Question about HP LaserJet 3330 All-In-One Printer
Proble with HP laserjet 3330
Window shows:
Scanner Error
Power off/Power on
turned off and back on and same problem has occurred 3x
help please
  • 2 more comments
  • LawFish Jun 02, 2008
    I have a 3330 printer and, after years of trouble free use, I get an error message that says "Scanner Error, power off power on." Which does not work, no matter how long the printer stays off. The printer will not accept a print job, but when I do unplug and plug it back in, it will print the job it had refused previously.
  • Anonymous Jun 02, 2008
    The printer says, Scanner Error, Power off -> Power on
    I've done that and still nothing happens, same erroe message. I have never had a problem before with my hp3330 printer
  • lbarrett11 Jul 11, 2008
    same error message, scanner error power on-power off.. i have unpluged numerous times, how do you reset this ?
  • kcmoonunit1 Sep 12, 2008
    I've owned 4 of them now; hunks of junk!
Cleaning all the mirrors in the scanner assembly solves this problem about 90% of the time. We see some customers every 18 mos. to clean their optics.
Posted on Jun 06, 2008
I had the same problem after a recent storm with resulting power surges. It wouldn't reset but I got lucky and after letting it sit unplugged overnight it seems to work fine now.
I went on the HP website's forum. There are a number of solutions suggested, including changing the electrical supply, a resetting back to the factory settings (relatively simple to do), a couple of ways to clean the scanner bulb and mirrors and a replacement of the scanner assembly. The cost for the latter seems to vary widely. The scanner needs to recalibrate itself. I reset back to the original factory settings and it has worked - so far so good.
Posted on Jun 03, 2008
    Problem Solver:
  • 14 Answers
You will have to have the scanner assembly replaced. There were some problems with the earlier versions and they have seen been rectified. I have not had a single one come back in after replacing it.
Posted on Jun 02, 2008
Red paper light keeps flashing. Closed all doors, turn on and off
Close the front cover. If the error is not
cleared even after closing it, open the cover
once and close it again.
The error may occur because of the laser
BD malfunction. The Laser unit may need to be R/R'd
Try cleaning the Scanner Window
When replacing the drum unit or toner cartridge with a new one, be sure to clean the scanner
window.
1) Turn off the power switch and unplug the power cord.
2) Remove the drum unit from the printer.
3) Gently wipe the scanner window with a soft dry
CAUTION:
· Do not touch the scanner window with your fingers.
· Do not wipe the scanner window with cleaning alcohol (isopropyl).
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
cloth.
Feb 10, 2011 | Brother HL-2040 Laser Printer
Canon MP 648 suddenly appeared a message: ERROR 5012, then after the power off and turned on again appears ERROR 5050. Printer error has occurred. TURN POWER OFF THEN BACK ON AGAIN. SEE IF THE PROBLEM...
From the service manual, both errors relate to the scanner unit:
[5012] An error occurred in the scanner FB motor.
(1) Cable connection (2) Part replacement: - Scanner unit
[5050] The AFE was faulty.
I don't know if the following YouTube video will help, but you could watch and see if it applies to your printer.
Error 5011 and 5012 Printer Canon MG 2570 MP 237 MP258
Feb 09, 2018 | Computers & Internet
We are not able to get our Fujitsu fi-5120C out of status 8. We've turned it on/off unplugged it changed one of the pads (as it was bent). We left it alone for a day and it's still not working. Do you have...
Thank you for contacting FixYa.
Please clarify if the error is E8 or some different error. E8 error indicates that SCSI fuse is blown. When 5V, 3.3V fuse is blown, the scanner does not turn on and E8 error is displayed. Check the SCSI fuse status. The SCSI fuse is located in the Control PCA marked as TH2. This alarm is detected during initial processing immediately after power-on.
Probable causes:
- Defective SCSI cable. #Check the SCSI cable status.
- Other SCSI device malfunction. #Check the SCSI device.
1. Does the same symptom occur after turning OFF and ON the scanner?
To check, press power button of the scanner for more than 2 seconds to turn it OFF, and after more than 2 seconds elapse, press the power button to turn the scanner ON.
2. Check if the SCSI cable or other SCSI devices connected to the scanner cause this error. The scanner can work even after this error occurs. However, to remove this error you may have to replace the Control PCA.
Hope the above information will be helpful.
Please revert if you have further queries.
Thanks & regards,
TechSatya
Microsoft Word - P1PA03289-B30X6_03.doc matsubara 11.9999 Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Jul 15, 2010 | Fujitsu fi-5120C
Paper jam message is showing but nothing is jammed in scanner and it will not pull the paper through
Hi
Does the message shows after few pages scanning or is there any panel error message like J-1 on scanner start up?
If the issue occurs during scanner start up, then there are staple pins or dirt might be stuck inside the US Sensor panel inside the scanner. Cleaning and removing the objects will resolve the issue.
If the error occurs after few pages scanning, then you may have to check the Pick Roller, Brake Roller, Pinch Roller and US Sensor FX status. you may have to replace any of the above, if damaged or worn off.
Hope the above info is helpful.
Please check your device first and get back to me.
Thank you.
Regards,
Tech Satya
May 26, 2010 | Fujitsu fi-6130 Flatbed Scanner
Driver problem for colorpage-vivid 3150 scanner in windows xp
you can get the driver from
http://drivers-free-download.com/driver-genius-colorpage-vivid-3x-scanner-driver-windows-98-me-2000-xp/
Hope this helps you. Please If this solutions solves you problem, please do not forget to rate my solution. If not, then please comment back so I can help some more
Mar 26, 2010 | Genius ColorPage Vivid Pro II Flatbed...
Canon MP480- 5011 - Printer Error Has Occurred After Scan/Prt
You need to carefully clean the encoder strip. It's the clear strip behind the carriage that runs all the way from right to left. A damp Q-tip should remove any grease or fingerprints.
Jul 16, 2009 | Canon Pixma MP480 All-In-One InkJet...
Printer problem
remove the ink case or catridge then reinsert them again they should work unless something is broken.
May 24, 2008 | Office Equipment & Supplies
Scanner error message hp laserjet 3030
my hp 3030 printers shows warning up bulb and make noise how can i solve it ?
Mar 05, 2008 | HP LaserJet 3030 All-In-One Printer
HP LaserJet 3330 All-In-One Printer Logo
312 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
