Question about Epson Stylus NX400 InkJet Printer
I have a epson nx-510 when i change the ink cartrige # 69 the printer not recognized the cartrige.
  • 10 Answers
SOURCE: Just installed Epson NX400 printer.
If you have re-inserted the inks, then you might have a faulty ink cartridge. M88/69 indicates Magenta is not recognized and B88/69 is for black. You can have the store replace those inks for you or contact Epson tech support.
Posted on Jan 03, 2009
SOURCE: epson stylus cx8400 cannot recognize ink cartridges
I had the same problem except it would not recognize any of the ink cartridges. I kept hitting the OK button over and over again with the same cartridges in place not removing them at all and it finally recognized them. Decided to go to maintenance on the printer to do a test, and it went right back to not recognizing the cartridges. So i pressed the OK button over and over again until it finally recognized all the cartridges again, but this time i did not try and go into the maintenance to do a test run. Plugged it up to the computer and it has been working ever since. So press the OK button until it recognizes the cartridges, and run no tests on it is what my solution was for the problem. Really is a pain but it works now.
Posted on Apr 06, 2009
  • 121 Answers
SOURCE: My Epson Stylus NX 400 is not printing.
no it cannot. Those multi-colored cartridge system requires that you put in every single color, AND ensure that they are not empty before they will print. Even if all you want is a black and white copy.
Posted on Apr 28, 2009
sherlyn c
  • 134 Answers
SOURCE: My Epson NX 400 is giving me this error message:Error B88/69/68 C
Try to run the ink pad reset utility software.
Please log on to epson.com. The software runs on win xp and win vista.
Posted on May 03, 2009
  • 30 Answers
SOURCE: Epson Ink Problem on sx200 printer
Fiend your solution direct from EPSON. Here is your solution...
http://www.epson.com/printer/prob676ijt65/solution
takio-28
Posted on Sep 04, 2009
Epson Stylus NX 125/127 Series Both power light and ink light flashing not recognizing two cartiages
Power light flashing : processing. Ink light flashing : not recognizing cartridge. Replace the cartridges.
Feb 17, 2013 | Epson Stylus Multifunction Inkjet Printer/...
My friend had a problem of his printer, cause the printer didnt recognize the ink... it has 6 colors epson ink. we dont know how to fix it... all the cartrige shows x
Is your friend use CISS. If so
Move Ink cartrige holder to cartrige change station.
Put off cartrige ( genuin or CISS) from carrage
Take a soft erager try to remove dry in or dust or waste everything smothly
reassemble the cartrige again
push top of the cartrige gentaly sothat it struck acurately.
Turn on printer.
I think you will get rid from your pprinter problem.
Thank you
Aug 21, 2011 | Office Equipment & Supplies
BOUGHT NEW CARTRIGE FOR MY NX 415 AND THEY AREN;T REGOGNIZED!
If the cartridge is not the same code as the previous used by the printer, then it will not be compatible. Your printer has been replaced by Epson Stylus NX415 All-in-One
  • One 69 Black Ink cartridge (T069120)
  • One 69 Cyan Ink cartridge (T069220)
  • One 69 Magenta Ink cartridge (T069320)
  • One 69 Yellow Ink cartridge (T069420)
  • Therefore, ensure that the catridge follows the above code (69).
    Best regards.
    Jun 10, 2011 | Epson Stylus NX400 InkJet Printer
    The printer do not recognize the new replacement cartrige
    I have many epson printer, some more than 5 years old. It's ok. some have printed more than 50.000pages, it's ok.
    If Ink cartridge Unrecognizable, there are two posibilities : Chip Error at ink tank, or printer error. For chip error, try to plug the ink tank to another printer (same type). If the ink tank recognized by other printer, so the problem is printer.
    So ;
    1. Check chip conector at head carriage.
    2. Check the wiring of the head, and chip.
    If two point above is ok, the last action is check the power supply and board. It may be epprom is damage.
    May 28, 2009 | Epson Stylus R380 InkJet Photo Printer
    REPLACED TWO 68 CARTRIDGES IN CX9400 EPSON
    Generic carts are sometimes not recognized. Epson's chips are the cause. I solved this problem for a small investment. I purchased a CISS system for about $75.00 [ink included], that's the cost of OEM carts that do not last very long. The CX9400Fax is an Ink Hog, which is why the printer is so cheap. If you want a CISS go to http://www.inkproducts.com/ink-store/ They are great if you need help and will call you back in less than an hour. Get the Waste Ink Kit when ordering the CISS.
    Apr 05, 2009 | Epson Stylus CX9400 Photo Printer
    Mar 31, 2009 | Epson Stylus NX400 InkJet Printer
    UNABLE TO USE #88 INK FOR MY EPSON STYLUS PRINTER.
    I don't know where you got your #88 cartridges from or who told you that they were compatible with your printer, but they were wrong.
    The CX7450 will only work with the #69 type cartridges.
    The cartridges themselves may look similar but the chip programming will be different for each.
    Hope that helps.
    Feb 21, 2009 | Epson Office Equipment & Supplies
    Just installed Epson NX400 printer. Keep getting M88/69 "Cannot recognize ink cartridges" error. Tried re-inserting cartidges twice already and still same error. What next?
    I found a solution to the same prolem that you guys have. I took the cartridges out and shook them horizontally, instead of vertically, with the large surface up for 3-4 seconds. Re-inserted them back in. Then I started seeing on the LCD "Recharging Cartridge". When it returned to regular copy screen, I turned the printer off and turned it back on. No more error message. It's been working for almost a day now. Try it to see if that works for you. Good Luck.
    FYI. I just bought NX400 last Friday. The error message came on this morning.
    Jan 01, 2009 | Epson Stylus NX400 InkJet Printer
    Ink cartriges not being recognized by printer
    It is not uncommon for an Epson printer to fail to recognise Epson cartridges. It is either due to failing to go through the proper cartridge replacement cycle properly, or more seriously, due to a communication problem between the cartridge and the main board. To fix the first, simply go through the cartridge replacement cycle again (see your manual how to do this before the cartridges are empty). Simply take your new cartridges out when told to, and put them back in again when told to insert the "new" cartridges. If it's the second problem you need specialist help, or simply sell your printer on e-bay for what you can get.
    Dec 17, 2008 | Epson Stylus Photo 830 InkJet Printer
    Epson Stylus NX400 InkJet Printer Logo
    269 people viewed this question
    Top Epson Office Equipment & Supplies Experts
    Alun Cox
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
