Question about Canon PIXMA MP150 All-In-One InkJet Printer
Damaged scanner ? (Canon MP150)
When I copy on my MP150, on the paper is a slip of noise. Here is scanned paper. Over 400dpi is all OK. Under 400dpi is a slip in ever scanned document. Where ist the problem?
http://img46.imageshack.us/my.php?image=imgoj3.jpg
    Problem Solver:
  • 15 Answers
Seems like maybe the ccd unit which turns the light reflected off your image into the digital version which is then displayed on your screen or printed. Im purely having a guess, but i just cant think what else could be doing this. I feel as though you could possibly be buying yourself a new printer soon.. In that case the mp 520 a VERY good valued approach.
Posted on Jun 13, 2008
Printer displays alarm and indicates there is a paper jam. However, there is no paper jammed. What can be the problem?
Could be dirt blocking a sensor, damaged sensor, or paper pieces where the sensor can pick them up.
Mar 03, 2016 | Canon Pixma Mx310 Office All-in-one...
Error 19
Hi there-
Below are a list of the error codes for this model.
E16-E19 = Failed to scan head alignment sheet.
You can find this information at http://www.usa.canon.com/cusa/home
CANON MP140, MP145, MP150, MP160 RESET ERROR CODES
[Info140] pixel_trans.gif RESET ERROR CODES CANON MP140, MP145, MP150, MP160
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge
is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera
Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
Nov 29, 2013 | Canon PIXMA MP150 All-In-One InkJet...
How do you scan an image onto the computer using the Canon MP190 series? Ive tried hitting scan and it only tried to copy the image and print onto paper.
Place the paper you wish to scan on top of scanner.
1. Go to window start manu.
2. Find picture board.
3. Click the file manu at picture board, and find the scanner.
4. Click the scanner and it will scan the paper as soon as you click ok...
5. After completion of scan, click "save as" and name the title wish to make.
That's all...
Apr 21, 2011 | Canon PIXMA MP190 All-In-One InkJet...
How do I use the scanner and send scanned copy on email?
KEEP PHOTO WHICH U WANT TO SCAN THEN PRESS SCAN BUTTON THE TAKE PREVIEW IN SCANNER WIZARD
Nov 30, 2010 | Canon PIXMA MP150 All-In-One InkJet...
How do use the Scanning Feature ?
navigate to your scanner through cannon utilities lift the lid lay a document/paper face print side down then press preview document which will scan document after this you will have to save this document somewhere
hope this helps
Sep 20, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Canon - Pixma MP150 printer/scanner won't scan in color.
may be you not installed the scanner application software if you have driver disk of printer choose the customs installation and select the scanning option menu and re install it the application.
Sep 18, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Can i scan slides with my Canon PIXMA MP150
No. This feature requires a light source to shine light through a slide to the lens so the image can be copied. Your Canon all in one doesn't have a transparency top that shines light through a slide. I had to get an Epson Perfectin scanner with transparency top to copy my slides. Hope this helps.
Feb 21, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Copyer problem
Go to the Control Panel, open Printers and Faxes, right click on the icon for your Canon, choose Properties.
Since the offered settings can differ from one model to another, you may have to look at any tabs shown to find the default setting for paper type but it will probably be under 'Advanced.' Check through the various settings and you should find settings influencing which paper size the printer should use and expect.
Oct 18, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Scanning speed problem
The scanners rated speed is for black and white all error correction turned off. As soon as you start doing 24bit colour or grayscale or up the dpi the scanner will start scanning more slowly. I personally get abpout 60ppm with my error correction on black and white 200dpi. (300 dpi scans just as fast although 400dpi will slow down).
Sep 28, 2007 | Canon DR-9080C Path-Through Scanner
Canon PIXMA MP150 All-In-One InkJet Printer Logo
old marine
old marine
