. maybe your application is similar.
Aug 01, 2006 | HP CD-Writer 9900ci CD-RW/DVD-ROM Burner
Sony Optiarc AD-7240S 24x DVDRW DL SATA Drive  Burner Logo
70 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
