Question about Frigidaire Freezers
Frigidaire Freezer RIP 10-11-10. The front temp control panel of this 2 yr old FFU14F5HWB was not illuminated as usual & there was no inside light or compressor activity at all. Outlet had power & unit was plugged in. Can't find anything obvious. Removed front panel w/ circuit board. It's getting 1.3 VAC to pins 1 & 2. Is this circuit board dead?
  • 1,531 Answers
Yes you need to replace the circuit board
Posted on Oct 13, 2010
With deluxe Electronic Temperature Control Freezer control panel shows "OF" and I can't restart the freezer
Search Results
    Freezer electronic temperature control manual... ' Sears ...
    www.searspartsdirect.com > Ask an Expert
    Jul 5, 2012 - I have a Kenmore elite freezer with electronic temperature control. ...my freezer was delivered yesterday, the control panel is stuck on of, ... an electronic control on front. the display is showing hi temp and door ajar. also an l in ...
    Control Panel is not working right - Samsung
    www.samsung.com/sa_en/support/skp/faq/239315
    Samsung ElectronicsSep 3, 2015 - In case of wrong temperature display, possibly door opens so inside ... If the control panel is still not lit up after you plug the refrigerator back in, it may ... When initial installation, Temperature will show current temperature for a ... When the refrigerator/ freezer reach the set temperature, the blinking will stop.
    Adjusting Side-bySide Refrigerator Temp Controls - Actual ...
    ? 3:50
    https://www.youtube.com/watch?v=DFzTGKVo79g
    Jun 27, 2010 - Uploaded by GE Appliances
    CAN I TURN OFF THE DIGITAL CONTROL ON FREEZER AREA ONLY. ... I need to know How to reset this kind of refigirator, same front panel ... When you try to set the actual temperature, does your control show your new ...
    Electronic Temperature Controls - ManualsLib
Feb 03, 2016 | Freezers
What should I do? Freezer is not cooling, inside light is on, control panel is off temp shows blinking OF and FF
usually means low freon... (of) and evaporator fan failure. can you hear the fan running in the freezer portion?...
Jun 05, 2015 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Frigidaire FFU14F5HW Hi-Temp alert. Checked thermistor at front panel pins 1 to 2, reading was 162.8K ohms. Removed panel to check thermistor, then put it in a cup of ice water-now reads 32.1K ohms. P
Check the internal temp with a thermometer. Anything above -12c will give you the hi alarm. Check the condenser is clean and drier not too warm, no ice build up inside the evaporator and all fans working properly etc, before suspecting thermistors.
Apr 02, 2014 | Frigidaire FFU14F5HW 13.7 cu. ft. Frost...
My upright frigidaire freezer is set on -1 degrees, but the display on the front indicates the temp is 8 degrees. It has gone as high as 11 degrees. Does this mean it is defrosting or is there another...
Hello swanee3669 - Have you trying measuring the temperature inside the unit to confirmed that it matches the display? If so, I recommend contacting a professional to accurately diagnose the unit since it sounds like it could possibly have a bad sealed, thermostat or control board.
Sep 25, 2012 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
I have a 17 cu ft. frost free freezer, Model F17WCE and I believe the tube is clogged. I thought if I found the plastic tube, I would wash it out. I saw the tube from the front of freezer, while lying on...
Usually you can access a service panel to where the fan and evaporation department is.
I don't know about a wood but I did work on an upright not long a go and took some pics.
See the drain hole below the fan on the floor there?
Thats what ya gotta clear. I use a shop vac myself but I let the freezer thaw all the way out , you could use a hair dryer to melt the ice.
Aug 13, 2011 | Woods Upright Freezer V1613RW3
Light inside on thermostat not working
If the compressor is not working and the unit has a electronic control board try and replace it.the other thing to check is the over load relay and the start ptc on the compressor. make sure there is power to the compressor.If it is still under warranty set it up for service and it will not cost you any money. you can put a 5 to 10 pound block of dry ice in the cabinet to keep things cold for about 24 hours until you get it running
Jul 09, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Frigidaire upright freezer is making whining, revving noise, like a model airplane. What is this, and is it worth fixing in a 15-18 yr old freezer? Thanks!
If all is working fine otherwise ,check the fan in front of the condenser.It may just be the wear in the fan bearings.A replacement fan would be all thats needed to fix then.
Oct 14, 2009 | Freezers
Frigidaire twin freezer not working
Check the freezer back wall for snow or frost.If it's there you have a defrost problem.
May 25, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezer not working
I have a Kenmore Freezer model # 253.9251310 serial # s510347256
10\95 Makes all kinds of noises and now is defrosting. Sounds like fan is working but no noises besides fan. any ideas
Dec 12, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezers Logo
256 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
