Question about Garden
I am looking for a manual for a Kawasaki 20 gallon air compressor model # 691743. Where will I find this? Thank you
  • 47 Answers
SOURCE: air compressor
could not find any such air compressor on the net. Please check the make and model and reply back.
Posted on Apr 01, 2008
  • 7 Answers
SOURCE: No psi
A louder motor usually means that it is running at a higher rpm. The most likely problem is bad seals around the compressor pistons. Once there is enough resistance to the seals they will begin to fail. As for a manual the best place to check is a CH authorized repair shop. Sometimes your local lawn mower shop will be able to assist you with parts help
Posted on May 02, 2009
  • 4088 Answers
SOURCE: I have a model FP209501 Air Compressor 2 Gallon,
The spray gun consumes more air volume than the compressor can deliver. You can pause painting periodically to allow the compressor to 'catch-up' or buy a larger delivered-volume compressor. The compressor that you have was intended to supply air for pneumatic nailers and staplers in an intermittent fashion. Hope this helps!
Posted on Jan 18, 2010
SOURCE: Need manual for a Kawasaki model 840703 5gal 3hp
I called 1 800 590-3723 and they are e-mailing a manual to me. For my model (3HP twin tank) they said 10W30 or 5W30.
Posted on Feb 26, 2010
wentlanv
  • 710 Answers
SOURCE: I have a 5hp 20
Hi tepeyac_3,
It sounds like the unloader valve is either stuck or needs replacing. Do you have an owner's manual with a parts breakdown? If not, try this site for a new valve: http://www.mastertoolrepair.com/campbell-hausfeld-parts-campbell-hausfeld-portable-c-271_468_474.html?osCsid=uspnd22h34i3k38p6mcf521e46
Copy and paste this entire address into your browser. You will have to look up parts according to your model number. This website includes diagrams so you can see how your compressor goes together.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Posted on Jun 13, 2011
Am out of oIL to put in a campbell hausfeld 20 gallon 4.5horsepower air compressor
Google the model number, download a copy of the owner's manual, follow directions. Try searching that model number at harborfreight.com If the manual does not exist anymore, and the pump has a sight glass, fill with clean, non-detergent straight 30wt motor oil, available at most car parts stores. If there is no sight glass, drain what is in there and pour in 1/2 qt. No promises that is right, but it is likely close. Last option, go to a Harbor Freight store. Look for a compressor with a pump that looks like yours on size and shape. look at that manual and use that amount of oil. Good luck
Sep 28, 2015 | Campbell Hausfeld Air Tools & Compressors
Looking for manual for sanborn B51-A24-80V1 model
PDF]Sanborn Black Max 5hp Air Compressor Manual B51 A24 80 1
intrigante35hindu.strictlyyouth.org/rzsatzo_sanborn-black-max-5hp-air-...
Jul 16, 2015 - Sanborn Black Max 5hp Air Compressor Manual B51 A24 80 1 ... Black Max Portable Air Compressor - 5 gallon Item #: 81527 ' Model #: BS0880504 ...Compressor Manual: $4.95: Buy Now: B51-AT24-80V,B51-A24-80V1.
Aug 28, 2015 | Air Tools & Compressors
How much oil for a quincy compressor model #216
What type of gauge belongs on the side of a 216 quincy compressor?
Also were can i locate one?
Thank you!
Tom
Mar 24, 2013 | Honda Quincy 17 - Gallon Air Compressor...
Looking for manuals for husky air compressor model FP204500AV
The manual and parts breakdown for your compressor can be found at: http://www.chpower.com/IMAGES/pdfs/manual02/608800_1102.pdf
If that doesn't work look for it on the Campbell-Hausfeld homepage at http://www.chpower.com/ under Service and Support. They have been working on the site so some links are not working correctly.
Your compressor is an oil-less type that has very little for you to do as far as service. Mostly you just have to keep it clean and occasionally drain the water from the tank. The frequency of that is dependent on where you are (humidity levels in your area) and how ofter you use it.
May 22, 2012 | Air Tools & Compressors
I want a operators manual for a coleman powermate air compressor 20 gal tank
You should be able to download a manual from this site:
http://www.powermate.com/productmanuals.php?cat_id=1
The VLF1582019 is a 20 gallon model but you should confirm if this is the model number of your unit.
May 23, 2011 | Coleman Powermate 02 - Gallon Air...
Jun 19, 2009 | Air Tools & Compressors
Owners manual
Get on E-Bay and type in a company by the name of "Industrial_ Manuals". They're a real good source for air compressor manuals. John
Mar 23, 2009 | Ingersoll Rand Compressors 5-HP,...
Wiering
look at the motor nameplate it should have voltage and fla which is full load amps this should be calculated by an electrician for wire size hope this helps
Aug 05, 2008 | Campbell Hausfeld 04 Gallon Twin Stack...
Garden Logo
200 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
